Install - EVAP Purge Solenoid Valve CANYON - Chevy Colorado & GMC Canyon
post #1 of 20 (permalink) Old 12-07-2009, 01:11 PM Thread Starter
Hey all,
I recently purchased an EVAP Purge Solenoid Valve for my 2004 GMC Canyon and wish to install it. The part that I received from GMC is labeled as "valve evap em" on the package. I never installed one of these before and would like to know how I go about this and where I could find this part on my truck. I have searched online and can find any instructions or anything on it. Here is a picture of the item in the bag:
I can take other pictures if need be. Thanks in advance for any advice or help
Thanks all!
nine9d is offline
post #2 of 20 (permalink) Old 12-07-2009, 01:29 PM
Re: Install - EVAP Purge Solenoid Valve CANYON
This thread tells you how to replace it and has pics :D : viewtopic.php?f=8&t=76502
post #3 of 20 (permalink) Old 12-10-2009, 07:22 PM Thread Starter
Dude you totally rock! You know how long I have been looking for that. I just replaced the piece, I am so stoked man!
Question: Should I let the check engine light reset itself and if so, how long should it take. Is it on mileage or on how many engine recycles? I read that I can reset it myself by taking off the positive cable of the battery for 4 minutes than replacing. I need my truck inspected by the end of the month.
Thanks again bro! WOOT!
nine9d is offline
post #4 of 20 (permalink) Old 12-10-2009, 10:08 PM
The CEL should go off after a certain number of engine on/off cycles, but you could swing by someplace like Autozone and have them clear the code for you. :D
post #5 of 20 (permalink) Old 07-28-2011, 12:29 PM
can you send me in the right direction for replace of purge vale that thread link does not get me anything
dana b is offline
post #6 of 20 (permalink) Old 07-30-2011, 12:29 AM
I wish I would have seen this thread earlier....just had this done at the stealership. Cost me $256 that I didn't have. The part was $175 plus $60 labor and tax...is this about what you paid for the part? ($175)
Black06Canyon is offline
post #7 of 20 (permalink) Old 07-18-2012, 11:14 PM
The link to replace the GMC Canyon purge valve solenoid does not work. Can you tell me where in the world this part is located on the truck? I have looked and looked and looked and looked ... THANKS!
rickh is offline
post #8 of 20 (permalink) Old 07-24-2012, 10:16 PM
I would appreciate this info as well.
Austin99 is offline
post #9 of 20 (permalink) Old 09-20-2012, 07:07 PM
I need a little help with finding pics of purge valve solenoid Thanks
John Costello is offline
post #10 of 20 (permalink) Old 09-21-2012, 09:40 AM
Colly_shifter's Avatar
How to: Replace your Evap Canister/Solenoid (P0455 code) - Chevrolet Colorado & GMC Canyon Forum
2006 Chevrolet Colorado Regular Cab Black w/sports pkg., 2WD, 2.8 I-4 w/ Manual Trans.
Colly_shifter is offline
post #11 of 20 (permalink) Old 11-19-2012, 06:52 PM
As an aside, I just ordered that part from Amazon for 20 bucks, shipped
Ed
z16monte is offline
post #12 of 20 (permalink) Old 01-29-2013, 08:23 PM
I am having the same problem with locating the EVAP Purge Solenoid Valve. I can't access the thread provided. Can someone help me with replacing this? Thanks.
crivera1 is offline
post #13 of 20 (permalink) Old 01-29-2013, 09:12 PM
Send a message via MSN to braindead1684
The condensed version,
Lower spare tire
Under the Bed of the truck above axle you will see a big 12" x 6" rectangle i beleive there are two 10mm bolts holding it in. Remove that box and unhook the line, you should be able to swap out the solenoid and reuse the hose, i had to break the solenoid to get the hose off (pinched the end of the hose and broke the plastic inside then pulled it off.
Then re-install in reverse.
Current
2016 CC LB 2.8L Duramax Diesel
GMC Canyon.
The Original (Sold June 2016)
2007 4x4 Z71 3.7 I-5
Hunter Brush Guard
Access Lorado Rollup Tonneau
Window In-Channel Vents
DDM Tuning 55w 5000k HID
Fosgate Punch 10" Sub w. Custom Box.
braindead1684 is offline
post #14 of 20 (permalink) Old 06-25-2013, 01:20 PM
New member here and this is my first post. I have a 2005 Canyon (I-5) and I've had an issue with code P0446 for the past year. The engine light keeps coming on and off. My dealer said I should replace the evap vent and purge solenoids for $300. From the parts breakdown I've seen online I can't find an evap vent. I do see these parts (part# 25932569 purge control valve and 12597567 purge solenoid) I believe the purge control valve is located in the back near the fuel tank and evap canister. I would like to replace the purge solenoid but I can't seem to locate it. The person that started this post had a picture of the purge solenoid...where does it go?
Thanks!!
VA_GMC is offline
post #15 of 20 (permalink) Old 06-25-2013, 02:59 PM
There are two separate valves in the Evap System. A Vent valve and a Purge valve. The Purge valve is mounted on the engine and the Vent valve is mounted next to the charcoal canister, under the truck bed, forward of the spare tire. Replacing the Vent valve usually corrects the P0446 DTC.
Some more info here:How to: Replace your Evap Canister/Solenoid (P0455 code) - Chevrolet Colorado & GMC Canyon Forum
Edit: you need the part number 25932569.
post #16 of 20 (permalink) Old 06-25-2013, 04:52 PM
Thumbs up
Thanks cart7881. Good info at the link you referenced. Can you tell me where on the engine the purge valve is located? A picture would be great.
VA_GMC is offline
post #17 of 20 (permalink) Old 06-25-2013, 06:26 PM
Replace the vent valve on the Canister first. It is a high failure item on the this vehicle.
n9cv is online now
post #18 of 20 (permalink) Old 06-25-2013, 08:02 PM
Will Do. Thanks n9cv.
2005 Canyon Z85
Fire Red 3.5L
4wd Crew Cab
VA_GMC is offline
post #19 of 20 (permalink) Old 04-24-2017, 11:54 AM
CANNOT FIND PURGE VALVE Chevy Colorado 4 Cyl.
Try as I may, I CANNOT locate this Purge Valve. I've tried MIRRORS, spot lights... but it LOOKS and FEELS like nothing in the diagrams.I have the wheel and the plastic splash off .... Once I find it I'll be OK. But ... I 've tried for two weeks. HELP!!
djb0254 is offline
post #20 of 20 (permalink) Old 04-24-2017, 12:02 PM
There is a tube connected to the forward side of the Throttle Body. Follow that tube to where it connects to a component below the Intake Manifold. That component is the Evap Canister Purge Valve.
