Colorado won't start - Chevy Colorado & GMC Canyon
 1Likes
  • 1 Post By pedalslipjohn
post #1 of 18 (permalink) Old 01-05-2010, 01:48 PM Thread Starter
So my Colorado won't start. When I try to start it, all the lights, radio, AC fan turn on and work and don't dim. I replaced the battery anyway, but it still doesn't start. I tried starting and leaving the key to the on position for 10 minutes then attempted to start it again and still nothing (a mechanic told me this will sometimes reset it if it's a security/anti theft problem). Before having it towed, I was going to bang on the starter, but I couldn't find it when I climbed under the truck. Can anyone tell me where exactly it is and how to locate it on the 2005 4wd 5 cylinder? Also any other ideas would be appreciated before a pay $125 to tow it and then who knows how much for a dealer to diagnose and fix it.
Thanks.
aaronabbott is offline
post #2 of 18 (permalink) Old 01-05-2010, 03:15 PM
Re: Colorado won't start
play with the shifter-make sure it in park or neutral-safety interlock.automatic's
if standard the clutch pedal safety switch.
starter is on the drivers side below the intake you may beable to see it through the wheel opening with the rubber splash guard removed.
05 offroad/31's/airlift/custom slidein camper/k&n filter/custom 5 leaf spring pack.
2 1/2 yrs of owning and still enjoying it..
mazdab2600 is offline
post #3 of 18 (permalink) Old 01-05-2010, 06:15 PM
Guest
Posts: n/a
i would hate for it just to be this but did you check the starter fuse? its under the hood in the fuse box. i can't remember the exact location but it should be listed on the diagram on the fuse box lid. i've blown this one a couple times now and it does all of what you're describing when it's blown.
post #4 of 18 (permalink) Old 01-17-2010, 04:45 PM
is the starter cranking but the engine not turning over?? You said you replaced the battery and still had the same problem, which would mean power was disconnected and the PCM was reset so it probably is stupid PASSLOCK. Did you get the problem diagnosed?
calirado22 is offline
post #5 of 18 (permalink) Old 01-18-2010, 01:05 AM
Send a message via Yahoo to 1BAD355
i agree if the engine is turning over but not starting you might want to wait about 10-12 min if it does start after that then it is the passlock/ignition switch going bad you would have to get the ignition switch replaced the passlock sensor is built into the ignition switch i had the same problems and they got prgressivly worse and i finaly broke down and replace the ignition switch cost me about $60 at the deal plus another $30 for reprogramming so you can look at spending close to $100 after taxes and every thing but i have not had any problems since.
1BAD355 is offline
post #6 of 18 (permalink) Old 08-16-2010, 08:43 AM
aaronabbott Did yo get your starting problem fixed. I am having a simular problem, get turn the key to on all lights come on, radio works, but turn the key to start and the starter will not turn over.
CRFARROW
crfarrow is offline
post #7 of 18 (permalink) Old 08-16-2010, 12:55 PM
I have a simular problem.
Tried to start my 06 Canyon, the dash lights came on when the key is truned to on, but when you trun the key to start the dash lights go out and the starter will not even try to rotate. Waited about an hour and tried it again still nothing. Three hours later it would start.
This has happend two other times, but did not take as long to restart.
Any help would be helpful.
crfarrow is offline
post #8 of 18 (permalink) Old 08-18-2010, 09:59 PM
i also am having this problem .. it comes and goes .. i know its not my red top , becasue not only do the interior lights work, all 6 6000k HIDS work, and my sound system works.. the starter wont turn.. the dash reads " traction Fault... reduced power" , so ive been disconnecting the positive battery terminal for about 10 minutes and then it fires right up like nothin happend..
im also having another issue with my truck .. recently while ive been driving home from work on the highway my truck will suddenly veer right , the first time it happend i almost hit the car in the right lane. after i gatherd the truck back my steering wheel was off center , the truck pulling to the right. could this be the half moon keys within the steering components or could this be a ball joint issue or something else.. please help me,
TRUCK INFO
2005 Chevy Colorado, Regular cab , 2WD 3.5 L, the truck is lowered with a 4/5 canuck motorsports spring and blocks kit with DJM Cal-Max struts .. any help with either problem would be great ..
thanks in advance everyone !! :D
low05rado is offline
post #9 of 18 (permalink) Old 09-18-2010, 08:34 PM
I am not as alone as I thought after all,
SAME EXACT PROBLEM, I took it to the shop, I was ready to leave it and since they need to 'duplicate' the problem, I tried turning it on just for kicks and it worked. So I did not leave her that time.
Last night I was changing the oil and spark plugs, when I try reseting the OIL LIFE it does it again and I cannot get it to start.
If you don't want to pay for towing to the dealer or shop you could try this, with the key open and the vehicle on neutral go under the truck with a screw driver (if no screw driver is available be sure that it has an insulated grip otherwise it won't be pretty) make the two post on the starter touch not the two big ones but he big and small, you might need someone to pump the gas while you do this to just to get the vehicle running. This has worked for me about 6 times before so good luck. I still have to take it and see if it could be the Passlock crap.
IZRA
igarcia2009 is offline
post #10 of 18 (permalink) Old 10-06-2010, 02:23 PM
Send a message via Skype™ to sheman10
i also had this problem, but (at least for now) i was able to fix it. 05 cc ls z71 4x4 ~117k mi
in grocery store parking lot, truck wouldn't even try to turn over despite having all electronic systems go (hvac blower, lights, etc). displayed "reduced power." messed with battery leads, still wouldn't start. waited ~5 minutes, tried again, magically starts up, reduced power goes away but check engine light comes on.
short drive back to work where fortunately (being far from home) i have access to tools. removed nasty looking battery clamps from nasty looking terminals and with stiff wire brush filed away the large amount of rust and small amount of corrosion on clamps, nuts, terminals, etc as best i could. the negative clamp was so worn a g.d. metal chunk fell off! thoroughly blew off rust and corrosion dust and reconnected cables, although the metal piece that fell off resulted in the negative clamp being loose on the terminal... needs replacing of course. anyway, truck starts up fine and check engine light is gone!
in summary, check your battery terminals and cable clamps to make sure they're tight and not overly rusted/corroded. i suspect a dying battery could cause similar symptoms too though...
2005 Chevy Colorado LS CC Z71 4x4 3.5L I5
sheman10 is offline
post #11 of 18 (permalink) Old 12-24-2013, 12:29 PM
truck turns over won't start
the truck turns over (like its out of gas). will not fire. no engine light or code.
canadiansignguy is offline
post #12 of 18 (permalink) Old 12-24-2013, 01:01 PM
Is that supposed to be a question?
If so, it sounds like passlock, or the Canadian equivalent.
Search the topic, it's discussed here quite often.
Your symptoms should include cranking but not fire. Wait 10 minutes and it starts fine. Also the dash icon (truck with a padlock over it) is illuminated.
post #13 of 18 (permalink) Old 01-02-2015, 10:10 PM
took my 09 to the dealer today because of the same problem. they had no answer except maybe the starter switch but cant tell unless it happens while in their garage.
jdl2_2000 is offline
post #14 of 18 (permalink) Old 11-04-2015, 02:50 PM
same problem here it statered offf that my 06 colorado i5 wont start about 1 time every two months now its atleast 3 times a month geting tireed of it i changed the fuel pump cleaned maf sensor throttle body ... a still nothin i have to check the ignition relay now ..that looks like the main cause.
dax2ny is offline
post #15 of 18 (permalink) Old 02-01-2016, 02:17 PM
I have an 09 Colorado 4 cylinder that intermittently won't start,won't even crank. Just replaced the clutch safety position switch and still is intermittently not cranking. Had a new battery I just put in it not to long ago. Any ideas?
Sands78 is offline
post #16 of 18 (permalink) Old 02-01-2016, 06:07 PM
to C'Fans.
Other possibilities: defective starter, ignition switch, start relay or wiring. Try replacing the start relay or swapping it with another like relay in the fuse box.
Do you have anything "hot wired" to the ignition circuit, such as an aftermarket head unit?
post #17 of 18 (permalink) Old 10-31-2016, 06:18 PM
Same issue 2012 Chevy Colorado wont start but I can mess with the shift lever and then try it and it starts, thinking it may be the Neutral Safety Switch but cannot locate it , does anyone know where it is located.
bghwg.wilson96@gmail.com is offline
post #18 of 18 (permalink) Old 01-21-2017, 12:16 AM
Neutral safety switch is underneath your truck on the driver's side of your transmission. Pretty simple, I was able to replace mine in under 45 minutes. Make sure you disconnect the battery, place your vehicle in neutral and engage the parking brake. I'm not sure if that's the correct order or if the order even matters, so best bet check out some Youtube how-to's. Also, don't forget to chalk your wheels before getting underneath, and I would probably recommend putting it up on jack-stands cause it gets tight underneath.
Toughsox likes this.
No Cuts, No Buts, No Coconuts!
Last edited by pedalslipjohn; 01-21-2017 at 12:17 AM. Reason: Forgot some additional information.
pedalslipjohn is offline
