Installing/ Mounting tow ball on bumper - Chevy Colorado & GMC Canyon
post #1 of 10 (permalink) Old 01-14-2010, 03:47 PM Thread Starter
I want to put a 2 inch ball on my bumper to tow a small trailer. I see there is a little round Plastic cover where the ball is to be installed. My question is does anyone know how this comes off or do I have to cut it out or something? It's a 2wd sport model with the grey plastic trim on the bumper
droppeddime is offline
post #2 of 10 (permalink) Old 01-14-2010, 07:23 PM
Re: Installing/ Mounting tow ball on bumper
It does have to be cut, the shank is 3/4"x 2".
If your goint to tow much weight, suggest you get a hitch. I use my bumper for now but don't pull that much to often.
2004 Black 2wd Extended cab Colorado,
Dual headlight mod
K&N filter
North East Chevrolet Colorado & GMC Canyon Forum
http://www.nec355.net
jugfu is offline
post #3 of 10 (permalink) Old 01-14-2010, 10:24 PM Thread Starter
Thanks a lot for that. i am doing a 400-500 pound trailer with my snowmobile in it. The snowmobile is about 550lbs. So combined weight is about 1000-1100 pounds.
I think it should tow it fine off the bumper.
Thanks a tonne though for even knowing the shank and length. That makes it easy for me!
I just cut out the plastic part with a exact type knife. It took some effort but it worked.
Now I just need to get one of those T connectors for the wiring and I'm good to go.
post #4 of 10 (permalink) Old 01-14-2010, 10:37 PM
shouled be fine I towed a pop-up abouy 1800 lbs, with no issue. as long as you under the rating for the bumper should be good to go.
Dual headlight mod
K&N filter
jugfu is offline
post #5 of 10 (permalink) Old 01-15-2010, 02:31 AM
Yes it will work, however, I was going to go that route but decided against it when i realized that for a nominal amount of money i could put on a class 3 receiver and never have to worry about tearing the bumper off or banging it up denting it etc. The day will come when someone "slips" putting a trailer tongue in place . You will also find the need to carry a bigger trailer and regret not having gone with the hitch.
I have not regretted spending the extra 50-75 dollars for the hitch, plus it will allow for bike racks etc. much more versatile than the ball.
100,000 miles on 01/28/13
110,000 miles on 10/22/13
120.000 miles on 07/08/14
130,000 miles on 03/19/15
140,000 miles on 11/19/15
davn is offline
post #6 of 10 (permalink) Old 01-15-2010, 08:11 AM
i bought my hitch for 75 local. look around. the bumper should work fine but be careful when turning. i fed my bumper up on both sides from turning to tight
LIFTED TRUCK #244, back to stock height
2006 chevy colorado
4 cyl
2wd (1wd)
red
bedliner
toolbox
borla muffler stock pipe
gutted cat
china intake with k & n
aal in rear, also 2 inch block to get near stock height
SUSPENSION MAXX rear 1.5 inch shock extenders
SUSPENSION MAXX Front lift spacer now taken off for now
1 inch body lift, removed
now zq8's with 235/50/17
rear air shocks
bobandcar is offline
post #7 of 10 (permalink) Old 01-15-2010, 11:33 AM
On the sport version without the trailer wireing were do u get the power from?
2005 Crew Cab Zq8
10,000k hids in highs
10,000k hids in lows
10,000k hids in fogs
high low and fog kit
blacked out fog light housing
totally debadged
smoked led 3rd tail light
smoked led brake lights
Xtreme wheels
2" drop
low pro transmission crossmember
Brenphose is offline
post #8 of 10 (permalink) Old 01-15-2010, 01:34 PM
there is a connection near the rear axle on the left side of the bed, If you buy the correct harness you simply unplug the connection and add this harness, it can only fit one way, and your good to go, mine cost maybe 30 bucks or so, from e trailer, according to their site
http://www.etrailer.com/pc-VWH~118301.htm
this fits all models, the link also will lead you to n installation video,
davn is offline
post #9 of 10 (permalink) Old 01-15-2010, 02:19 PM
ok thanks i want to get the hitch that works with the rollpan and flip up license plate
2005 Crew Cab Zq8
totally debadged
Xtreme wheels
2" drop
post #10 of 10 (permalink) Old 01-15-2010, 07:42 PM
viewtopic.php?f=44&t=78989
2006 chevy colorado
4 cyl
2wd (1wd)
red
bedliner
toolbox
gutted cat
rear air shocks
