Applying Brakes affects turn signal indicator - Chevy Colorado & GMC Canyon
post #1 of 14 (permalink) Old 10-25-2010, 01:58 AM Thread Starter
This annoying issue has crept up in my 06 I-280 in the last couple of weeks. Whenever I hit the brakes the right hand indicator arrow on the cluster lights up a bit. I would say it lights up about 50% brightness as normal. Accompanied by this phantom illumination is a single turn signal "click" sound when the brakes are applied or released. It only illuminates right hand indicator, and I checked outside and when it is doing it the turn siginal itself is not affected.
If I am stopped waiting to turn right with the brakes pressed, the turn signal produces no noise at all and cycles between being half lit and fully lit. If i release the brakes is starts making noise again and drops the half lit stage but speeds up the blink rate dramatically.
One thing I did notice early on was that sometimes after using the right turn signal (or flipping it on/off a few times) the problem would cease to exist for a few seconds. It has since stopped doing that and this occurs 100% of the time. This made me suspect the turn signal switch. Anybody else have similar issues?
06 I-280 --
K&N fipk, Colorado grill, AR Baja 15x8 w/ Yoko 255/60/15
i-280 is offline
post #2 of 14 (permalink) Old 10-25-2010, 02:08 AM
CALI-BOSS
DBNissan's Avatar
Re: Applying Brakes affects turn signal indicator
Typically, when there are strange electrical gremlins like that, you will either have loose battery cables, a bad ground junction or a battery that is starting to go bad.
DBNissan is offline
post #3 of 14 (permalink) Old 10-25-2010, 06:56 PM Thread Starter
The oem battery died in august and was replaced. I did note the electrical components went absolutely bonkers when undervolted! Everything went back to normal after the new battery was installed. In the back of my mind I can't help but wonder if the stress put on the electricals during that period might of worn something out though.
Are the brake light/turn signal switches piggy backed into one system on these trucks? Everything else works flawlessly with no problems whatsoever. Any idea of where the grounds would be to check them out?
06 I-280 --
i-280 is offline
post #4 of 14 (permalink) Old 10-25-2010, 07:17 PM
CALI-BOSS
DBNissan's Avatar
The ground box is on the passenger side fender behind the intake filter box.
DBNissan is offline
post #5 of 14 (permalink) Old 10-26-2010, 01:24 AM
If you have a trailer wiring connector, look under the left side of the rear bumper and find the trailer adapter. Unplug it and plug the two cables removed from the adapter together. This sounds like a shorted diode in the trailer wiring adapter. If this is your problem, you can get a new one from your local autoparts store or off of ebay for about $30.00.
post #6 of 14 (permalink) Old 11-12-2010, 12:17 AM Thread Starter
You have hit the nail on the head n9cv. I disconnected the trailer brake adapter from the the back and the problem is solved. Thanks a bunch :)
got busy and just now got around to posting, but it has been fixed since halloween lol. thx again
06 I-280 --
i-280 is offline
post #7 of 14 (permalink) Old 11-12-2010, 04:34 AM
That is the thing with "Guessing" what is wrong over the Internet. Sometimes you are correct and sometimes you are way off base.
You can get another one of those adapters on Ebay, most trailer supply stores, and some of the Autoparts stores. They are around $30.00.
post #8 of 14 (permalink) Old 11-12-2010, 10:15 PM Thread Starter
honestly I haven't towed anything in a couple years now. I towed a couple atv's around after i first got the hitch and then sold the atv's. I'm probably going to wait and buy another if I need to tow again.
I wonder if it would be better to just keep the next one in the garage between tows. Hook up is a matter of seconds.
06 I-280 --
i-280 is offline
post #9 of 14 (permalink) Old 11-13-2010, 06:47 AM
I've never had problems with mine and it is out there is the weather, salt, and snow all the time. I do not think they go bad from being installed, but if you are not using it why not just buy one, throw it in the truck, and install it the next time you need it.
post #10 of 14 (permalink) Old 11-16-2011, 10:05 PM
I have an 05 Chevy Colorado Z71 LS Crew Cab with 75,000KM on it, and the other day I was also experiencing the same problem... I would apply my brakes and my left and right indicator on the dash would light up. You would also hear the 'click' sound when applying and releasing the brake. So I was reading up on the forums and came across your response about the trailer wiring harness... Took my truck to the wal-mart underground parking lot (it's cold here in Canada), and unpluged the trailer wiring harness (threw it in the garbage) and plugged the original junction box back together. PROBLEM SOLVED!!!!
I have been reading on this forums for over a year now, and I finally registered today because of the abundance of information everyone has provided, and the help you have provided in invaluable.
I just wanted to say thanks alot and I really appreciate your help n9cv.
mar18lam1 is offline
post #11 of 14 (permalink) Old 11-17-2011, 05:20 AM
I'm happy you fixed it. My previous response was a guess. Sometimes I'm right and many times I'm wrong. We have had several people report that those trailer adapters have failed. I found a bad one on a friend's Ranger a few months back.
I do not know where you are in Canada but I'm headed to Owen Sound, Ontario on Monday to pick up an engine, trans, and differential. Please keep your snow away for a couple of days until I return to the Chicago area. I have not installed my A/T tires yet for the winter season.
post #12 of 14 (permalink) Old 11-24-2011, 02:21 PM
lol... I live in Toronto, Ontario.... are winters are very mild in comparison to the rest of Canada.... It's going up to 13C or (55F) this weekend... I think Owen Sound already got snow, it's farther north-west, about 3 hours away from Toronto... Good luck, and thanks again...
post #13 of 14 (permalink) Old 11-25-2011, 03:47 AM
I'm back. Nice trip weather was all above freezing. It rained all evening on Tuesday with temps around +1 C all that way back to Sarnia. The Collie handled the 455 CU V8 with GM TM425 trans and final drive attached as one unit without a problem. I had to readjust the headlights down a bit, which only takes a minute. I figure the engine/power train weighed around 1200 pounds (550 Kilograms) with another 600 (275kg) or so with the two of us an all the junk a brought along with us.
That 80k 2 lane Ontario speed limit is a killer. On the 4 lane 402 with 100k it was a little better. With out of province (Indiana) plates I was afraid to exceed either of the limits by much.
post #14 of 14 (permalink) Old 03-23-2015, 02:13 PM
THANKS!! My truck just started making the turn signal noise when braking, weird. I have had trouble before with trailer lights, so will look into this solution.
Gretchen is offline
