How to: Permanently disable the passlock II system. - Page 2 - Chevy Colorado & GMC Canyon
 18Likes
post #21 of 291 (permalink) Old 09-09-2011, 11:31 PM
FUR
Did this a few months back and just added quick connects to secure the wire back together if my battery ever goes bad and it needs to relearn. Got a couple thousand starts with no issues.
Thanks goes to the OP!
FUR is offline
post #22 of 291 (permalink) Old 09-10-2011, 08:37 AM
Will there be problems if the battery goes bad? What has to relearn?
maxthepoke is offline
post #23 of 291 (permalink) Old 09-15-2011, 12:24 PM
techniques sexythree's Avatar
Been a week, before i did this i was haveing it happen 1 or 2 times a day... Since I did it not one time has my truck not started.. BIG THANKS
techniques sexythree is offline
post #24 of 291 (permalink) Old 09-19-2011, 11:32 PM
i want to do this....3 questions
1. does the factory remote door lock and unlock still work
2. do i have to do the relearn if i get a new battery?
3. how do i get the dash led off?
speedy ron is offline
post #25 of 291 (permalink) Old 09-23-2011, 11:33 PM
ColoradoPDC's Avatar
HI there,
same for me, apart that I live in Mexico and hard to trust garages here, even the dealership looks dodgy! The sales rep even told me, on-board computer don't get reprogrammed, you have to change it!!! WTF!! What the point of it being a 'computer'??
Got a 2004 Colorado LS 4x4 - not too sure of mileage.
Left for urgent trip abroad and left keys with a friend to keep it running but he didn't...
Anyways, had a new battery as other one died dry but car won't start now. Got the Passlock light on dashboard. Tried the 'start leave for 10' then off for 30 seconds' thing but no success.
Now, I had enough and dropped the car at dealership. Waiting for diagnostic.
Any help would be highly appreciated.
Cheers
Jason
ColoradoPDC is offline
post #26 of 291 (permalink) Old 09-29-2011, 10:24 AM
Couldn't you wire a switch to the blue/white wire?
97srad750 is offline
post #27 of 291 (permalink) Old 10-03-2011, 09:16 PM
Hey thanks for pointing out which wire.
I just did this. Can confirm the truck will still start with the door sensor disconnected. I put on some quick connects on the cut wire so I could reconnect it.
So it is clear, you need to cut the blue/white striped wire on the small wire bundle on the driver side. It is right next to a green/white striped wire.
When it is cut, the car won't warn you when your keys are in the ignition when you open the door to get out... so add a spare set of keys to the OP's list of things. =)
Lets see if it fixes my trucks problem...
Tmonster is offline
post #28 of 291 (permalink) Old 10-06-2011, 04:28 PM
Led mod
Does anyone know how to get the Led light off the dash once the wire has been cut?
justin96chevy is offline
post #29 of 291 (permalink) Old 10-07-2011, 09:27 AM Thread Starter
Send a message via AIM to noximus Send a message via Yahoo to noximus
Well I hope this is working for everyone, I still have not had any issues on the other two trucks I've done.
Justin96chevy, go the link below. It's a how to on how to change the LED color, but this will also show you how to remove the LED that indicator on your dash is using. Other wise you will need HPT, or EFI Live
How-to: Custom Gauge Lighting (LEDs) w/video
2006 Metallic Blue Colorado 7Z1: 3" SM keys, 2" rear shackels, 15% tinted windows, Kenwood KDC-X494 HU, Infinity Kappa 6.1 perfect all around. Infinity 475a amp, remote start/alarm.
2007 cobalt SS/SC: sold
2012 Raven R1 to many mods to list .
noximus is offline
post #30 of 291 (permalink) Old 10-07-2011, 09:29 AM Thread Starter
No, there will not be any issues if the battery dies, gets disconnected, or any other scenario you can throw at it about losing power.
noximus is offline
post #31 of 291 (permalink) Old 10-07-2011, 09:37 AM Thread Starter
ALSO- Wanted to note that I added the LED removal how to, to the original post.
Sorry I don't get on there much, there are a few members I don't like to deal with, so I hang out at the HPT, and LS1 forums more often than here.
noximus is offline
post #32 of 291 (permalink) Old 10-07-2011, 04:00 PM
I guess the led light being on isnt going to burn out my cluster or anything its just going to be annoying?
post #33 of 291 (permalink) Old 10-08-2011, 11:52 AM Thread Starter
Correct, it wont hurt anything.
noximus is offline
post #34 of 291 (permalink) Old 10-09-2011, 03:08 PM
New to the forum here and it seems a lot of people have the same intermittent passlock problem that I am having. I was just wondering:
Instead of disabling the passlock feature altogether, could I install a battery disconnect switch on the negative terminal? That way the passlock will still work to prevent theft, and when it randomly acts up all I have to do is pop the hood, turn my disconnect off and then back on, and then I'd be good to go?
Thanks!
2007Colorado is offline
post #35 of 291 (permalink) Old 10-11-2011, 09:55 AM Thread Starter
Disconnecting the battery does not reset the ignition lockout. You'd still be playing the 15 min waiting game, and hoping that it doesn't trip again, once you're able to try to crank it over again.
Thanks!
noximus is offline
post #36 of 291 (permalink) Old 10-13-2011, 12:16 PM
krisperez's Avatar
Thank you noximus!
I did the job this morning. Got stranded last night at a Drive thru window... embarressing!!!
I really dont mind the light staying on.
Any quick mods to fixing the drivers side window problem???
krisperez is offline
post #37 of 291 (permalink) Old 10-17-2011, 12:47 PM
Thanks noximus. The fix was quick, easy and the best part......it works!!!
post #38 of 291 (permalink) Old 10-17-2011, 04:34 PM Thread Starter
No problem guys! What issues are you having with the window? I'll take a look at the wiring diagram to try to figure it out.
noximus is offline
post #39 of 291 (permalink) Old 10-19-2011, 02:03 AM
Luke174's Avatar
Just did this to mine.
Works like a charm. Thanks a lot!!
Luke174 is offline
post #40 of 291 (permalink) Old 10-19-2011, 12:30 PM
I have a 2012 coming next month. Is this Pass Lock still a problem?
sherwoodphil is offline
