Error Code:P0506, Low Idle - Chevy Colorado & GMC Canyon
post #1 of 4 (permalink) Old 12-11-2010, 11:37 AM Thread Starter
How do you correct this problem, the truck is a 2004 Colorado, Z71 4 x 4, ex cab, 109,800 miles.
In cold weather after start up it goes really low in the rpms at idle, does anyone know how to fix this?
Thanks.
Hunter is offline
post #2 of 4 (permalink) Old 12-11-2010, 12:23 PM
Swattie87's Avatar
Re: Error Code:P0506, Low Idle
Could be a dirty throttle body, if it hasn't been cleaned recently. It seems like a lot of times that issue first shows itself as a low idle in colder temperatures.
Check out these threads...if you do a search I'm sure there's more out there too.
viewtopic.php?f=1&t=84834
viewtopic.php?f=8&t=54407
A dirty throttle body is the first thing I would look to rule out anyway. After the truck gets some miles on it, it probably needs to be cleaned once a year or so. I did mine last December (Just the TB clean, not the Seafoam) and no PO506 code since...debating on whether to do it preemptively this year, or wait and see if the idle starts to drop and it throws the code. Hope that helps.
Edit:
I have a 2007 Ford Focus that gets fussy with it's throttle body in the cold too. My inlaws have a Prius that needs it's throttle body cleaned periodically too...I've basically come to the conclusion that this is just a regular maintenance item on modern engines.
2005 Colorado Z71 4x4 Ext. Cab - 3.5 I5 - 5 Speed - 4.10
Truxport Truxedo Tonneau, Rhino Liner
Swattie87 is offline
post #3 of 4 (permalink) Old 12-12-2010, 03:48 PM Thread Starter
Thankyou for the tip, I have never cleaned it, will do it shortly, thanks.
Hunter is offline
post #4 of 4 (permalink) Old 12-12-2010, 04:34 PM
fredss's Avatar
Mine was doing the same thing, I have over 100k on my truck as well. I did the throttle body cleaning yesterday, and she is idling like glass now right at about 700 - 750 rpms. Starts up real strong now too. Its super easy, and totally fixes this issue.
fredss is offline
