P0301 Cylinder 1 misfire - Chevy Colorado & GMC Canyon
post #1 of 16 (permalink) Old 01-09-2011, 01:06 PM Thread Starter
reelindoormats's Avatar
Ok. so my truck is only throwing the code for cylinder one and i cant figure out why. all new plugs and the coils are seated properly. im not noticing any rough idles or anything of the sort but it seems to be robbing MPG's. I've kinda hit a wall on this one. Does anyone have any suggestions or similar experience?
2004 Z71 Canyon SLE
3" shackles, TB crank, Diff drop, BJ flip, K&N CAI, air raid TBS, MBRP catback, BULLMAXX3, TAG multicarrier bumper, tire gate PR, 2 7" HID lights,2 4" HID lights, PCMforless, Scanguage II, 31x10.5 dick cepek mountaincats on 15x8 Ultra 50 wheels, GS racing seats.
reelindoormats is offline
post #2 of 16 (permalink) Old 01-09-2011, 11:50 PM
Re: P0301 Cylinder 1 misfire
There have been many comments that Cyc. 1 is the easiest to misseat the coil pack on. It maybe worth another look see. Maybe swap #1 and #2 coils over see if it moves the miss to # 2. Good luck
Green "05 canyon ext cab, 3.5 auto, 2wd, belltech 2/2 drop , fake lake pipes, overhead console, scangauge, ARE tonnue cover, brushed pinstrips, de badged, helwig sway bars, H3 wheels.
bondo dust is offline
post #3 of 16 (permalink) Old 01-15-2011, 01:33 PM Thread Starter
I didn't know you could just swap coil packs. It's worth a try. If the misfire does switch to cyl 2 would that mean I have a bad coil pack?
2004 Z71 Canyon SLE
post #4 of 16 (permalink) Old 01-23-2011, 03:49 PM Thread Starter
ok. so i swapped out the coils and its still throwing the code for cylinder one. where does that leave me. any help would be awesome
2004 Z71 Canyon SLE
post #5 of 16 (permalink) Old 01-23-2011, 05:07 PM
that leaves you at probably the head issue get a leakdown test done and its covered to 100k miles by GM theres a TSB on it.
puddleman is offline
post #6 of 16 (permalink) Old 01-25-2011, 09:27 PM Thread Starter
ok sorry im gonna need that in simple english lol. what exactly is a leakdown test? and what does TSB mean?
Also, the truck appears to be running fine beside throwing the code.. could this be some sensor i dont know about?
2004 Z71 Canyon SLE
post #7 of 16 (permalink) Old 02-05-2011, 06:37 PM Thread Starter
ok i did some recon and found the TSB. if this turns out to be my problem, does anyone know how much it will run me to get fixed?
2004 Z71 Canyon SLE
post #8 of 16 (permalink) Old 02-22-2011, 03:22 PM
What did you find out ? cylider 3 misfire . thinking leak down test . did you get yours fixed ? how much ? mine 147000miles out of warranty :(
vinper is offline
post #9 of 16 (permalink) Old 02-23-2011, 12:37 AM
I mine had a miss fire code, and was idling rough too. There is a service bulliten about the spings on the exhaust valve springs and it is covered to a 100,000 miles, bad thing was my truck had 130,000, it is a 2005. But don't let a dealer sell you a head to fix it, get a valve job done got 135. The deler charged me over 1800 dollars to take it apart and putnit back together, and when they could not fix it, they said it was an exhaust valve leaking, but i told them i wanted the head and had it fixed myself, itr was a intake valve sticking open.
Steve460 is offline
post #10 of 16 (permalink) Old 02-23-2011, 01:31 PM
my shop said 2 to 2400$ to repair ,includes sending head to machine shop to be rebuilt 550$rebuild head 1000$ labor 500$ materials
vinper is offline
post #11 of 16 (permalink) Old 02-23-2011, 04:04 PM
Did you swap the boots that are in between the coil and the plug as well?
05 Z71 I4 Rado /w 4:10 gearing
garyc660r is offline
post #12 of 16 (permalink) Old 03-08-2011, 09:48 PM Thread Starter
i didnt swap the boot. didnt see a reason to. they looked brand new. should i?
2004 Z71 Canyon SLE
post #13 of 16 (permalink) Old 03-09-2011, 09:30 AM
There is a spiral wire inside the boot(s) that connect the coil pack to the spark plug. On an 04 model truck deterioration could be an issue for sure. Besides that I would look at a possible injector issue on 1 cylinder and look into a compression / leak down test.
post #14 of 16 (permalink) Old 03-23-2011, 09:47 PM Thread Starter
i'll check that out, thanks for the tips. highly appreciated
2004 Z71 Canyon SLE
post #15 of 16 (permalink) Old 01-22-2015, 10:45 AM
Hi I am now having this P0301 problem. Have done the leakdown test and all that. The dealer is saying that the cylinder heads need to be redone due to soft valve seals (???) Total cost could be up to $3500. Truck runs fine otherwise. My problem is I can't get a smog test done due to the check engine light on. Am I screwed here? Is there anyway to get around this to get my smog done? mileage is at 104k so of course I am out of warranty on the TSB.
zerpda is offline
post #16 of 16 (permalink) Old 01-22-2015, 12:19 PM
to C'Fans.
I don't think that there is a way to get the "check engine" light to go away, for this issue. The only thing I can suggest, if you haven't already done so, is replace the plugs and swap the coils, as mentioned earlier in this Thread. Just in case the Dealer's diagnosis is not correct. Other than that, good luck. You might be able to get the head replaced for less at an independent shop. Usually, with the "defective head" problem, an engine will set other DTCs and run a bit rough.
The Service Manual also states:A misfire DTC could be caused by an excessive vibration from sources other than the engine. Inspect for the following possible sources:
-A tire or wheel that is out of round or out of balance.
-Variable thickness brake rotors.
-An unbalanced drive shaft.
-Certain rough road conditions.
-A damaged accessory drive component or belt.
-A damaged reluctor wheel.
Obviously most, or none, of those would apply to your case. It is just to show you that, unless you really trust the Dealer, it doesn't hurt to check other possible causes.
