AC blower motor problems - Chevy Colorado & GMC Canyon
Old 08-27-2011, 06:24 PM   #1 (permalink)
Default AC blower motor problems
I have an 04 Colorado ZQ8 crew cab that I recently replaced the blower motor in and it just quit working. The harness looks good, I just replaced the resistor and had no burned parts of the connector so I believe that is still in working order. I made some jumper wires and was able to run the blower motor straight off the battery so it works. One thing I find peculiar is that when I check for voltage at the connector for the blower motor it comes in as reverse polarity. If I switch the DDM leads and put the black one with the red wire and the red wire with the black one the multimeter reads right. Would this be caused by a faulty ground, Out here in phoenix it is very hot so any help would be deeply appreciated.
I followed the thread quite a bit and used that as a basis of trouble shooting but am at a loss right now.
daemontrym is offline   Reply With Quote
Old 08-27-2011, 07:53 PM   #2 (permalink)
Send a message via AIM to xkmacx86 Send a message via Yahoo to xkmacx86
Default
did you check the ground point next to the intake airbox
xkmacx86 is offline   Reply With Quote
Old 08-27-2011, 08:21 PM   #3 (permalink)
Default
No I haven't are you talking about under the dash or next to the air filter box under the hood?
Old 08-27-2011, 08:25 PM   #4 (permalink)
Default
Old 08-28-2011, 01:06 PM   #5 (permalink)
Default
That was the problem! First time I have ever seen a bad ground cause something like that. I think its kind of dumb to have so many wires grounded to such a small point that they painted over too. I filed off some of the paint around the hole, cleaned everything up with contact cleaner, and reassembled.
Old 06-29-2012, 01:23 AM   #6 (permalink)
Default
I to had the same problem. Went through the same diagnostics and was unable to find the problem until now. THANKS! I had to do one extra step I isolated the pin that was going to the blower and bent it to make contact with the connector. The dumb aluminum connectors they use corrode and quit making contact. Cleaning the corrosion made the gap bigger.
too-onebee is offline   Reply With Quote
Old 06-29-2012, 03:23 AM   #7 (permalink)
Default
Is this a pin in the Blower Motor Connector that failed?
n9cv is offline   Reply With Quote
Old 07-01-2012, 05:28 PM   #8 (permalink)
Default
is this ground a plug type unit between the air box and fender?
BHmike is offline   Reply With Quote
Old 07-01-2012, 06:59 PM   #9 (permalink)
Default
thanks guys, the ground was definately bad, it's fixed and it works
You may not post new threads
You may not post replies
