05 Colorado Drivers side window problem - Chevy Colorado & GMC Canyon
post #1 of 4 (permalink) Old 02-24-2012, 05:43 PM Thread Starter
I was reading a bunch of these posts about the drivers side window switch having problems. My window will initially go down but will not go back up. Sometimes if I pull up on the window and hit the switch at the same time it will go up. The other times I hit the bottom side of the door and it will go up. I do not have any issues with the power locks or the other window. Does anyone think the switch could cause just the window to act up and if not has anyone had to install the window regulator?
justin96chevy is offline
post #2 of 4 (permalink) Old 02-24-2012, 06:04 PM
motor is is gone had both replaced on my 04 this year. same symptoms as yours seems to be a common problem as they get older
04 Colorado crew 2wd
Michelin ltx2
Advance folding cover
login is offline
post #3 of 4 (permalink) Old 02-25-2012, 01:52 PM
RobertR's Avatar
sounds like motor to me as well, haven't had issues on my Colorado but other older cars had this. For a long time I felt manual windows were better because of how common the problem was in aging vehicles.
RobertR is offline
post #4 of 4 (permalink) Old 02-25-2012, 10:31 PM
JBlu1354's Avatar
Just had a new motor put on mine Tuesday, I was having to push mine down but once I got it down had to hit it hard to come back up.
JBlu1354 is offline
