LinkBack | Thread Tools |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
friend I have the same problem as you,,, light 4WD message service on the board and 4x4 buttons are inoperative, all this happened since then that I made injector cleaning, ... now I work my 4x4.
someone help me please,, help achievement you fix this? help me and tell me how you did to fix it? Deshacer cambios |
#4 (permalink) |
I have a similar problem, it feels like im driving down a rumble strip until i shift into 4x4. I cant tell which side its coming from. I've been told cv shaft, wheel bearing, u joints or ball joints. i replaced a bad cv but no help. I checked the u joints and replaced the front one as it was worn badly. I'm in the process of replacing ball joints (which are slightly worn) but i have no faith in that fixing the problem. The wheel bearings both seem fine. Im at a loss here.
P.S. My truck has almost 100,000 miles on it and it started doing it 5000 miles ago. it only seems to do it at 60mph or above. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
