LinkBack | Thread Tools |
#1 (permalink) |
Ok, I just got this truck and here we are
Im driving along, each time I hit the brakes the pedal gets tighter and tighter until the pedle is rock solid. At this point im pulled over because it feels like im driving with my brakes on PLEASE HELP anybody have some insight!?!?!?!?!?!?!?!? by the way, after waiting a while the brakes release and everything seems ok until of course I drive again for a short distance... THANKS IN ADVANCE
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Is the parking brake applied? If definitely sound as if the shoes are hanging up. It could be a bad adjuster at one of the rear wheels. I don't know if they can be installed in reverse and tighten too much but it seems like something is making them hang up.
Have you been able to isolate it from the front or the back? If it's the front, it's the caliper hanging up. You might want to try removing the drums and take a look at the system. The drum won't just lip off, especially if it's tight. You'll have to back it off using the adjuster. If you don't know how to do that, either look it up online or take it to a shop. I'm not sure how to explain it. I am going to assume that no work has been done recently? |
#3 (permalink) |
Sounds like a possible probley with one of the following:Brake booster,Brake booster check valve,Brake pedel pushrod,Vacuum supply issues,Vacuum leaks.
07 Chevy Colorado Crew cab Z71 4x4 3.7L I5 |
#4 (permalink) |
The stealership is telling me there is a valve in the master cylinder hanging up.... They want $680!!!! LOL I will pick up a referbished master cylinder from the parts store in the morning for $70! Hope they are right, definately makes sence. Thanks guys.
#5 (permalink) |
can you keep us posted on the master cylinder swap? This sounds more like BlueBandit stated brake booster issue not a master cylinder issue. Of course these trucks are unique in some ways, good luck.
GregDAP called my truck a "Pavement Princess" once.............. ONCE! LOL
#6 (permalink) |
Yeah, I will update when I get the master cylinder installed... I keep hearing all kinds of different things... I have had a couple people bring up the booster thought. So i'll start with the master cylinder, and hope for the best. If thats not it looks like i'll be researching the booster further...
#7 (permalink) | |
#8 (permalink) |
Make sure you bench bleed the master cylinder per the instructions. I know master cylinder seals fail and the pedal goes to the floor but I've never head of it in how you described it. Not saying it's not that, just saying I've never head that before.
Good luck! |
#9 (permalink) | |
From your other post it sounds like the stealer is replacing the entire booster/master not just the master after the booster so it could be that you will need a new booster or at least one with a good diaphragm piston return assembly. It has been a few years but even today power breaks are not that complicated and at one time you could even rebuild boosters yourself.... I do not know what the rebuild kit situation is for newer GMCs brake systems now a days, but you would think that essential components that are as simple as a power break system would be easily rebuilt!
"if it aint broke ..just let me have a crack at it" |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
