2009 colorado cold day electrical issues? - Chevy Colorado & GMC Canyon
post #1 of 2 (permalink) Old 01-10-2017, 09:58 AM Thread Starter
hello all, new guy here.
Its been real cold here lately, around zero to twenties,
i started truck the other morning and suddenly had
abs light, parking brake light, lost my directionals, windheild wipers, and heater fan all at once.
I did not get a check engine light.
i turned off the ignition, removed key, and then restarted and all went away for awhile.
About 5 minutes later while driving, it happened again, same exact thing.
it has happened two more times since, while on the highway about 1 hour after the second time.
Pulling over, removing key, restarting fixes it.
Any ideas? and sorry if this has hopefully been covered i tried searching but came up blank
Thanks in advance
ps, havent done any work lately except months ago fixing my p0442, but nothing recently but cold and snow
woodman is offline
post #2 of 2 (permalink) Old 01-11-2017, 02:01 AM
Thanks in advance
hmmm, if it does it again try moving the key a little toward start and off. Just a tiny bit like a jiggle. If the blower comes back to life then I'm going with ignition switch. This is only a guess of course. Good luck and let us know what you find.
JScottM is offline
