TIP: Changing Remote Door Lock Indicators (RFA Modes) - Chevy Colorado & GMC Canyon
post #1 of 67 (permalink) Old 12-29-2003, 07:29 PM Thread Starter
Send a message via AIM to koolz71
Remote Feedback Modes
Won't help much to :rtfm , but on Page 2-6 of The owners Manual it is mentioned.
I did some major work over at the dealership and after the DIC not wanting to accept the changes to make the horn chirp when locking the doors using the remote keyless entry, here is what we found out you do.
Automatic Door locks
1. With the vehicles engine off, and the ignition in the LOCK position. (You possibly also need the doors locked.)
2. Press and hold the lock and unlock buttons on the remote keyless entry transmitter at the same time until the DIC displays the current remote feedback mode (RFA1 is default from factory).
3. Then press and hold the odometer reset stem for approximately two seconds to switch between modes.
RFA 1 - DIC display. (Default)
The parking lights will flash when you press the lock and unlock buttons on the remote keyless entry transmitter.
RFA 2 - DIC display.
The parking lights will flash when you press the lock and unlock buttons on the remote keyless entry transmitter and the horn will chirp when the lock button is pressed.
RFA 3 - DIC display.
The parking lights will flash and the horn will chirp when you press the lock and unlock buttons on the transmitter.
RFA 4 - DIC display.
There is no feedback when you press the lock and unlock buttons on the remote keyless entry transmitter. This means no flashing lights or horn chip at all when locking vehicle.
4. Once your selection is made, press the trip odometer reset stem QUICKLY ! The DIC should go blank at this point.
This is the part they don't tell you and that we found out by ourselves. We are 95% sure, this is the only way we could have the computer save the setting. 2 members have made it work this way.
I hope this info serves a good porpose and is well appreciated.
koolz71 is offline
post #2 of 67 (permalink) Old 12-30-2003, 03:53 PM
So is the save option pressing the trip reset button momentarily for sure now?
Ken Deatrick
1957 BELAIR 4 DOOR HARD TOP
My CarDomain Gallery
kdeatrick is offline
post #3 of 67 (permalink) Old 12-30-2003, 06:03 PM Thread Starter
well im not for sure..the dealers online guide tells how to do it all but how to save it..the service guy and me spent an hour figuring out how to get it to save with no avail..then he hit the reset stem quickly after i made my selection, the DIC whent black..pulled the key, shut the door, and it worked..so thats the only thing i could think of that did it..y is it now working for u?
koolz71 is offline
post #4 of 67 (permalink) Old 12-30-2003, 06:14 PM
hkick, did that work for you to save it?
Ken Deatrick
post #5 of 67 (permalink) Old 12-30-2003, 08:34 PM
Got it !!! I hit the stem quickly
2004 Black Colorado Z-71 Crew Cab
LS Trim / Black
Vortec 3500 220 HP I5 Engine
Chrome Step Sides
Traililering Equipment
Line-X BedLiner
hkick is offline
post #6 of 67 (permalink) Old 12-30-2003, 09:14 PM
Okay, so a "QUICK MOMENTARY" press of the trip reset switch.
Ken Deatrick
post #7 of 67 (permalink) Old 01-02-2004, 09:18 PM
It worked!. The only thing that needs to be added to the instructions is that you need to have the doors in the locked position before you start the process. I tried it with them unlocked and nothing happened. But thanks for the info. I never would have figured it out without those instructions. But one other question: does anyone else have a horn volume that is noticeably low? I have never heard a horn that sounds so muted? Am I the only one experiencing this?
mjones12 is offline
post #8 of 67 (permalink) Old 01-12-2004, 11:00 PM
The RFA switch worked. Thanks a lot. I didn't find this in the manual, and now I know why.
'04 GMC CC 4WD Z71 (Black)
-I5, Leather, XM, Sirius, PIONEER Premier AVIC-F90BT, K&N FIPK, BedRug, 15% Tint
~88000 miles
Conservative Club Member #26.
SuperH is offline
post #9 of 67 (permalink) Old 02-26-2004, 09:47 AM
I know this is an old post, but I just came across it and wanted to say Thanks.
Good post and quite helpful. (So was the post on the automatic dorr lock codes!)
-Steve
extremerider is offline
post #10 of 67 (permalink) Old 05-03-2004, 09:49 PM
Send a message via MSN to Southpaw Send a message via Yahoo to Southpaw
Great Thread! Worked perfectly....now if I could figure out how to get all the doors unlocked at one press of a button.
2004 colorado crew cab, z71, dark cherry red, deluxe bucket, sliding rear window
Aftermarket: hood protector, inchannel window vents, chrome step bars, Colorado soft tonneau cover
My Gallery
Southpaw is offline
post #11 of 67 (permalink) Old 05-19-2004, 12:14 AM
That is covered in one the "bulletins" thread I typed in a while back. It is a mistake in the printing of the owners manual.
Colorado Z71 crew cab
love this truck.
G.M. tech since 1991
My Gallery
2004t1colorado is offline
post #12 of 67 (permalink) Old 05-20-2004, 10:03 PM
2004t1colorado.......I did a search of all your threads and couldn't find it. If you do, let me know the date/time so I can refer to it. I've re-read the manual and can not find any place where it tells u how to open up all the doors with one push of a button.
On a side note, how do u like your soft Colorado tonneau? Does yours fit square?
My Gallery
Southpaw is offline
post #13 of 67 (permalink) Old 05-20-2004, 10:32 PM
I don't think you can unlock them all with 1 push.
Ken Deatrick
post #14 of 67 (permalink) Old 10-26-2004, 02:56 PM
tried it, and it does work, and you can also program the automatic lock of your truck with 4 different settings, as of page 3-39
FunP0rn is offline
post #15 of 67 (permalink) Old 11-18-2004, 11:29 PM
Send a message via AIM to CanyonRyan
Thanks! I too tried to find this in the "Manual", now I'll I want to do is set up perimeter lighting, change the color on my DIC, and find the setting that changes my I4 to an I5!
ext cab Canyon SLE Silver
I4 5-speed Manual
Flowmaster Exhaust Chrome tip
Wolfliner Spray-on bedliner
Infinty Kappa Perfect 6.1
Alpine 12" Type R in Custom Box
My Gallery
CanyonRyan is offline
post #16 of 67 (permalink) Old 11-19-2004, 07:28 AM
I think it's a personal safety sort of thing. In a parking lot, a person is safer opening only the driver's door with one click and not all of the doors because a criminal could rush inside the vehicle from the other side.
Fitz
Keep The Open Road Open - Ship By Rail
Fitz Ingarage is offline
post #17 of 67 (permalink) Old 12-26-2004, 04:07 AM
Originally Posted by 2005 Owner Manual Pg. 3-38
Remote Keyless Entry Feedback
This feature allows you to program your remote keyless entry feedback to a preferred setting.
To set your choice for this feature, perform the
following steps:
1. With the engine off, turn the key to LOCK.
2. Press and hold the lock and unlock buttons on the remote keyless entry transmitter at the same time.
Hold both buttons until the DIC display shows
the current remote keyless entry feedback mode.
3. To view the next available mode, press and hold the reset stem for approximately two seconds.
Release the reset stem and press and hold again to
view each mode.
4. Once the desired mode is shown on the DIC
display, briefly press the reset stem to set your
choice. The DIC display will then clear.
The following are the available modes:
RFA 1 (default):
This mode flashes the parking lamps when you press the lock or unlock buttons on the remote keyless entry transmitter.
RFA 2:
This mode flashes the parking lamps and sounds the horn when you press the lock button on the remote keyless entry transmitter. This mode also flashes the parking lamps when you press the unlock button on the remote keyless entry transmitter.
RFA 3:
This mode flashes the parking lamps and sounds the horn when you press the lock or unlock buttons on the remote keyless entry transmitter.
RFA 4:
This mode disables remote keyless entry feedback. There will be no feedback when you press the lock or unlock buttons on the remote keyless entry transmitter.
3-38
Ken Deatrick
post #18 of 67 (permalink) Old 01-03-2005, 04:25 PM
BahamaTodd's Avatar
w00t!
2004 GMC Canyon SLE Ext Cab Z71 4x4
Site Rules
BahamaTodd is offline
post #19 of 67 (permalink) Old 01-10-2005, 09:56 PM
Thanks for the post, this is EXACTLY what I was looking for!
B.
cottonakin is offline
post #20 of 67 (permalink) Old 02-03-2005, 11:03 AM
Sorry to bring up and old post but the 05 owners manual says to leave the door OPEN nothing about locked or unlocked. I followed the instructions and sucessfully changed mine. One other thing the quick press is also in there.
05 Canyon SLE Z85 4x4. 1989 Pontiac Formula 350, and 1990 Pontiac 6000 LE.
My Gallery
dcjredline is offline
