Index of Issues - CHECK HERE FIRST - Chevy Colorado & GMC Canyon
post #1 of 1 (permalink) Old 09-23-2004, 06:10 PM Thread Starter
I plan to use this thread as an index and will update it when I can, or when needed.
Campaigns & Recalls
System Software Upgrade-Fuel Level Sender On Board Diagnostic (Reprogram Powertrain Control Module (PCM)) #04081 - (Oct 18, 2004)
04-05 Valve Seat wear issues (including scans of the letters from GM)
Advanced Service Information
Noise and Bump/Clunk Felt When Transfer Case Shifted Into Four Low (4LO) (Engineering Is Currently Working on Fix, No Repair Available at This Time) #04-04-21-002 - Jun. 3, 2004
Information on Pickup Box Reinforcements to Accomodate Aftermarket Accessory Tool Box - TSB #04-08-66-019 - Dec. 13, 2004
Advance Service Information Resolution
Whistle/Hiss/Hum/Ring Noise Heard When A/C is On (Install Evaporator Core Service Kit) - TSB #41-01-38-012A - Nov. 9, 2004
Technical
Incorrect Transmission Shifts, Poor Engine Performance, Harsh 1-2 Upshifts, Slips 1ST and Reverse, Torque Converter Clutch (TCC) Stuck Off/On, DTC P0730, P0756, P0757, P0741, P0742 #02-07-30-013C - Jan. 3, 2005 (This does not appear to actually apply to the Colorado as they have the 4L60 Transmission.)
Popping/Snapping Noise When Vehicle is Hot, at Idle or Immediately after Vehicle is Shut Off (Replace Muffler Heat Shield) #04-06-05-005A - Dec. 16, 2004
Engine Misfire, P0300 (Replace Exhaust Valve Springs and Seals) #04-06-04-081A - Nov. 12, 2004
Other Related Thread
Underhood Whine or Rattle Type Noise (Replace Tensioner) #04-06-01-016A - Nov. 9, 2004
Other related thread.
Battery Message Displayed in Drivers Information Center (Recalibrate Instrument Panel Cluster) #04-08-49-013 - Apr. 22, 2004
Revisions to index not done yet below.
Issue: Digital Clock Loosing time - PI02060
Issue: Vibration at Idle, Rough Idle 600 RPM - PIP3112
Issue: Erratic Flare idle - PI02021
Issue: Erratic Flare idle, thread 2 - PI02021
Issue: Black ring around exhaust tip - PI02106
Issue: Thump when carrying passengers - PI01942A
Issue: Noise, loud bump, thump, thread 2 - PI01942A
Issue: A/C Noise, Flutter - PIT3019A
Issue: PCM pin fit issue - PIP3008
Issue: Water Leak - PI01943
Issue: Water Leak, thread 2 - PI01943
Issue: Water Leak - PI01914
Issue: Wheel tire balance rough shake wobble - PIT3107A
Issue: No Crank, No Start - PIT3113
Issue: Heat Shield Rattle - PIP3147 & PIP3195
Ken Deatrick
1957 BELAIR 4 DOOR HARD TOP
My CarDomain Gallery
kdeatrick is offline
Closed Thread
