LinkBack | Thread Tools |
#1 (permalink) |
Document ID# 1563438
2004 Chevrolet Colorado Pickup -------------------------------------------------------------------------------- Underhood Whine or Rattle Type Noise (Replace Tensioner) #04-06-01-016A - (Nov 9, 2004) 2004 Chevrolet Colorado 2004 GMC Canyon with 3.5L L5 Engine (VIN 6 - RPO L52) Built Prior To VIN Breakpoints 48123220 (Chevrolet) and 48123225 (GMC) This bulletin is being updated to clarify the Correction and Parts Information. Please discard Corporate Bulletin Number 04-06-01-016 (Section 06 - Engine/Propulsion System). Condition Some customers may comment on a whine type noise and/or a possible rattle noise on light acceleration coming from the engine. This noise may seem more pronounced at start up after an overnight soak. Cause The source of the noise may be the balance shaft chain and the tensioner interaction. There are 2 balance shafts in this engine that are driven by the crankshaft to keep the engine running smoothly. This noise does vary from vehicle to vehicle and does not cause any durability concerns; however, some customers may find it objectionable. Correction A new tensioner has been designed to eliminate this noise. The kit consists of an oil fed tensioner, longer tensioner bolts, balance shaft drive chain and right side balance shaft assembly. Please note that it is necessary to install the updated balance shaft assembly because it contains an oil feed passage for the oil fed tensioner. This new tensioner was introduced into production in the mid December time frame. If you have a vehicle built prior to VIN breakpoints 48123220 (Chevrolet) and 48123225 (GMC), install a new tensioner, P/N 89017543. Follow the removal and installation instructions in SI for the Balance Shaft Chain Tensioner Replacement in the Engine Mechanical section. You will also need to order and install a new rear oil seal, P/N 12568124. Parts Information Part Number - Description - Qty 89017543 - Tensioner Kit, Hydraulic - 1 12568124 - Seal, Crankshaft Rear Oil - 1 Parts are currently available from GMSPO. Warranty Information For vehicles repaired under warranty, use: Labor Operation - Description - Labor Time J0787 - Tensioner And/Or Shoe, Timing Chain - Replace - Use Published Labor Operation Time
Ken Deatrick CT15653 - 2004 COLORADO 4WD LS EXT CAB Z85 My CarDomain Gallery Mods: Silver GM Hood Protector, Silver GM Small Flares, Factory Style Fog Lamps added Rhino Liner, Fold-A-Cover, Carriage Works Billet Grille, Silverstar Bulbs |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
hey kdeatrick, I have been having trouble getting my dealer to fix this both times over the summer they said it was nothing. Is this the actual buliten number the dealer would use?
Conservative Club Member #12 |
#3 (permalink) |
yes, it is from GM eSi.
#5 (permalink) |
Interesting. I still would hesitate to associate this with the chirping sound I experienced before replacing the serpantine belt. When I say "chirp," think the Nextel sound, but rythmically repeated.
Thanks Kdeatrick!
I am the Voice Over the Wall and I approved this message. http://www.voiceoverthewall.com/ 2004 Colorado Z71 ... Gibson Side Swept Exhaust ... Bridgestone Dueler AT REVOs ... TruckHyde Tonneau Cover ... Superman Hitch Cover ... AVS In-channel VentVisors ... aFe Pro Dry S Performance Air Filter ... GM Accessories High Bug Shield, Rail Caps, and Bedliner ... Proudly displaying a 20 inch ColoradoFans.com decal since 2004 |
#7 (permalink) |
Poker, correct, you would need a number lower than the one stated.
God Grant me the serenity to accept the things I can not change, the courage to change the things I can, and the wisdom to know the difference. www.krissplicing.com |
#8 (permalink) |
my engine has a bit of a whine/loud hum on startup on occasion, not sure bout my vin number atm tho...its 12:20 am n' i dont wanna go out n' look
![]() 06 EC WT 2.8L I4 3.73 Tint Sony CDX-GT300 HU BAJA foglamps Deezee toolbox Hunter Grillgaurd (now removed) GM bedmat Billet Grill overlay Z71 rims w/ BFG 31x10.5 All Terrains Pioneer TS-G671M speakers Silverado Overhead console My Cardomain |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
