engine squeal - Chevy Colorado & GMC Canyon
post #1 of 24 (permalink) Old 07-07-2005, 11:28 AM Thread Starter
engine squeal
Lately my truck will sometimes make a horrible squealing noise when I first crank it up in the morning. Sounds kind of like a bad belt tensioner or something. It ONLY happens after the truck sits overnight though, it won't do it again the rest of the day.
So I finally went to the dealership with it, and of course the truck didn't make the noise for them, after leaving it there for 2 days in a row so they could try cold cranking it in the morning. It will undoubtedly do it tommorrow morning after I go pick it up tonight.
Anyone else had this noise? It's not a 'whine' or 'rattle' like has been discussed here before. It sounds exactly like a squealing belt or pulley.
I only have 3k left on my warranty, and I don't know how I'm going to convince the dealership that somethin is wrong with it if it won't reproduce the noise when I leave it there. It's extremely frustrating. I guess I'm going to have to fix it myself.
Brian,
Black '04 Z71 4x4 Ext. Cab
My Gallery
69boo307 is offline
post #2 of 24 (permalink) Old 07-07-2005, 11:36 AM
Anything like this?
Underhood Whine or Rattle Type Noise (Replace Tensioner) #04-06-01-016A - (Nov 9, 2004)
2004 Chevrolet Colorado
2004 GMC Canyon
with 3.5L L5 Engine (VIN 6 - RPO L52)
Built Prior To VIN Breakpoints 48123220 (Chevrolet) and 48123225 (GMC)
This bulletin is being updated to clarify the Correction and Parts Information. Please discard Corporate Bulletin Number 04-06-01-016 (Section 06 - Engine/Propulsion System).
Condition
Some customers may comment on a whine type noise and/or a possible rattle noise on light acceleration coming from the engine. This noise may seem more pronounced at start up after an overnight soak.
Cause
The source of the noise may be the balance shaft chain and the tensioner interaction. There are 2 balance shafts in this engine that are driven by the crankshaft to keep the engine running smoothly. This noise does vary from vehicle to vehicle and does not cause any durability concerns; however, some customers may find it objectionable.
Correction
A new tensioner has been designed to eliminate this noise. The kit consists of an oil fed tensioner, longer tensioner bolts, balance shaft drive chain and right side balance shaft assembly. Please note that it is necessary to install the updated balance shaft assembly because it contains an oil feed passage for the oil fed tensioner.
This new tensioner was introduced into production in the mid December time frame. If you have a vehicle built prior to VIN breakpoints 48123220 (Chevrolet) and 48123225 (GMC), install a new tensioner, P/N 89017543.
Follow the removal and installation instructions in SI for the Balance Shaft Chain Tensioner Replacement in the Engine Mechanical section. You will also need to order and install a new rear oil seal, P/N 12568124.
Parts Information
Part Number - Description - Qty
89017543 - Tensioner Kit, Hydraulic - 1
12568124 - Seal, Crankshaft Rear Oil - 1
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation - Description - Labor Time
J0787 - Tensioner And/Or Shoe, Timing Chain - Replace - Use Published Labor Operation Time
Carbuster is offline
post #3 of 24 (permalink) Old 07-07-2005, 11:38 AM Thread Starter
that's likely the cause... but unless it will do it in front of the dealer tech, I have no way to convince them that there's a problem.
Brian,
My Gallery
69boo307 is offline
post #4 of 24 (permalink) Old 07-07-2005, 11:47 AM
I don't think that TSB is what your problem is. That is for the chain tensioner not tbe belt tensioner. I've been having the squealing belt issue also, happens the same as yours, but it has been getting worse lately. It will squeal after sitting for only 20-30 minutes now. I am going to the dealer after work tonight, it should be squealing when I go there if it acts as it normally does. I belive that it is the belt. I remeber seeing a post where someone had this issue and that some of the "early" trucks have a belt that is very slightly too long (only a couple mm's). My belt also seems to be glazed over a little bit, this combination may be causeing the squeal. I'll keep you posted, I have had no trouble with my dealer fixing things.
Silver Birch Z71 Crew Cab 4x4
1SF - L5 - SRW - ISRV - Leather
BedRug - XM-Roady2 - Aux Input Adapter
31x10.5 BFG A/Ts - TorzaTopCover
McCulloch 6000k HID
bablake is offline
post #5 of 24 (permalink) Old 07-07-2005, 11:50 AM Thread Starter
Yes, please let us know what happens. If it's just a matter of installing a new belt, then that's no big deal. There's nothing visibly wrong with my belt, but I'm not imagining the squealing.
Brian,
My Gallery
69boo307 is offline
post #6 of 24 (permalink) Old 07-07-2005, 02:02 PM
Send a message via AIM to Bigtryt
I also have a similar issue. It only happens when it rains and sits over night or it is damp outside at night. When I first start up I can hear a squeal and it goes away after a few minutes of driving. My guess would also be the belt tensioner.
-Nick
MyGallery
Grounded 355 Member #8
Bigtryt is offline
post #7 of 24 (permalink) Old 07-07-2005, 08:04 PM
took mine into the shop today for a under hood noise at a cold start. They told me it was the idler pulley and the part was on back order. my truck has 700 miles on it, man was i ever so chapped.
FLAT TOP is offline
post #8 of 24 (permalink) Old 07-08-2005, 11:16 AM
I went to the dealer after work, the service writer said they have replaced the belts on about 5 rados already. One of them was his and he has not had the problem return since the belt was replaced. He also said all the trucks were earlier in production (Dec '03-Jan-Feb-March of '04) and there was not common mileages, his was replaced at about 9k miles, mine will be replaced at about 22k. They have the belts in stock and I'm going in on Thursday to have it replaced.
McCulloch 6000k HID
bablake is offline
post #9 of 24 (permalink) Old 01-03-2006, 10:39 PM
mine has been doing the same thing (squealing on cold start) since i hit 200 miles and i am at 888 now and it is still doing it. like some of the others it goes away after 3 mins and doesn't come back the rest of the day. i took it in at 300 miles they told me to wait till 1000 miles. you can bet it is going back in, i already lost my truck for 3 days for them to repaint my roof and it still has to go in for scratches :( but i still love my truck :D
2005 Z-71 4x4
BlkZ-71 is offline
post #10 of 24 (permalink) Old 01-04-2006, 01:14 AM
i have a 2.8 and i also het the squeal when i start my truck in the morning, been happening since 8000 miles, a little to early for the belt to squeal isn't it, specially cuz my engine is still real clean
Grounded 355 Member #4
LiLKaRBoY13 is offline
post #11 of 24 (permalink) Old 01-04-2006, 01:38 AM
I had the same squeal at 53K on my truck and I replaced the belt and the squeal is now gone!
'04 White Canyon Crew Cab Z71 4x4, 3" Body Lift, 2" Shackles w/TB Crank, 33x10.50x15 BFG KO's, Rancho RS5000, Street Sceen Speed Grille, Wade Ventshields, K&N, Magnaflow, Spray Bed Liner, Hinged Tonneau Cover, Back up lights, H1 Tow Hooks, Barbed Wire Stripes.
Traildog is offline
post #12 of 24 (permalink) Old 01-04-2006, 02:39 AM
Send a message via AIM to Sawblade6
Does anyone have the problem of a whine at 3000 rpm driving down the road???
I wanna say it sounds like an engine being lugged.. i have no idea what it is all i know is that it comes from the rear ( more than sure of that). Anybody know what it is?, and could it be bad down the road?
Sgt Joseph Freeman
INFILTRATE.....DESTROY.....then rebuild
3 easy concepts
***Proud Supporter of Scorched Earth Policy '07*** USMC
Grounded 355 member #45
Sawblade6 is offline
post #13 of 24 (permalink) Old 01-04-2006, 04:13 AM
my truck had been sitting on the lot a very long time when i bought it, i think i am gonna push the issue and have them change the belt or do something, would be ridiculous to buy a 24k vehicle with 40 miles on it that squeals when you start it like it has a bad belt, people tend to look at you funny when you have t-tags still
we'll see what they do, they are pretty good at harrassing me with requests to fill out their survey of my experience maybe i will wait till i get this sorted out before i fill that out
2005 Z-71 4x4
BlkZ-71 is offline
post #14 of 24 (permalink) Old 01-04-2006, 06:51 AM
Send a message via AIM to 05colorado Send a message via Yahoo to 05colorado
Well crap, I wanna oil feed tensioner!
05colorado is offline
post #15 of 24 (permalink) Old 01-04-2006, 07:56 AM
Send a message via Yahoo to SONG
I have a squeeling serpentine belt that squeels to high heaven until the engine warms. I didn't think it abnormal. Every vehicle I've had does it in the winter months.
Conservative Club Member #8
SONG is offline
post #16 of 24 (permalink) Old 01-04-2006, 09:51 AM
Send a message via AIM to RedneckB790
Does anyone know if the Gator Belts (I think that is what they are called, the ones with the NASCAR endorsement on it) have a belt to fit our trucks...I would much rather have one of them than these stock cheapo belts...I put on on my Sunfire and it just seemed to sound better, no squeeling or any belt associated noise...
RedneckB790 is offline
post #17 of 24 (permalink) Old 01-04-2006, 10:04 AM
Send a message via Yahoo to Prydain
I went to the dealer about three times for this problem. The first time they cleaned the belt and that quieted the problem for a few weeks. The second and third time they replaced the belt and it was quiet for almost nine months. Just recently on cold mornings I get maybe five seconds of squeal.
'04 Z71 EXT Cab 2wd, I5, Auto, Mods: Green Filter
31x10.50x15 BFG TKOs
http://photobucket.com/albums/y179/Prydain/Colorado/
Prydain is offline
post #18 of 24 (permalink) Old 01-04-2006, 10:47 AM
Send a message via AIM to Rsquires67
Mine started doing that a couple of weeks ago, so it went in last week. They said it was the tensio pulley. So they had to order the parts. Going back tomorrow to get the new part.
Funny part was before is did it till it was warmed up. Now doing it all the time. The last week the noise is driving me nuts.
Also getting a new coil for the surging it was doing it threw a code and was related to the coil.
Then another call to GM again, this truck been in way to many times for different things. I want a 7/75 warranty from them. I just hit 29k and been like in 5 times for a list of things.
VOTE for me please in TOTY!!!! viewtopic.php?f=24&t=67915
Rsquires67 is offline
post #19 of 24 (permalink) Old 01-04-2006, 12:14 PM
Send a message via AIM to PARAGON
Mine has been squeeling pretty bad since last weekend. It first started up a couple weeks ago, but would die down after driving the truck for 5 minutes or so. Now it still screeches after driving into work. (about 30 min) I was thinking about taking it into the dealership, but are the belts covered under warrenty?
Or do you guys think that it would just be easier to change out the belt on my own?
PARAGON is offline
post #20 of 24 (permalink) Old 01-04-2006, 12:35 PM
I will let you know if mine is better with the new pully or whatever they doing to it. It will be in the shop tomorrow.
Also try a little belt dressing on it might help. But mine was doing the same thing as yours Paragon. It would go away after about 10 minutes of running.
