Fuel Pump Removal & Replacement - Chevy Colorado & GMC Canyon
post #1 of 13 (permalink) Old 09-29-2005, 03:04 PM Thread Starter
Has anyone attempted this proceedure? On a regular cab model
is there any way to access the pump, other than dropping the tank.
Since I'm assuming the electric pump resides inside the tank.
2004 GMC Canyon Z85 2wd 3.5 5spd
SLE Reg Cab, Polo Green Metallic
UnderCover Tonneau
ssrbuzz is offline
post #2 of 13 (permalink) Old 09-29-2005, 05:34 PM
It is easier to take the bed off of the truck than it is to lower the tank. The bed is only held on by a few bolts. Replaced 2 fuel pumps on my previous chevy silverado, and after the first time lowering the tank, a local mechanic gave me the tip. Made the next one a lot easier and quicker.
2005 Chevy Z71 4x4 Crew Cab
1SF package, 4.10 rear end, Eaton G80 Locker
Yakima roof rack, Bed extender, Bed liner,
32" BFG All-Terrains, 1 1/2" Lift Shackles in rear for leveling purposes. WARN M8000 Winch, custom winch bumper.
Sac34 is offline
post #3 of 13 (permalink) Old 09-29-2005, 08:37 PM
wow, take the bed off? If youve got a hoist, or a tractor. Find someone with a welder and have a plate made up to fit in your floor jack that will support something long. Sort of like a Tranny jack, but different.
God Grant me the serenity to accept the things I can not change, the courage to change the things I can, and the wisdom to know the difference.
www.krissplicing.com
KCinMI is offline
post #4 of 13 (permalink) Old 09-29-2005, 09:14 PM
Actually two guys can easily lift the bed off of the frame once it is unbolted. The hardest part of the entire procedure is unhooking the wiring harness from the brake lights, unbolting the gas tank filler neck from the bed and the bed from the frame, and removing the tailgate. Which is much easier than wrestling the gas tank loose from underneath, and trying to unhook the fuel lines in such a small cramped position. The bed is suprisingly lighter than it looks. If I ever have to do it on my coly, I won't even think twice which method I'll use. A phone call to some local repair shops in your area will show that most of them will go about it in the same way. That is how I found out about this way, and man was it easier. Anyway, just trying to save you some trouble. Good luck either way.
Sac34 is offline
post #5 of 13 (permalink) Old 10-31-2005, 12:20 AM
Send a message via Yahoo to coorsbill
Quick question: Where do you hook up fuel pressure gauge and what adapters do you need? Just in case...
Ax me about Jesus, he is cool.
coorsbill is offline
post #6 of 13 (permalink) Old 10-31-2005, 01:10 AM
Usually it's in line before the fuel line goes to the fuel rail. A lot of companies have it set up where the guage is connected by a tube that measures the pressure without having fuel come into the cab. I'm sure it's got to do with safety, obviously.
In the first place God made idiots. This was for practice. Then he made School Boards.
- Mark Twain
My Gallery
'05 Z85 CrewCab I5 4A 4x4 3.73 gears
'03 16" Silverado wheels w/ LT245/75R16 tires
geetar_zan is offline
post #7 of 13 (permalink) Old 10-31-2005, 10:45 AM
Thanks! I want to get a "baseline" for what is normal, while the truck is running well. Have 95 S-10 with CPI that will absolutely NOT run if the pressure is 38.0 pounds or less; if it's 39.0 or greater, it runs great! That's a whole 'nuther story however.
post #8 of 13 (permalink) Old 11-02-2005, 09:16 PM
And the reason for the problems with the CPI system is that the injectors are opened hydraulically, not electrically. I know because when the pressure side of the pump goes it will not run. An old Astro owner.
Yellow 04, LS Z71 2WD, Leather, color matched, OEM flares and speedliner, 3:42 axle. We love it.
Maxm is offline
post #9 of 13 (permalink) Old 11-22-2016, 05:24 AM
Send a message via MSN to Stu007
fuel Pump removal
hi, what are the chances of cutting a hole in the bed and removing the fuel pump, I saw a cross member under the bed that might just cause a problem and could I remove part of it to get at the pump..?
Stu007 is offline
post #10 of 13 (permalink) Old 11-22-2016, 06:29 AM
I would not bother cutting the bed.
The bed comes off easily. Two people can easily lift it. I have done several PU trucks that way. If you do not want to take it completely off, then simply lift it up and block it in place 6" to 12" above it's normal mounting position. Then you will have room to work.
post #11 of 13 (permalink) Old 11-22-2016, 12:38 PM
the question was, can it be done.? so, i only need 6" clearance to remove the pump..?
Stu007 is offline
post #12 of 13 (permalink) Old 11-22-2016, 01:32 PM
You don't need to completely remove the bed. Just disconnect everything and lift it up on one side and block it in position. You will need more than 6 inches for clearance. The problem you are going to have is corroded mount bolts. It looks like you live in the part of the country that paves the roads with salt. That same corrosion will be attached to the straps for the tank.
Can you cut a hole in the bed? Certainly. It's your truck. Have at it. If there is a crossmember there, it is probably a brace for the bottom of the bed and will probably have to be cut also. Don't know what model you have, but I'm assuming from the problems that you have worked on, that it is not a Crew Cab. The pump is under the cab on a Crew.
post #13 of 13 (permalink) Old 11-22-2016, 05:36 PM
OK, Thank you..
Stu007 is offline
