How to have radio turn off... - Chevy Colorado & GMC Canyon
post #1 of 17 (permalink) Old 11-20-2005, 02:14 AM Thread Starter
Send a message via AIM to rabidpanda Send a message via Yahoo to rabidpanda
Well, I am trying to find a way to have my radio turn off when I open the door. Right now, it will only turn off when I push the on/off button. Sorry if this has been answered a million times, but I looked around and did a search and couldn't find out anything. Thanks...
Dan
Dan
'04 Colorado ZQ8 X-Cab
rabidpanda is offline
post #2 of 17 (permalink) Old 11-20-2005, 03:25 AM
bbb
Door jamb switch working?
'07 silverado 4X4 ext cab/5.5' box
2'' lift with 275/60/20 tires
bbb is offline
post #3 of 17 (permalink) Old 11-20-2005, 03:04 PM
I wouldn't say that was normal. My radio turns off if the key's out and I open the door. I'd get the dealer to look at that.
Ranger is offline
post #4 of 17 (permalink) Old 11-20-2005, 05:13 PM Thread Starter
I just thought of something. It will turn off when the passenger door is opened, but not when the drivers door is opened. Maybe I will look at the latch and everything when I get out there...
Dan
post #5 of 17 (permalink) Old 11-20-2005, 07:02 PM
Try pressing that little knob in the doorframe. On my Ext cab, it's just in front of the swing door on the bottom.
Ranger is offline
post #6 of 17 (permalink) Old 11-20-2005, 09:00 PM Thread Starter
I will run out real quick and try it.
Dan
post #7 of 17 (permalink) Old 11-20-2005, 09:30 PM Thread Starter
Well, I tried playing with the little white knob, and it didn't help. I know for a fact that the passenger door will turn off the radio, but the drivers side won't. I guess back to the dealership...
Dan
post #8 of 17 (permalink) Old 11-20-2005, 09:47 PM
Global Moderator
Danny45's Avatar
It has to be the switch in the door. Should be a simple fix for the dealership.
Danny
10,000 Posts Club Member #1
Conservative Club Member #2
Danny45 is offline
post #9 of 17 (permalink) Old 11-20-2005, 09:54 PM
Send a message via AIM to bbrewbaker
Does your dome light come on when you open the door? If the light comes on then it's not the switch.
2006 Lapis Blue Mazda 6 I 2.3 4cyl, 5 speed Auto,
Mods: Xm Radio, Aux Mod, Stubby Antenna, Silverstar turn Singal bulbs (Front), 6x8 Pionner speakers in front door, 100 watt Bazooka Sub, 3 Led bulb for trunk light, Bosch Icon wiper blades.
bbrewbaker is offline
post #10 of 17 (permalink) Old 11-20-2005, 11:24 PM Thread Starter
Yes, the light comes on. And after messing around with anything door related, it still doesn't do it. Another thing that I thought of, the last time I got out of my truck, the wipers still worked when the truck was turned off and the key was out. Seems like nothing is turning off when I get out of the drivers door...
Dan
post #11 of 17 (permalink) Old 11-21-2005, 12:35 AM
Global Moderator
Danny45's Avatar
May just need to have the bcm flashed. That's the only other thing I can think of. The bcm controls all that stuff.
Danny
Danny45 is offline
post #12 of 17 (permalink) Old 11-21-2005, 01:41 AM
What white knob? The one in mine is black and it's more of a push button.
Ranger is offline
post #13 of 17 (permalink) Old 11-21-2005, 03:34 PM
Then I would take it to the dealer. Sounds like a probelm with the BCM like Danny said.
post #14 of 17 (permalink) Old 09-17-2008, 09:38 PM
Re: How to have radio turn off...
Back from the dead!
I am having the same problem with my 04 Colorado. When I open the drivers side door nothing shuts off. When I open the passenger door everything will shut off.
I thought it was the door jamb switch so I took the switch from the passenger side and put it on the drivers side door and the drivers side switch and put it on the passenger side door. I still have the same problem!
I am thinking maybe one or both of the 2 wires on the harness going to the switch on the drivers side is cut somewhere??? Any suggestions???
galleyhand is offline
post #15 of 17 (permalink) Old 09-17-2008, 10:42 PM
Since you have an '04 truck, your door sill plate should be plastic. Carefully pull it up and remove it, its only held on with clips. Lift the carpet and you should see a wiring harness running along the inside edge of the door opening. Look for a gray/black wire and a white/black wire. These two wires go to the drivers side door jamb switch. Get your hands on a digital multimeter and set it to 'continuity'. With the door open, carefully pierce the gray/black wire with one probe and the white/black wire with the other. If the switch is good you get a beep. If no beep than you have a break in one or both wires. The gray black wire connects the switch to the BCM. The white/black wire goes to ground. When the door is open (switch closed) this completes the ground circuit from the BCM. The BCM then turns on the dome light. If the door isn't closed tight, the switch is sgain closed and the BCM gives you the 'Door Ajar' message in the DIC.
ANother check you can do is pierce the white/black wire with one probe and put the other probe on a good ground. With the DMM on continuity you should hear the beep. If so the black/white wire to ground is good. If no beep, the wire to ground has an open.
I also included the link to the wiring schematic.
http://www.naskie18.com/colorado/schema ... ircuit.pdf
ssgjurista is online now
post #16 of 17 (permalink) Old 09-17-2008, 10:46 PM
post #17 of 17 (permalink) Old 07-11-2011, 10:27 PM
Pretty late reply to a pretty old post...but I had the same issue and found that the Gy/Bk wire in the ext cab rear door (Left Front Door Ajar Switch) was broke in the rubber boot that "protects' the wires going from the door to the chassis..Anyway, the harness has part # 15112061 on the label, but will splice the gy/bk wire and all is well.
jrkeelt1 is offline
