trouble code P0106 ? - Chevy Colorado & GMC Canyon
post #1 of 5 (permalink) Old 01-12-2006, 09:54 PM Thread Starter
Send a message via AIM to nvmycolorado
P0106 MAP/BARO Circuit Range/Performance
is the code that came up from a diagnostic reading, tried google but couldn't find an explanation nor solution? anyone heard of this? know what it is? and most importantly how to fix it without going to a mechanic. Please any feedback would be greatly appreciated
nvmycolorado is offline
post #2 of 5 (permalink) Old 01-13-2006, 02:15 PM
th2855's Avatar
I found this:
P0106
Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
I'll see if I can find more info for you.
I also changed the thread title to more specific. More people might have info for you.
Z71 Crew cab / indigo blue / IL5 cyl
Gibson Stainless CAT back
K & N intake/PCM tuned
A R Atlas Wheels
wet okole seat covers
bed liner/rails/extender
carriage works billet grille & bow tie
goodmark air ram cowl hood
My Gallery
th2855 is offline
post #3 of 5 (permalink) Old 01-13-2006, 07:42 PM
The PCM calculates what the MAP signal voltage should be, based on engine RPM. If the MAP sensor voltage and the predicted MAP sensor values do not closely match, this DTC will be set.
The diagnostic flow chart for this DTC leads u to either replacing the sensor or a bad wire from the PCM to sensor.
ryan
spoolin ex is offline
post #4 of 5 (permalink) Old 01-13-2006, 07:42 PM Thread Starter
Originally Posted by th2855
I found this:
P0106
Thanks a lot :) i found that same information out.. unfortunately i have no idea what it means
post #5 of 5 (permalink) Old 01-11-2010, 08:04 PM
Re: trouble code P0106 ?
most likely Manifold Absolute Pressure Sensor(map sensor). try cleaning it. if not replace it. about 55.00 for map. when this act up your whole truck will run like crap. you should feel hesitation and almost stalling.
jmaggio2 is offline
