Partial List of OBD II Automotive Diagnostic Trouble Codes - Chevy Colorado & GMC Canyon
 1Likes
post #1 of 24 (permalink) Old 01-13-2006, 04:10 PM Thread Starter
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0127 Intake Air Temperature Too High
P0128 Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
P0129 Barometric Pressure Too Low
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0168 Engine Fuel Temperature Too High
P0169 Incorrect Fuel Composition
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance
P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
P0297 Vehicle Overspeed Condition
P0298 Engine Oil Overtemperature Condition
P0299 Turbo / Super Charger Underboost
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected with Low Fuel
P0314 Single Cylinder Misfire (Cylinder not Specified)
P0315 Crankshaft Position System Variation Not Learned
P0316 Misfire Detected On Startup (First 1000 Revolutions)
P0317 Rough Road Hardware Not Present
P0318 Rough Road Sensor A Signal Circuit
P0319 Rough Road Sensor B Signal Circuit
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0345 Camshaft Position Sensor A Circuit (Bank 2)
P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
P0347 Camshaft Position Sensor A Circuit Low Input (Bank 2)
P0348 Generic Camshaft Position Sensor A Circuit High Input (Bank 2)
P0349 Generic Camshaft Position Sensor A Circuit Intermittent (Bank 2)
P0350 Ignition Coil Primary/Secondary Circuit
P0351 Ignition Coil A Primary/Secondary Circuit
P0352 Ignition Coil B Primary/Secondary Circuit
P0353 Ignition Coil C Primary/Secondary Circuit
P0354 Ignition Coil D Primary/Secondary Circuit
P0355 Ignition Coil E Primary/Secondary Circuit
P0356 Ignition Coil F Primary/Secondary Circuit
P0357 Ignition Coil G Primary/Secondary Circuit
P0358 Ignition Coil H Primary/Secondary Circuit
P0359 Ignition Coil I Primary/Secondary Circuit
P0360 Ignition Coil J Primary/Secondary Circuit
P0361 Ignition Coil K Primary/Secondary Circuit
P0362 Ignition Coil L Primary/Secondary Circuit
P0363 Misfire Detected - Fueling Disabled
P0364 Ignition Coil L Primary/Secondary Circuit ?
P0365 Camshaft Position Sensor B Circuit (Bank 1)
P0366 Camshaft Position Sensor B Circuit Range/Performance (Bank 1)
P0367 Camshaft Position Sensor B Circuit Low Input (Bank 1)
P0368 Camshaft Position Sensor B Circuit High Input (Bank 1)
P0369 Camshaft Position Sensor B Circuit Intermittent (Bank 1)
P0370 Timing Reference High Resolution Signal A
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A"
P0381 Glow Plug/Heater Indicator Circuit ?
P0382 Glow Plug/Heater Circuit "B"
P0383 Glow Plug/Heater Indicator Circuit ?
P0384 Glow Plug/Heater Circuit B
P0385 Crankshaft Position Sensor B Circuit
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0390 Camshaft Position Sensor B Circuit (Bank 2)
P0391 Camshaft Position Sensor B Circuit Range/Performance (Bank 2)
P0392 Camshaft Position Sensor B Circuit Low Input (Bank 2)
P0393 Camshaft Position Sensor B Circuit High Input (Bank 2)
P0394 Camshaft Position Sensor B Circuit Intermittent (Bank 2)
P0395 Camshaft Position Sensor B Circuit High Input (Bank 2)
P0396 Camshaft Position Sensor B Circuit Intermittent (Bank 2)
P0397 (Undefined)
P0398 (Undefined)
P0399 (Undefined)
P0400 Exhaust Gas Recirculation Flow
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0409 Exhaust Gas Recirculation Sensor A Circuit
P0410 Secondary Air Injection System
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit
P0419 Secondary Air Injection System Relay "B" Circuit
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0425 Catalyst Temperature Sensor (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0429 Catalyst Heater Control Circuit (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0435 Catalyst Temperature Sensor (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0439 Catalyst Heater Control Circuit (Bank 2)
P0440 Evaporative Emission Control System
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit
P0450 Evaporative Emission Control System Pressure Sensor
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0456 Evaporative Emission System Leak Detected (very small leak)
P0457 Evaporative Emission System Leak Detected (fuel cap loose/off)
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
P0460 Fuel Level Sensor Circuit
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit
P0481 Cooling Fan 2 Control Circuit
P0482 Cooling Fan 3 Control Circuit
P0483 Cooling Fan Rationality Check
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit
P0486 Exhaust Gas Recirculation Sensor B Circuit
P0487 EGR Throttle Position Control Circuit
P0488 EGR Throttle Position Control Range/Performance
P0489 Exhaust Gas Recirculation Control Circuit Low
P0490 Exhaust Gas Recirculation Control Circuit High
P0491 Secondary Air Injection System (Bank 1)
P0492 Secondary Air Injection System (Bank 2)
P0493 Fan Overspeed (clutch locked)
P0494 Fan Speed Low
P0495 Fan Speed High
P0496 Evaporative Emission System High Purge Flow
P0497 Evaporative Emission System Low Purge Flow
P0498 Evaporative Emission System Vent Control Circuit Low
P0499 Evaporative Emission System Vent Control Circuit High
P0500 Vehicle Speed Sensor
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0504 Brake Switch A / B Correlation
P0505 Idle Control System
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0508 Idle Air Control System Circuit Low
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 CRUISE CONTROL ON SIGNAL MALFUNCTION
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0577 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) ErroR
P0606 PCM Processor Fault
Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0645 A/C Clutch Relay Circuit (CHRYSLER)
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P0812 Reverse Input Circuit Malfunction
P0900 Clutch Actuator Circuit Open
P0901 Clutch Actuator Circuit Range/Performance
P0902 Clutch Actuator Circuit Low
P0903 Clutch Actuator Circuit High
P0904 Gate Select Position Circuit Malfunction
P0905 Gate Select Position Circuit Range/Performance
P0906 Gate Select Position Circuit Low
P0907 Gate Select Position Circuit High
P0908 Gate Select Position Circuit Intermittent
P0909 Gate Select Control Error
P0910 Gate Select Actuator Circuit Open
P0911 Gate Select Actuator Circuit Range/Performance
P0912 Gate Select Actuator Circuit Low
P0913 Gate Select Actuator Circuit High
P0914 Gear Shift Position Circuit Malfunction
P0915 Gear Shift Position Circuit Range/Performance
P0916 Gear Shift Position Circuit Low
P0917 Gear Shift Position Circuit High
P0918 Gear Shift Position Circuit Intermittent
P0919 Gear Shift Position Control Error
P0920 Gear Shift Forward Actuator Circuit / Open [forward gears, 1,3,5]
P0921 Gear Shift Forward Actuator Circuit Range/Performance
P0922 Gear Shift Forward Actuator Circuit Low
P0923 Gear Shift Forward Actuator Circuit High
P0924 Gear Shift Reverse Actuator Circuit / Open [rearward gears, 2,4,6]
P0925 Gear Shift Reverse Actuator Circuit Range/Performance
P0926 Gear Shift Reverse Actuator Circuit Low
P0927 Gear Shift Reverse Actuator Circuit High
P0928 Gear Shift Lock Solenoid Circuit / Open
P0929 Gear Shift Lock Solenoid Circuit Range/Performance
P0930 Gear Shift Lock Solenoid Circuit Low
P0931 Gear Shift Lock Solenoid Circuit High
P0932 Hydraulic Pressure Sensor Circuit Malfunction
P0933 Hydraulic Pressure Sensor Range/Performance
P0934 Hydraulic Pressure Sensor Circuit Low Input
P0935 Hydraulic Pressure Sensor Circuit High Input
P0936 Hydraulic Pressure Sensor Circuit Intermittent
P0937 Hydraulic Oil Temperature Sensor Circuit
P0938 Hydraulic Oil Temperature Sensor Range/Performance
P0939 Hydraulic Oil Temperature Sensor Circuit Low Input
P0940 Hydraulic Oil Temperature Sensor Circuit High Input
P0941 Hydraulic Oil Temperature Sensor Circuit Intermittent
P0942 Hydraulic Pressure Unit Circuit Malfunction
P0943 Hydraulic Pressure Unit Cycling Period Too Short
P0944 Hydraulic Pressure Unit Loss of Pressure
P0945 Hydraulic Pump Relay Circuit / Open
P0946 Hydraulic Pump Relay Circuit Range/Performance
P0947 Hydraulic Pump Relay Circuit Low
P0948 Hydraulic Pump Relay Circuit High
P0949 ASM Adaptive Learning Not Done
P0950 ASM Control Circuit Malfunction
2009 GMC Sierra Hybrid
1998 Coleman Mesa pop-up trailer
max_headroom is offline
post #2 of 24 (permalink) Old 03-03-2006, 02:35 PM
thanks for this sticky...
Liberal Club Member #3
GospeedracerGo is offline
post #3 of 24 (permalink) Old 08-25-2006, 07:13 PM
th2855's Avatar
thought this site might interest people too.
http://www.obd-codes.com/trouble_codes/index.php
Z71 Crew cab / indigo blue / IL5 cyl
Gibson Stainless CAT back
K & N intake/PCM tuned
A R Atlas Wheels
wet okole seat covers
bed liner/rails/extender
carriage works billet grille & bow tie
goodmark air ram cowl hood
My Gallery
th2855 is offline
post #4 of 24 (permalink) Old 08-27-2006, 08:01 AM
Bud
Thanks for the list of trouble codes it is a great help.
2006 I5 CC 4x4 G80
Bridgestone Revo A/T
K&N
Bud is offline
post #5 of 24 (permalink) Old 01-12-2007, 02:03 AM
Good to know! Thanks for the info.
post #6 of 24 (permalink) Old 01-29-2007, 02:36 PM
NewColy's Avatar
Here is another place. http://www.regalgs.org/obd2.htm
NewColy is offline
post #7 of 24 (permalink) Old 04-03-2007, 11:26 PM
Send a message via AIM to orangebangZ71
is there a way of getting a DTC with out using a scan tool of some sort cause on hondas/acuras you can get dtc with the amount of blinks of the CEL
04 sunburst orange metallic 3.5L I5 4.11
K&N FIPK, mickey thompson MTZ 315/75/16, rock cralwer street locs 152, wolo air horns
IRONWORKERS LOCAL 433
orangebangZ71 is offline
post #8 of 24 (permalink) Old 04-04-2007, 09:40 AM Thread Starter
I don't think so.
post #9 of 24 (permalink) Old 07-03-2007, 11:44 PM
The haynes manual also has some codes in it. Saw it today flipping through.
RIP Spike 9-25-2007
coyote is offline
post #10 of 24 (permalink) Old 09-22-2007, 06:43 PM
great...my CEL is lite up. where did you guys go to find out the code
post #11 of 24 (permalink) Old 09-22-2007, 07:43 PM
Check out the owners manual, I think I recal reading about how to use the Digital Info Center (DIC) in the speedo area to see/ scroll codes.
Ride'n on QA1's
Life is hard, but it is a heck of a lot harder, if your stupid ! ~ John Wayne
twgiffin is offline
post #12 of 24 (permalink) Old 09-23-2007, 09:22 AM
The Murrays, Autozone, and Advance Auto all pull codes around here.
RIP Spike 9-25-2007
coyote is offline
post #13 of 24 (permalink) Old 09-25-2007, 12:58 PM
Advance and Orielly's cant pull codes anymore, some asshole bought every sensor under his hood, then found out that it was his engine computer, then sued because the OBD code reader fried it
DasGoob likes this.
Gun Toting American Club Member #5
2007 TOTW Winner Week #21
LongBow986 is offline
post #14 of 24 (permalink) Old 02-29-2008, 06:10 PM
Hey guys,
I found this list of codes, it has all the ones under p0100
http://www.midwestavalancheclub.com/ind ... 9.msg17923
guido is offline
post #15 of 24 (permalink) Old 06-10-2008, 07:29 PM
Re: Partial List of OBD II Automotive Diagnostic Trouble Codes
Hello Everyone
Does Anybody have good suggestions for a good reliable ( average model ) for code reader ?
coly-greenhorn is offline
post #16 of 24 (permalink) Old 06-14-2008, 04:32 PM
Scanguage II
Originally Posted by coly-greenhorn
Hello Everyone
I use a scanguage II, that will give you a lot of other features too for a reasonable price.
There is always the option of having autozone read your codes for you as well.
2008 Pontiac G6 3.5 4 door
1996 Jeep Grand Cherokee 4.0 ... the "other vehicle"
Canyon.Off.Road is offline
post #17 of 24 (permalink) Old 08-15-2008, 03:29 PM
here's the list i have
Diagnostic Trouble Code (DTC) List - Vehicle
DTC
Descriptor
DTC B0012, B0013, B0014, B0016, B0017, or B0018
Right Front/Passenger Frontal Deployment Loop (Stage 1) Circuit
DTC B0022, B0024, B0026, B0042, B0043, or B0044
Left Front/Driver Frontal Deployment Loop (Stage 1) Circuit
DTC B0051
Deployment Commanded
DTC B0053
Deployment Commanded with Loop Malfunctions Present
DTC B0057, B0058, or B0059
Passenger Pretensioner Deployment Loop Circuit
DTC B0061, B0062, or B0068
Driver Roof Rail Bag Deployment Loop Circuit
DTC B0064, B0065, or B0066
Driver Pretensioner Deployment Loop Circuit
DTC B0069, B0070, or B0071
Passenger Roof Rail Bag Deployment Loop Circuit
DTC B0077, B0078, B0079, B0080, B0081, or B0082
Side Impact Sensor (SIS) Circuit
DTC B0083 or B0084
Inflatable Restraint Seat Position Switch Circuit
DTC B0090
Active Switch Voltage Out of Range
DTC B0091
Active Switch Wrong State
DTC B0100, B0101, B0102, B0103, B0104, or B0105
Electronic Frontal Sensor Circuit
DTC B0527, B0528, or B0529
Right Turn Signal Circuit
DTC B0532, B0533, or B0534
Left Turn Signal Circuit
DTC B0827
Traction Control System Off Indicator Circuit Low
DTC B0828
Traction Control System Off Indicator Circuit High
DTC B1000
ECU Malfunction
DTC B1001
Option Configuration Error
DTC B1004
Keep Alive Memory (KAM) Reset
DTC B1007
EEPROM Write Error
DTC B1009
EEPROM Checksum Mismatch
DTC B1025, B1035, B1045, or B1055
Audio [+] Output Circuit
DTC B1259
Antenna Ground Circuit
DTC B1372
Device Ignition 1 (ON and START) Circuit Low
DTC B1372, B1373, or B1374
Device Ignition 1 Circuit
DTC B1382, B1383, or B1384
Device Ignition ACCESSORY Circuit
DTC B1420
Device Voltage
DTC B1441, B1442, or B1443
Device Ignition OFF, RUN, and CRANK Circuit
DTC B1477 or B1478
Retained Accessory Power Circuit Low
DTC B2455
Cellular Phone Microphone Circuit
DTC B2470
Cellular Phone Antenna Circuit
DTC B2476
Cellular Phone Select Service Switch Malfunction
DTC B2482
Cellular Phone Select Service Switch Range/Performance
DTC B2483 or B2484
Global Positioning System (GPS) Sensor Circuit
DTC B2532 or B2533
Front Foglamps Control Circuit
DTC B2557 or B2558
Passenger Compartment Lamp Control Circuit
DTC B2562 or B2563
Cargo Lamp Control Circuit
DTC B2575
Headlamp Control Circuit
DTC B2582 or B2583
Headlamp High Beam Control Circuit
DTC B2585
Parklamp Control Circuit Malfunction
DTC B2622 or B2623
Display Dimming Pulse Width Modulation (PWM) Input Circuit
DTC B2624
Display Dimming Signal Circuit
DTC B2647 or B2648
Ambient Light Sensor Circuit
DTC B2707
Gearshift Unlock Circuit Low
DTC B2708
Gearshift Unlock Circuit High
DTC B2725
ATC Mode Switch Circuit Malfunction
DTC B2745
Traction Control Switch Circuit
DTC B2752
Horn Relay Coil Circuit Low
DTC B2753
Horn Relay Coil Circuit High
DTC B2957
Security System Sensor Data Circuit Low
DTC B2958
Security System Sensor Data Circuit High
DTC B2960
Sec Sys Sensor Data Incorrect but Valid
DTC B3031
Security System Controller in Learn Mode
DTC B3033
Security System Indicates Tamper
DTC B3142 or B3143
Driver Unlock Switch Circuit
DTC B3152 or B3153
Driver Lock Switch Circuit
DTC B3715, B3716, B3717, B3718, or B3719
Front Wiper Relay Drive Circuit
DTC B3787 or B3788
Blower Motor Relay Control Circuit
DTC C0035
Left Front Wheel Speed Sensor Circuit
DTC C0040
Right Front Wheel Speed Sensor Circuit
DTC C0055
Rear Wheel Speed Sensor Circuit
DTC C0110
Pump Motor Circuit
DTC C0191
Four Wheel Drive (4WD) Reference Accelerometer Circuit
DTC C0201
Antilock Brake System (ABS) Enable Relay Contact Circuit
DTC C0220-C0229
Antilock Brake System (ABS) Channel in Release Too Long
DTC C0240 or P1571
Powertrain Control Module (PCM) Traction Control Not Allowed
DTC C0244 or P1689
Pulse Width Modulated (PWM) Delivered Torque
DTC C0245
Wheel Speed Sensor Frequency Error
DTC C0267 or C0268
Pump Motor Circuit
DTC C0327
Encoder Circuit Malfunction
DTC C0550
ECU Malfunction
DTC C0569
System Configuration Error
DTC C0899
Device Voltage Low
DTC C0900
Device Voltage High
DTC P0013
Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit
DTC P0014
Exhaust Camshaft Position (CMP) System Performance
DTC P0016
Crankshaft Position (CKP) - Camshaft Position (CMP) Correlation
DTC P0017
Crankshaft Position (CKP) - Exhaust Camshaft Position (CMP) Correlation
DTC P0030 or P0036
HO2S Heater Control Circuit
DTC P0068
Throttle Body Airflow Performance
DTC P0101
Mass Air Flow (MAF) Sensor Performance
DTC P0102
Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103
Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0106
Manifold Absolute Pressure (MAP) System Performance
DTC P0107
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112
Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113
Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0117
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0120
Throttle Position (TP) Sensor 1 Circuit
DTC P0121
TP Sensor Circuit Insufficient Activity
DTC P0125
Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0128
Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
DTC P0130
HO2S Circuit Sensor 1 (LK5)
DTC P0130
HO2S Circuit Bank 1 Sensor 1 (L52)
DTC P0131
HO2S Circuit Low Voltage Sensor 1 (LK5)
DTC P0131
HO2S Circuit Low Voltage Bank 1 Sensor 1 (L52)
DTC P0132
HO2S Circuit High Voltage Sensor 1 (LK5)
DTC P0132
HO2S Circuit High Voltage Bank 1 Sensor 1 (L52)
DTC P0133
HO2S Slow Response Sensor 1 (LK5)
DTC P0133
HO2S Slow Response Bank 1 Sensor 1 (L52)
DTC P0134
HO2S Circuit Insufficient Activity Sensor 1 (LK5)
DTC P0134
HO2S Circuit Insufficient Activity Bank 1 Sensor 1 (L52)
DTC P0135
HO2S Heater Performance Sensor 1 (LK5)
DTC P0135
HO2S Heater Performance Bank 1 Sensor 1 (L52)
DTC P0136
HO2S Circuit Sensor 2 (LK5)
DTC P0136
HO2S Circuit Bank 1 Sensor 2 (L52)
DTC P0137
HO2S Circuit Low Voltage Sensor 2 (LK5)
DTC P0137
HO2S Circuit Low Voltage Bank 1 Sensor 2 (L52)
DTC P0138
HO2S Circuit High Voltage Sensor 2 (LK5)
DTC P0138
HO2S Circuit High Voltage Bank 1 Sensor 2 (L52)
DTC P0140
HO2S Circuit Insufficient Activity Sensor 2 (LK5)
DTC P0140
HO2S Circuit Insufficient Activity Bank 1 Sensor 2 (L52)
DTC P0141
HO2S Heater Performance Sensor 2 (LK5)
DTC P0141
HO2S Heater Performance Bank 1 Sensor 2 (L52)
DTC P0171
Fuel Trim System Lean
DTC P0172
Fuel Trim System Rich
DTC P0201-P0204
Fuel Temperature Sensor Circuit High Pulsewidth (LK5)
DTC P0201-P0205
Fuel Temperature Sensor Circuit High Pulsewidth (L52)
DTC P0218
Transmission Fluid Overtemperature
DTC P0220
Throttle Position (TP) Sensor 2 Circuit
DTC P0230
Fuel Pump Relay Control Circuit
DTC P0300
Engine Misfire Detected
DTC P0301-P0304
Cylinder X Misfire Detected (LK5)
DTC P0301-P0305
Cylinder X Misfire Detected (L52)
DTC P0315
Crankshaft Position (CKP) System Variation Not Learned
DTC P0325
Knock Sensor (KS) Circuit
DTC P0326
Knock Sensor (KS) Performance
DTC P0327
Knock Sensor (KS) Circuit (LK5)
DTC P0327 or P0332
Knock Sensor (KS) Circuit (L52)
DTC P0335
Crankshaft Position (CKP) Sensor Circuit
DTC P0336
Crankshaft Position (CKP) Sensor Performance
DTC P0340
Camshaft Position (CMP) Sensor Circuit
DTC P0341
Camshaft Position (CMP) Sensor Performance
DTC P0351-P0354
Ignition Coil X Control Circuit (LK5)
DTC P0351-P0355
Ignition Coil X Control Circuit (L52)
DTC P0365
Camshaft Position (CMP) Sensor 2 Circuit
DTC P0366
Camshaft Position (CMP) Sensor 2 Performance
DTC P0420
Catalyst System Low Efficiency
DTC P0442
Evaporative Emission (EVAP) System Small Leak Detected
DTC P0443
Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0446
Evaporative Emission (EVAP) Vent System Performance
DTC P0449
Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P0452
Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453
Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0455
Evaporative Emission (EVAP) System Large Leak Detected
DTC P0461
Fuel Level Sensor Performance
DTC P0462
Fuel Level Sensor Circuit Low Voltage
DTC P0463
Fuel Level Sensor Circuit High Voltage
DTC P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P0502
Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
DTC P0506
Idle Speed Low
DTC P0507
Idle Speed High
DTC P0520
Engine Oil Pressure (EOP) Sensor Circuit
DTC P0532 or P0533
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
DTC P0562
System Voltage Low
DTC P0563
System Voltage High
DTC P0564
Cruise Control Multi-Function Switch Circuit
DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610
ECU Malfunction
DTC P0621
Generator L-Terminal Circuit
DTC P0622
Generator F-Terminal Circuit
DTC P0641
5 Volt Reference 1 Circuit
DTC P0650
DTC P0651
5 Volt Reference 2 Circuit
DTC P0711
TFT Sensor Circuit Range/Performance
DTC P0712
Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713
Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0719
Brake Switch Circuit Low Input
DTC P0724
Brake Switch Circuit High Input
DTC P0741
TCC System Stuck Off
DTC P0742
TCC System Stuck On
DTC P0748
Pressure Control Solenoid Circuit Electrical
DTC P0751
1-2 Shift Solenoid Valve Performance
DTC P0752
1-2 Shift Solenoid (SS) Valve Performance - No Second Or Third Gear
DTC P0756
2-3 Shift Solenoid Valve Performance
DTC P0757
2-3 Shift Solenoid (SS) Valve Performance - No Third Or Fourth Gear
DTC P0787
3-2 Shift Solenoid (SS) Control Circuit Low Voltage
DTC P0788
3-2 Shift Solenoid (SS) Control Circuit High Voltage
DTC P0894
Transmission Component Slipping
DTC P0973
Shift Solenoid (SS) 1 Control Circuit Low Voltage
DTC P0974
Shift Solenoid (SS) 1 Control Circuit High Voltage
DTC P0976
Shift Solenoid (SS) 2 Control Circuit Low Voltage
DTC P0977
Shift Solenoid (SS) 2 Control Circuit High Voltage
DTC P1101
Intake Air Flow System Performance
DTC P1106
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
DTC P1107
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
DTC P1111
Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC P1112
Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1133
HO2S Insufficient Switching Sensor 1
DTC P1380
Misfire Detected - Rough Road Data Not Available
DTC P1381
Misfire Detected - No Communication with Brake Control Module
DTC P1516
Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
DTC P1523
Throttle Closed Position Performance
DTC P1545
Air Conditioning (A/C) Clutch Relay Control Circuit
DTC P1574
Stoplamp Switch Circuit
DTC P1626
Theft Deterrent Fuel Enable Signal Lost
DTC P1630
Theft Deterrent Learn Mode Active
DTC P1631
Theft Deterrent Start Enable Signal Not Correct
DTC P1682
Ignition 1 Switch Circuit 2
DTC P1810
TFP Valve Position Switch Circuit
DTC P1815
Transmission Fluid Pressure (TFP) Valve Position Switch - Start in Wrong Range
DTC P1816
Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Park/Neutral (P/N) With Drive Ratio
DTC P1862
Torque Converter Clutch TCC Solenoid Valve Circuit Low Voltage
DTC P1863
Torque Converter Clutch TCC Solenoid Valve Circuit High Voltage
DTC P2101
Control Module Throttle Actuator Position Performance
DTC P2120
Accelerator Pedal Position (APP) Sensor 1 Circuit
DTC P2125
Accelerator Pedal Position (APP) Sensor 2 Circuit
DTC P2135
Throttle Position (TP) Sensor 1-2 Correlation
DTC P2138
Accelerator Pedal Position (APP) Sensor 1-2 Correlation
DTC P2176
Minimum Throttle Position Not Learned
DTC P2763
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage
DTC P2764
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage
DTC P2771
Four Wheel Drive (4WD) Low Switch Circuit
DTC U1000 and U1255
Class 2 Communication Malfunction
DTC U1001-U1254
Loss of XXX Communications
DTC U1300, U1301, or U1305
Class 2 Data Link Shorted
DTC U1500
Communication State of Health
pjpeery is offline
post #18 of 24 (permalink) Old 01-19-2009, 07:26 AM
Hello Everyone
The actron OBDII Autoscanner model #cp9175 works great.
TML Construction is offline
post #19 of 24 (permalink) Old 01-28-2009, 11:15 PM
Thats why I love having alldata. All the code info I need
zeuce is offline
post #20 of 24 (permalink) Old 02-01-2009, 10:11 AM
Another member posted this link a few months ago:
http://service.gm.com/gmspo/mode6/index.html
When it opens, look at the right side of the page for engine and transmission parameters. For 2006 and below, just click on "Engine" or "Transmission" and then select your engine or tranny.
Along with a list of codes, there is a brief description of what causes the code. For 2007 and newer models, click on "Engine" or "Transmission" and then click on "Engine & Transmission Diagnostic Parameter File Index" to find what Group your engine or tranny is in. For example, an '08 Colly with the 3.7L is in Group 9. So you would then click on the Group 9 Engines pdf.
