Towable Colorado - Chevy Colorado & GMC Canyon
post #1 of 14 (permalink) Old 07-21-2012, 06:22 PM Thread Starter
Towable Colorado
I am interested in purchasing a Colorado to tow behind my motorhome. I have no experience with this truck but have heard that it can be towed without modification. I want an extended cab, but am very flexible on everything else - as long as it is towable.
Any comments/advice on what year/engine/transmission/etc would be good for this purpose will be greatly appreciated.
Thanks,
John
johntk is offline
post #2 of 14 (permalink) Old 07-21-2012, 07:15 PM
What kind of modifications would you expect to be necessary?
Should not require anything, but there are different precautions to take if towing a 4x4.
post #3 of 14 (permalink) Old 07-21-2012, 11:43 PM
crazyeyez's Avatar
Send a message via AIM to crazyeyez Send a message via MSN to crazyeyez Send a message via Yahoo to crazyeyez
how do you plan to tow? flat tow (all 4 wheels on road) using a tow bar? tho i see RV's on the highways doing this all the time, its not something i like much (i'd much rather use a trailer). i dont know if i'd want to do so with a 4wd. but a 2wd shouldnt be a problem. one thing i would try to do with a 2wd is disconnect the drive shaft from the rear diff. i'm not sure how easy this is, but would prevent any posible damage/wear on the tranny.
05 Canyon 4wd Z71 CrewCab
3.5 5cyl 3.73 G80, K&N FIPK, SuperModz PTB&SuperSparkz, manifold cat gutted, HTP
2" SMaxx shackles, TB cranked, Rancho rs5000,
Surco roof rack,LED 24v lights, BullMaxx3, 4 130w KC DayLighters
6 1/2" Sony Xplode's, LUND Tri-Fold, FB-PhotoBucket
MUD CLUB #36--LIFTED CLUB #433--OFF ROAD CLUB #1--ROOFRACK CLUB#1 -- MY ROOF RACK
crazyeyez is offline
post #4 of 14 (permalink) Old 07-24-2012, 01:05 PM
fitsector's Avatar
Reading my owner´s manual I found that on 4WD colorados there is a procedure to put the transfer case in "Neutral" which is optimal for towing the truck.
Proud owner of American Pickup trucks since 2006
2009 1LT Crewcab Z85 2.9 L4 2WD Deep Red (Wife)
2011 1LT Crewcab Z85 2.9 L4 2WD Summit White (Brother)
2012 2LT Crewcab Z71 3.7 L5 4x4 Deep Navy (My ride)
fitsector is offline
post #5 of 14 (permalink) Old 07-24-2012, 02:08 PM
britishrich's Avatar
I have read that the 2wd is actually tow-flat ready without issues...I believe the only truck in it's class that is set up that way too.
britishrich is offline
post #6 of 14 (permalink) Old 07-24-2012, 03:00 PM
Four-Wheel Drive Vehicles
Use the following steps to tow your vehicle with all
four wheels on the ground:
1. Drive the vehicle to be towed into position behind
the tow vehicle.
2. Firmly set the parking brake. See Parking Brake
on page 2-31 for more information.
3. Put an automatic transmission in PARK (P) or a
manual transmission in FIRST (1).
4. Securely attach the vehicle being towed to the
tow vehicle.
{CAUTION:
Shifting a four-wheel-drive vehicle’s transfer
case into NEUTRAL can cause your vehicle to
roll even if the transmission is in Park (P) for
an automatic transmission, or if your vehicle is
in gear, for a manual transmission. You or
others could be injured. Make sure the parking
brake is firmly set before you shift the transfer
case to NEUTRAL.
4-5. Shift the transfer case to NEUTRAL. See
Four-Wheel Drive on page 2-28 for more
information.
6. Release the parking brake only after the vehicle
being towed is firmly attached to the towing
vehicle.
Notice: If you exceed 55 mph (90 km/h) while
towing your vehicle, it could be damaged. Never
exceed 55 mph (90 km/h) while towing your vehicle.
7. Turn the ignition to LOCK. To prevent your battery
from draining while towing, remove the RDO BATT
and CLSTR fuses from the instrument panel fuse
block. Be sure to replace the fuse when you reach
your destination. See Fuses and Circuit Breakers
on page 5-105 for more information.
After towing see “Shifting out of NEUTRAL” under
Four-Wheel Drive on page 2-28.
orangez71 is offline
post #7 of 14 (permalink) Old 07-24-2012, 03:01 PM
Two-Wheel Drive Vehicles
Notice: If you tow your vehicle with all four wheels
on the ground, the drivetrain components could
be damaged. The repairs would not be covered by
your warranty. Do not tow your vehicle with all
four wheels on the ground.
Two-wheel-drive vehicles should not be towed with all
four wheels on the ground. Two-wheel-drive
transmissions have no provisions for internal lubrication
while being towed
post #8 of 14 (permalink) Old 07-24-2012, 03:06 PM
My bad orange you got me second guessing now and I am definitely not going to argue with the owners manual quote :)
(In my defense there IS a lot of people out there flat towing their manual 2wds though, just saw a couple on RV sites...LOL)
post #9 of 14 (permalink) Old 07-24-2012, 04:13 PM
that is out of my 04 owners manual.
post #10 of 14 (permalink) Old 07-24-2012, 04:20 PM
fitsector's Avatar
Still the same as I got on my 2012 manual.
post #11 of 14 (permalink) Old 07-24-2012, 09:35 PM
crazyeyez's Avatar
sounds pretty good tho. putting the T-case in nutral dissconnets the transmission from the drive wheels. with out the t-case, the 2wd's have no ways to disconnect like that.
i still stand by disconnectingi the driveshaft from the differential, but i have no idea how the warrenty nazi's would feel about that. i'd have to crawl unnder the truck to see how easy that would to. this is even something the books say to do when flat towing some of the armys larger trucks.
post #12 of 14 (permalink) Old 07-25-2012, 03:28 AM
The driveshaft is easy to remove. Just a few bolts mounting the flanges together. Once it is removed from the rear differential, you slide it backwards and remove it from the splines of the transmission.
Mark the flange location to know how to put the flange back on the differential flange. I don't know if it matters, but it would be nice to put it back where it came from. It's critical to mark the yolk location to the driveshaft if you replace universal joints. It only takes a second to mark it so I would do it.
post #13 of 14 (permalink) Old 07-31-2012, 09:39 AM
johntk, I have a 04 colorado crew cab that I pull behind my MH I have a blue ox tow bar system and a smi internal braking system for the truck. The tow bar bracket and light wiring were easy to hook up, the brake system was a bit of a pain but a must need to be towing the truck. Mine is 4wd so I just put the transfer case into N and away we go. Not sure on the MH you have but check the allowable tow weight for the coach, I just make it at around 4200 lbs dry you dont wanna over do it!
BobbyH is offline
post #14 of 14 (permalink) Old 06-17-2015, 03:59 PM
Has to four wheel drive with the two speed transfer case.
Towing procedure:
1. CONNECT TRUCK
2. ENGINE RUNNING PUT TRANSFER CASE INTO NEUTRAL.
3. SHIFT INTO DRIVE, TURN OFF ENGINE
4. THEN SHIFT INTO PARK
5. WAIT 10-SECONDS AND RE-START ENGINES
6. SHIFT INTO DRIVE, TURN OFF ENGINE.
7. DISCONNECT BATTERY
8. SHIFT INTO PARK
9. KEY ON ACCESSORY POSITION TO UNLOCK STEERING.
Also Blue OX makes a nice base plate for towing this truck.
michaelholzer is offline
