Which vent valve part number? - Chevy Colorado & GMC Canyon
post #1 of 5 (permalink) Old 04-14-2015, 06:42 PM Thread Starter
Kodak's Avatar
Hi,
I'm doing the common P0449 error code repair. I think I can fix it myself, after having read several related threads, but I'm getting some conflicting information.
There are several different part numbers referenced in various threads: 214-2147, 214-2149, 214-2324 and 214-2328. These are all AC Delco vent valves. My understanding is that some use a square connector and others an oval. If you get the wrong one, you have to also buy wiring harness 19257603 to make it fit.
Which part # would be a perfect fit for an 07 Canyon (SL, 2wd, i-4, stick shift)?
Edit: Just learned that the 07's used the round/oval connector. These were phased out for the square ones later.If anyone knows which part has the round connector, it'd be a huge help.
Thanks for the help.
Best,
Kodak
Kodak is offline
post #2 of 5 (permalink) Old 04-14-2015, 07:17 PM
The valve that will fit and plug and play with your wiring is 214-2149.
The originally recommended valve, 214-2147 is no longer in production. If you order that number, you will get it's replacement, 214-2324, which has the square connector. That will necessitate the jumper harness. I don't recognize the number 214-2328.
Note: for anyone with a newer truck, the wire harness was changed to a square connector, so 214-2324 will be the correct number. I know that the 2011 has a square connector and I think the 2010 does also.
post #3 of 5 (permalink) Old 04-14-2015, 07:59 PM Thread Starter
Kodak's Avatar
Plug and play, baby. 214-2149.
Thanks for the speedy reply, cart. I'll grab this part and get it done this weekend.
Kodak is offline
post #4 of 5 (permalink) Old 04-16-2015, 05:13 PM Thread Starter
Kodak's Avatar
Just did the job and I want to report that the part was a perfect fit. Cart, you saved me about $40 versus what the dealer wanted for the new generation vent valve plus adapter. Big thanks!
Kodak is offline
post #5 of 5 (permalink) Old 04-16-2015, 06:03 PM
Glad it worked out. Thanks for the update.
