M30 4-SPEED AUTOMATIC TRANSMISSION SPECIFICATIONS - Chevy Colorado & GMC Canyon
post #1 of 2 (permalink) Old 12-29-2003, 10:59 PM Thread Starter
Transmission model: AUTOMATIC 4-SPEED w/OVERDRIVE 4L60-E
RPO Code: M30
GEAR RATIOS:
First: 3.05
Second: 1.62
Third: 1.00
Fourth: .69
Reverse: 2.29
Gear type: Planetary
TORQUE CONVERTER
Element types: Pulse width modulated solenoid control
Lock-up clutch: Automatic
Maximum Engine Torque (lb-ft/N-m): 360/486
LUBRICANT CAPACITY (pints/litre):
Dry Fill: 11.4/10.78896
Refill: 5/4.732
MAX GVW(lbs/kg): 8600/3900.96
Ken Deatrick
My CarDomain Gallery
kdeatrick is offline
post #2 of 2 (permalink) Old 12-29-2003, 11:25 PM
That's probably why the ones I drove didn't feel very punchy.
The A4 only has a 3.05:1 first gear.
The M5 has a 3.75:1 first gear. WAY more torque at the rear wheels.
Couple the M5 with the 3.73:1 rear end, and it should be pretty torque-y.
I drove A4, 3:42:1 twins.
2009 Challenger R/T
2007 Solstice GXP
2004 Colorado ZQ8 White
2002 Trans Am WS6 Collector Edition
1994 Grand Prix SE B4U
My Gallery
HuJass is offline
