Wiring Info - All colors , locations, etc. - Chevy Colorado & GMC Canyon
post #1 of 15 (permalink) Old 05-14-2004, 01:44 PM Thread Starter
I just found this great reference for wiring on the Colorado. It has everything that you need to know for wiring a radio, security system, etc. Check it out :
http://www.haven4bees.com/co/archives/2 ... r_2004.php
Let me know what you think.
2004 Colorado Sport(ZQ LS
Black Regular Cab
3.5L I-5 Auto
Check out my Colorado website: http://www.haven4bees.com/co/
sczq8@haven4bees.com
SCZQ8 is offline
post #2 of 15 (permalink) Old 05-14-2004, 02:37 PM
EXCELLENT, thanks...
Rob.
2006 Chevrolet 2500HD LBZ Duramax EC Std Bed 4WD, Prodigy Brake Controller, Line-X Bedliner, Scangauge II
rvsixer is offline
post #3 of 15 (permalink) Old 05-28-2004, 12:16 AM
The link has gone down. Can you post it here. If anyone copied the info, let us know.
Ken Deatrick
1957 BELAIR 4 DOOR HARD TOP
My CarDomain Gallery
kdeatrick is offline
post #4 of 15 (permalink) Old 06-22-2004, 07:08 PM
Z71_rado is offline
post #5 of 15 (permalink) Old 07-27-2004, 01:04 PM
Send a message via AIM to twdawg Send a message via Yahoo to twdawg
FOR THE CREW CAB: After making numerous calls to dealers, I finally found information on the SPEAKER wiring diagram for the Colorado Crew Cab . They are as follows:
Front LEFT Door: Tan (+); Gray (-)
Front RIGHT Door: Light Green (+); Dark Green (-)
Back Doors: Brown (+); Yellow (-)
Apparently, in some models, the RIGHT REAR door has blue wires. If this is the case, here is the polarity: Dark Blue (+); Light Blue (-)
Just thought I'd share this so it's now available in one place.
Information compliments of Team Chevrolet at Northpoint (Atlanta) (free plug).
- Todd
Crew Cab, Z71, 2WD, Silver Birch, Dark Pewter Cloth, XM .. looking to install new speakers soon.
If you can't live in Colorado, then at least drive one!
twdawg is offline
post #6 of 15 (permalink) Old 07-27-2004, 02:07 PM
Code Systems Tech Support 505080 Code Systems ID:
CHEVROLET COLORADO 2004 4DR TRUCK
Security Color Polarity Location
Battery WHITE/BLACK (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE/GREEN (+) IGNITION SWITCH HARNESS
Starter 1 (+) IGNITION SWITCH HARNESS
Domelight Super WHITE (-) AT THE BODY CONTROL MODULE PIN # A46
LF Latch GRAY/BLACK (-) AT THE BODY CONTROL MODULE PIN # A32
- Note YOU MUST DOUBLE DIODE ISOLATE EACH WIRE TO PREVENT FALSING
RF Latch GREEN/BLACK (-) AT THE BODY CONTROL MODULE PIN # A38
LR Latch BLUE/BLACK (-) AT THE BODY CONTROL MODULE PIN # A44
RR Latch BLACK/WHITE (-) AT THE BODY CONTROL MODULE PIN # A39
Parking Lights BROWN (+) AT THE HEADLIGHT SWITCH OR PIN #A48 IN A GRAY
CONNECTOR AT THE BODY CONTROL MODULE
Low Crr Pk Lights BROWN/WHITE AT THE HEADLIGHT SWITCH OR PIN #A7 IN A GRAY
Remote Start
Accessory 1 WHITE/RED (+) IGNITION SWITCH HARNESS
Tachometer (AC) UNCOMMON WIRE AT THE COIL PACK OR AT ANY FUEL
INJECTOR
Low Crr. Pk Lights BROWN/WHITE AT THE HEADLIGHT SWITCH OR PIN #A7 IN A GRAY
Brake Lights LIGHT BLUE (+) AT THE BRAKE PEDAL SWITCH
Reverse Lights LIGHT GREEN (+) AT THE FUSE BOX UNDER THE HOOD
Horn GREEN (-) AT THE STEERING COLUMN HARNESS OR AT THE BODY
CONTROL MODULE PIN # A25 IN A GRAY CONNECTOR
Doorlocks/Windows
Power Unlock DARK BLUE (-) IN THE DRIVERS KICK PANEL OR PIN A12 IN A BLACK PLUG AT
- Note TO UNLOCK JUST THE DRIVERS DOOR ONLY, PULSE THE WHITE WIRE AT THE BCM, PIN # A12
PowerLock LIGHT BLUE (-) IN THE DRIVERS KICK PANEL OR PIN A11 IN A BLACK PLUG AT
Driver Mtr Unlock TAN (REV) AT THE LOCK SWITCH IN THE DRIVERS DOOR
Driver Mtr Lock GRAY (REV) AT THE LOCK SWITCH IN THE DRIVERS DOOR
Pas Mtr Unlock TAN (REV) AT THE LOCK SWITCH IN THE DRIVERS DOOR
Convenience
All Hazrd Lights WHITE (-) AT THE HAZZARD SWITCH OR AT THE BODY CONTROL MODULE
PIN # A48
Parking Brake LIGHT BLUE (-) AT THE PARKING BRAKE SWITCH
Modules
Module 1 BCM - BODY CONTROL MODULE IS LOCATED IN THE PASSENGERS KCIK PANEL
Documents
700065 POLARITY CONVERTER
Camperman
http://www.DFWCamper.com
Mesquite, Texas 75150
214-327-6848
04 Crew Cab White Z71
My Gallery
CamperMan is offline
post #7 of 15 (permalink) Old 03-14-2005, 09:52 PM
I'm lookin for a wire that is on until the door is open and the keys are off..basically when the radio shuts off the amps are off
JasonHardin is offline
post #8 of 15 (permalink) Old 03-14-2005, 10:30 PM
naskie18's Avatar
Any idea which of the 5 wires there is the starter wire?
naskie18 is offline
post #9 of 15 (permalink) Old 03-26-2005, 10:36 PM
Send a message via AIM to Futuresweets-10
Our trucks have no starter wire. Its a class II data bus system
I'm gonna stop looking back start moving on
And learn how to face my fears
Love with all of my heart make my mark
I wanna leave something here
Go out on a ledge without any net
That's what I'm gonna be about
Yeah I wanna be running when the sand runs out
Futuresweets-10 is offline
post #10 of 15 (permalink) Old 04-03-2005, 11:56 PM
jax
Send a message via AIM to jax Send a message via MSN to jax Send a message via Yahoo to jax
You can use the power window wire. or go out to the fuse box and tap into #42
04 Ext Cab Colorado ZQ8 LS. Summit white, PCMforLess tune, Volant CAI & Ram Air scoop ( 1st one ot have it ), Denso ITV16 Iridium spark plugs, Bedrug, Truxedo Lo-Pro, Dynomax super turbo muffler ,2 inch drop in the back, 3 piece billet grill, custom dual siren dual horn alarm.
jax is offline
post #11 of 15 (permalink) Old 05-03-2015, 09:51 AM
rear window switches
I need to know what wires are which out of the window switches. having trouble matching them up with power to motor. had to replace everything and now I dont know what is what. I have the thick blue, black, yellow, brown. then there are a thin yellow,blue brown and green.
I am working with power , ground and then the up and down on the motor. any hepy would be good.
thnaks
Seven is offline
post #12 of 15 (permalink) Old 05-03-2015, 10:02 AM
to C'Fans. I sent you a PM.
post #13 of 15 (permalink) Old 01-07-2016, 04:53 PM
where can I find reverse light power and parking brake power behind the radio
Jay Firm is offline
post #14 of 15 (permalink) Old 01-07-2016, 06:01 PM
to C'Fans.
Any way you can find out what year truck you are referring to and what model?
post #15 of 15 (permalink) Old 01-08-2016, 08:57 PM
naskie18's Avatar
Huh?
"Parking brake power"? I don't even know what that means (unless the parking brake on the new trucks is electrically activated, on the first gen it was mechanical. I haven't paid enough attention to the new trucks to notice the parking brake).
Reverse light power would likely best be found on one of the a-pillars, as that is something that is run to the rear view mirror connector, but I'm not sure up which a-pillar the harness runs. I would guess that it heads that way from the kickplate in front of the door, but again, I'm not sure which side.
If your questions are about a first gen truck, you can find the wiring schematics here.
If you're talking about a second gen, I would guess that there is a reverse power wire somewhere behind the radio to control the camera display.
naskie18 is offline
