AAM 800 axle specs - Page 2 - Chevy Colorado & GMC Canyon
post #21 of 25 (permalink) Old 11-08-2008, 04:30 PM
Re: AAM 800 axle specs
Originally Posted by TX blackout
well thats one less complication then, if someone were to do the swap. i know for fact that for the cfans in dallas, an 8.8 complete from disc to disc can be picked up for $30. i've done it several times.
Very true. They're a dime a dozen around here.
Lifted Club Member #179
TOTW Winner Week #31 2008
Gun Toting American Club Member #55
CAI, Gutted Cat, Magnaflow, PCMforless Tune, New Head! (Thanks GM), Supermod PTB, Vette Servo
2" TB Crank, BJ flip w/1/4" Spacer, 2" Procomp AAL, Air Shocks, 1" BL
**SINSITY KUSTOMZ**
jrbyers96 is offline
post #22 of 25 (permalink) Old 03-28-2009, 05:23 AM
Anyone have the ratio between tire dimensions as they relate to gearing...
35"s vs 33"s vs 32" for example.
Curious since tire size not only effects torque forces. Also throws off your speedo readings as well as mpg when you change from stock to bigger shoes.
wpage505 is offline
post #23 of 25 (permalink) Old 05-29-2009, 07:41 PM
well, i have 33" with 4.10, and is perfect
31" in the colorado 3.73 is perfect too
but 35 is better whit 4.56.
if you want 33" whit star speed and control in very slow spedd you can use 4.56 .
another hinks, i am from sur america, i buyed a colorado made in usa, but the rear diferential said aam 40035366 h115071709, power lite, i dont nokw its full float o semi, its limit slip or normal, i have abs but the light of a car sig sag dont turn on?????
the problem is the colorado sell here dont said z71 or z08, nothings, then the specifications is no clear
thnaks
robell is offline
post #24 of 25 (permalink) Old 09-24-2010, 12:28 PM
Does anybody know the width of our axles WMS-WMS? Are they all the same? I'd read somewhere that the Z71 axle was 2 inches wider than the Z85? Anybody with a Z71 care to measure?
Chris_B is offline
post #25 of 25 (permalink) Old 12-04-2011, 08:20 AM
Hi, I'm new to the forum. I have a 05 Colorado ext cab LS Z85. The Ford 8.8 is a popular swap into Jeep YJ's (the ones with the square headlights). The width of these axles is 59.5" WMS to WMS if not mistaken. The swap would be great if it's not to wide. There is a C-clip eliminator kit on the market. Superior Axle and Gear makets one called the Super 88. It comes with everything to get rid of the c-clip and chrome moly shafts. The draw back is having to redrill them for 6 lugs
sgt1022 is offline
