AAM 800 axle specs - Chevy Colorado & GMC Canyon
post #1 of 25 (permalink) Old 02-08-2006, 08:33 PM Thread Starter
AAM 800 axle specs
Specs on our axle is as follows:
AAM 800 PowerLite Aluminum Housing
PowerDense Ring Gear Diameter: 205mm / 8.071 in.
Axle design Salisbury and Independent
GAW rating: 1450kg / 3197 lbs.
Axle Torque Capacity: 4750Nm / 3508 lb. ft.
Gear Range Ratio: 3.08 - 4.56
Differential Options: Trac-Right Series
http://www.aam.com/technology/tech_prod ... raxle.html
Conservative Club Member #52
Lifted Colorado Club Member #32
'05 Colorado Z85 reg cab, Victory Red, 2.8/MA5, 4.11's
3" Fabtech Spindles / Bubaloo's shackles
'06 Tahoe wheels / Bridgestone 265/70/17's
05colly is offline
post #2 of 25 (permalink) Old 04-18-2006, 01:09 PM
Send a message via AIM to 2trackr
so does anyone make a locker or posi....aftermarket...i dont want to pay 1300 to the dealership for a factory one...
2TRACKR
2006 GMC Canyon
2" TB keys, 2.5" AAL, 1" Body lift, 33/12.50 BFG AT's, 2 8" ProComp lights
and much more to come as soon as i get my welder
you can see pics at the link below, click 2trackr then pics
www.bandofmudders.com
"Wheeling is about going places other people can't. If it were easy, everyone would be doing it and it wouldn't be any fun.
2trackr is offline
post #3 of 25 (permalink) Old 04-18-2006, 07:18 PM Thread Starter
Not at this time. I talked to a tech at randy's ring and pinion when i ordered my gears, and he told me that they only available unit was the factory gov-loc. He said he could get me one for about $550 plus the install kit which i think was about 80 bucks. I just said no thank you because im not paying $550 for a crappy gov-loc, i'd rather wait until Detroit or some other company makes a lunchbox locker for about $200. With the 32's im running on my truck i don't think i'll have a problem with them snapping splines off. Lunchbox lockers have a bad reputation for that on 10 bolt fullsize trucks....but i think alot of that is just guys running too big of a tire on 1/2 ton drivetrain and wheeling hard.
Gov-locs are fine if all you do is stay on pavement and you want better dry traction, but if your into offroading they really stink. Most of the time you have to hold your foot slightly on the brake when you have one tire in the air because there isn't enough resistance to get the posi to engage. I had the same problem in my Silverado whenever i would have one tire off the ground.
05colly is offline
post #4 of 25 (permalink) Old 05-02-2006, 09:42 PM
Send a message via AIM to SlowTA
what about horsepower and tq ratings? i read through that site briefly and they didnt mention anything about it? im looking more towards on road high performance vs. off road traction.
1991 Trans Am-Few bolt ons, best run to date 14.35@95mph
2004 Colorado-Belltech 2/3 drop (4203/3" blocks), 245/45zr17 Hankook Ventus V4 ES H104 tires, debadged, dumped bassani exhaust, billet grille and bowtie--Best time before exhaust 16.45@82mph w/2.2 60'
SlowTA is offline
post #5 of 25 (permalink) Old 05-03-2006, 12:21 AM Thread Starter
Use a torque multiplication equation to figure out the maximum engine torque. Most of the time, axle torque ratings are pretty conservative because they normally use a double multiplication. Basically, they rate the axle at what torque one axle shaft could withstand before breakage.
05colly is offline
post #6 of 25 (permalink) Old 03-12-2007, 06:17 PM
This is what I was looking for!
Thanks!
This should be a sticky...
2004 Colorado Z71 4x4 Extended Cab
H3's w/ Goodyear MT/R 265/75/16
TB Crank
K&N Drop in filter
PCM's 4 Less Tuned PCM
Amsoil 0w30
Lifted Colorado group member #37
Mud Club member #3
http://www.wi4x4.com
Amsoil dealer... let me know what you need!
joeclark4725 is offline
post #7 of 25 (permalink) Old 03-13-2007, 01:17 AM
By the way - ours is a locking differential not a posi-traction device. And I've had no problems with it offroad except when I have the open front differential unloaded ( aka tire in the air ).
rangerbob is offline
post #8 of 25 (permalink) Old 04-15-2007, 01:46 PM
nothing better then a tight posi ! I ONLY HAVE A LOOSE LOCKER, it takes alot of wheel spin to make it lock
bajated is offline
post #9 of 25 (permalink) Old 04-15-2007, 03:18 PM
Really? I can cause it to lock by launching. Maybe you need more power?
post #10 of 25 (permalink) Old 04-15-2007, 11:08 PM
lead foot locker
bajated is offline
post #11 of 25 (permalink) Old 05-16-2007, 05:15 PM
Send a message via AIM to dr_mario_05
Is this axle stronger than the GM 10 bolt? 7.65"
modded 1995 Z28
2006 colorado Z85 2.8 5spd
V-8's are better than Vtec
dr_mario_05 is offline
post #12 of 25 (permalink) Old 09-07-2007, 11:13 PM
do we have 28 spline axles?
ASE Master Techician, L1 Certified, Chevrolet Tech
GM Diesel Master Certified, GM Brakes Master Certified
2006 Colorado 4cyl 4x4 5spd Standard Cab
Pioneer HU, Polk 6 1/2's in Front Doors
Pioneer 200w Amp pushing Polk 6x9's in boxes
GM color matched, chrome grille
30% Tint on Side windows, Limo on rear
K&N Cold Air Intake
ChevTech06 is offline
post #13 of 25 (permalink) Old 06-18-2008, 09:07 PM
Re: AAM 800 axle specs
Ok i want to get a g80 can some one fill in the info on Spline and rear size/model please.
vadimm is offline
post #14 of 25 (permalink) Old 06-19-2008, 12:35 AM
^^^^ Uh..... The size and model are at the top of the phacking thread.....
post #15 of 25 (permalink) Old 06-19-2008, 08:48 PM
Send a message via AIM to Jhartcolorado
phacking??? lol.
JHart
TOTW WINNER WEEK #35
Jhartcolorado is offline
post #16 of 25 (permalink) Old 06-20-2008, 12:16 AM
Bloody word censors.
post #17 of 25 (permalink) Old 10-27-2008, 10:21 PM
I'm surprised that no one has built a conversion kit for a Dana 44 or ford 8.8 into a Colorado!
Lifted Member #167
canarado is offline
post #18 of 25 (permalink) Old 11-07-2008, 03:07 PM
Send a message via Yahoo to TX blackout
the late 90s explorers were 31 spline and disc braked... lot of aftermarket crap available for 8.8s as well... detroit, yukon, randy's and superior all make parts. the only draw back to the 8.8 is that it is a c-clip axle, but i THINK there is a semi floater conversion kit.
is our speedo run out of the rear diff the same as ford?? with the little magnetic VSS doodad??
i am BRAND NEW to Colorado tech... but from the axle swaps i have done in the past, i cannot imagine that stuffing an 8.8 would be that difficult. not sure about WMS-WMS differences, but you would have to drop a pretty penny for 8.8 shafts drilled out to match the collie bolt pattern.
food for thought.
i managed to get a fw HP d44 under my 2000 ranger... and i'm not dead (yet.)
NIX
Gun Toting American Club member #59
FOR SALE: 04 ZQ8 COILS, and z71 lower valance/airdam combo open to offers.. PM me
adam.nix.usmc@gmail.com
TX blackout is offline
post #19 of 25 (permalink) Old 11-07-2008, 03:15 PM
The speedo is run off of the transmission.
post #20 of 25 (permalink) Old 11-07-2008, 04:41 PM
well thats one less complication then, if someone were to do the swap. i know for fact that for the cfans in dallas, an 8.8 complete from disc to disc can be picked up for $30. i've done it several times.
NIX
