AC help...speed 4 only works sometimes - Chevy Colorado & GMC Canyon
post #1 of 16 (permalink) Old 04-27-2016, 04:41 PM Thread Starter
I think I ordered the wrong parts. My Fan only works on 4 sometimes my burnt pins are in the main connection behind the glove box. If I move the wires there it works sometimes. Can someone help me with the parts needed for that fix?
pwoller is offline
post #2 of 16 (permalink) Old 04-27-2016, 05:02 PM
Look Here.
War Dang Eagle !!!
2016 Lazer Blue Long Bed Crew Cab
Cut the Dang Wire Already!!!!!!!!!!!!!!!!!!!!
WDEagle is offline
post #3 of 16 (permalink) Old 04-27-2016, 06:56 PM
to C'Fans
Are you referring to the 10 wire inline connector attached to the face of the HVAC case? If so, are the burned pins just in one side of the connector, or both?
What model and year is your truck?
cart7881 is online now
post #4 of 16 (permalink) Old 04-27-2016, 08:57 PM Thread Starter
Its a 2004 Colorado z71 LS extended cab yes the plug that has 10 going in and it is both sides of the plugs and just one pin. Thanks for the help and the welcome.
pwoller is offline
post #5 of 16 (permalink) Old 04-27-2016, 09:07 PM Thread Starter
I also noticed my blower moor cooling tube is gone......
pwoller is offline
post #6 of 16 (permalink) Old 04-27-2016, 09:31 PM
Okay, I'm guessing the terminals for the Orange wire are the ones burned. For a temporary repair you could cut the wires, get a length of 14 gauge wire and splice a jumper around the connector. A proper repair will require replacing the connector assemblies or replacing the burned pins if the connector isn't damaged.
The connectors are available, with pigtail wires, from RockAuto, part numbers 15306309 and 15306305, but the two total about $60 + shipping. Depending on your capabilities, you could replace the pins fairly cheaply. It would require some disassembly of the connectors. I have supporting information if you decide to pursue that option.
I have no clue what a blower motor cooling tube is. Can you get a picture?
post #7 of 16 (permalink) Old 04-27-2016, 10:00 PM Thread Starter
I'm thinking of splicing it for now thanks or the info. I did get the part with 4 pin s that seems to the more common failure point out and its got burned pins too.
pwoller is offline
post #8 of 16 (permalink) Old 04-27-2016, 10:01 PM Thread Starter
I cleaned up the ground points and retightened them. Hopefully this all gets me back working. Thanks!
pwoller is offline
post #9 of 16 (permalink) Old 04-27-2016, 10:18 PM
This happened to me, here's what I found. Behind the glove box a couple of wires had rubbed on a bracket causing a short. I wrapped the wires with tape, problem solved. Good luck
Johnny Potatoes is offline
post #10 of 16 (permalink) Old 04-27-2016, 10:25 PM Thread Starter
The burnt wires in the big plugs are brown thicker wires. Down under the dash in the 4 pin plug they are blue green. I will wait till you advise before I splice anything.
pwoller is offline
post #11 of 16 (permalink) Old 04-27-2016, 10:27 PM Thread Starter
About the cooling tube. Its a drain looking plug on the bottom of the blower motor. I didn't know about it till I looked at the diagram either. Is it needed?
pwoller is offline
post #12 of 16 (permalink) Old 04-27-2016, 11:06 PM
This is a bit confusing. The Brown wires are the 12 volt side of the blower motor circuit. The wire goes from the blower fuse in the fuse box, through that 10 pin connector and to the blower motor connector. If that wire is defective, the problem should show up on all blower speeds selected. Yes, you would need to repair that Brown wire. If you also have burned pins at the resistor module you may need a new connector. ACDelco part number PT1231, GM part number 15306069. Amazon $22.55. You have already purchased a resistor module?
Cleaning the grounds was a good idea.
In the Service Manual I see the tube that you are referring to. So far I haven't found a link to it. A Dealer might be able to help as they have detailed parts breakdowns.
post #13 of 16 (permalink) Old 04-28-2016, 12:17 AM Thread Starter
Yes I do have an issue at all levels of blower power but at 4 if I move the connector around it will work for a while. Can I still splice around the connector for the brown wire? I have the other wires coming.
pwoller is offline
post #14 of 16 (permalink) Old 04-28-2016, 06:14 AM
Yes, there isn't any reason that you can't splice a jumper around the connectors for any of the circuits. The Brown wire is 2mm (14 gauge) so try to get that size for the jumper. Leave enough slack to allow the connectors to be separated if necessary.
post #15 of 16 (permalink) Old 04-29-2016, 12:16 AM Thread Starter
Ok I spliced around the connector for the brown wire and I have speed 4 again. Waiting on the parts to do the rest of the repairs.
pwoller is offline
post #16 of 16 (permalink) Old 04-29-2016, 06:28 AM
Thanks for the update. Let us know what happens with the other repair.
