2005 GMC tow hooks (front) - Chevy Colorado & GMC Canyon
post #1 of 4 (permalink) Old 06-07-2016, 10:54 AM Thread Starter
scrambler41's Avatar
Hello I am new to trucks as a 2005 GMC canyon is my first truck and I would like to do a little offroading. So I would like to know how one would install front tow hooks on the 1st gen canyons, and where I can find them.
Thank you
scrambler41 is offline
post #2 of 4 (permalink) Old 06-07-2016, 11:38 AM
Well, I can give you the information for the easiest install, which is OEM. Not the cheapest though. The holes should already be in the frame. Just look through the lower opening in the grill. There should be two holes in the frame, on each side.
Hook: GM 15163526
Bolt: GM 11589282
Nut: GM 11514598
I'm sure there are less expensive aftermarket options available. Hopefully someone will drop by and provide the info.
cart7881 is online now
post #3 of 4 (permalink) Old 06-07-2016, 11:49 AM
Krypton fabrication makes these...
http://www.krfabs.com/product_detail.php?productID=15
You will have to buy the shackles for them separately. Those are just the mounts
GregDAP is offline
post #4 of 4 (permalink) Old 06-07-2016, 11:55 AM
Looks like oem hooks may be cheaper though
GregDAP is offline
