How To: Add a GM Fog Light Package - Page 3 - Chevy Colorado & GMC Canyon
post #41 of 81 (permalink) Old 09-11-2004, 01:00 PM Thread Starter
Nova,
Thanks for reading, I know it's long for a post, But I intend to add pictures and diagrams that will help a bit. It's intened to be step by step for anyone to be able to follow.
Odie,
Do you mean the size of the hole in the housing that needs cut? Not sure what you want there?
Ken Deatrick
1957 BELAIR 4 DOOR HARD TOP
My CarDomain Gallery
kdeatrick is offline
post #42 of 81 (permalink) Old 09-11-2004, 01:06 PM
no, the actual fog light itself
odie99 is offline
post #43 of 81 (permalink) Old 09-11-2004, 09:36 PM Thread Starter
The bulb is 8" wide x 5" high. From the bulb to the rear of the housing is 5 1/2" deep.
The Bumper Housing cutout is smaller than the bulb itself.
Ken Deatrick
post #44 of 81 (permalink) Old 09-11-2004, 10:48 PM
by bulb, i assume you're talking about the glass portion at the front of the housing. so i'm looking at 8x5x5.5 ish.
thanks
odie99 is offline
post #45 of 81 (permalink) Old 09-11-2004, 11:26 PM Thread Starter
yes the bulb dimensions are the glass portion. I should have said lense. So it woiuld fit in a square box 8x5x5.5 ish.
Ken Deatrick
post #46 of 81 (permalink) Old 09-12-2004, 10:02 AM
(Sorry I haven't responded in a while... been a little preoccupied by the onslaught we're taking down here in the "sunshine" state.)
As for your instructions post... looks good! It seems to be a lot more involved than I anticipated, but no doubt cheaper than having the dealer install it. Pictures will definitely help. Perhaps you could also list where you got each part and for how much $.
Scott
'04 Z85 Crew Cab
Silver Birch, Medium Pewter Leather
I-5, XM, 6-disc
Truxedo Lo Pro, Line-X
My Pics
Gr8 G8r is offline
post #47 of 81 (permalink) Old 09-17-2004, 09:09 AM
Send a message via Yahoo to SONG
A deer ran out in front of me last night and I bright lighted to get a better look. Throwing my brights on killed my fogs. Is this normal? If so, did you wire yours to do the same?
Conservative Club Member #8
SONG is offline
post #48 of 81 (permalink) Old 09-17-2004, 03:11 PM Thread Starter
Yes, that is done by LAW.
In most if not all states, it is illegal to have fog lights on with high beam head lights.
The Logic on the the Fog Lamps is:
On if:
1. Ignition on, Fog Lamp switch on & park lamp switch on.
2. Ignition on, Fog Lamp switch on & head lamp switch on with low beam selected.
3. Ignition on, Fog Lamp switch on & light sensor low light condition on with low beam selected.
They will be off when any of these change.
1. Fog Lamp switch is off.
2. Ignition off.
3. High Beam is selected.
Ken Deatrick
post #49 of 81 (permalink) Old 10-14-2004, 08:19 PM
What's weird is that on the '05 Canyon, the fog lights *are* an accessory on the Z85 and is available without the Color Keyed Appearance Package. You also get a leather wrapped wheel outside of this package on the Canyon. I wonder who dreams up these packages?
Fitz
Keep The Open Road Open - Ship By Rail
Fitz Ingarage is offline
post #50 of 81 (permalink) Old 10-14-2004, 10:27 PM Thread Starter
Did you find that on Gmbuypower? It maybe a mistake. Lat I checked the '05 online order guide it was still the same as last year.
But if they changed it maybe because we bitched enough!
Yeah that's it they made it available because I called and told them they were idiots and should make it available. :
Ken Deatrick
post #51 of 81 (permalink) Old 10-15-2004, 06:56 PM
Originally Posted by kdeatrick
Did you find that on Gmbuypower? It maybe a mistake. Lat I checked the '05 online order guide it was still the same as last year. ...
Yes, it was GM BuyPower alright. GMC also fails to mention the "center console with storage and armrest" with the bucket seats, which must be an error as well. Yeah, it's nuts. I want metallic paint, so can't get the Appearance Package and its features. An auto parts store can supply me with a leather kit for the steering wheel, but as we know from the discussion here, factory fog lighte are another matter ....
Fitz
post #52 of 81 (permalink) Old 10-15-2004, 07:01 PM Thread Starter
After having the installation behind me and figuring out all the details, I'd now say it is a very easy installation.
Ken Deatrick
post #53 of 81 (permalink) Old 01-29-2005, 11:29 AM
GREAT post kdeatrick!!!! I was considering this retrofit already for next year when its nice out nut after reading your instructions I am going to do it. I will be sure to post the results then. Thanks again for going through the details of this.
05 Canyon SLE Z85 4x4. 1989 Pontiac Formula 350, and 1990 Pontiac 6000 LE.
My Gallery
dcjredline is offline
post #54 of 81 (permalink) Old 01-31-2005, 12:14 AM Thread Starter
I posted this elsewhere, but will here as well.
I have not yet verified the pinouts on the 2005 model. I doubt they have changed the pin outs, but I do know that according to the service manual they've added a new fuse location for the sunroof.
That would be on a different terminal underneath the fusepanel since it is on the harness going to the cab.
Ken Deatrick
post #55 of 81 (permalink) Old 01-31-2005, 01:56 PM
I am going to customize mine a bit though. I do NOT like the fact that the factory shuts them off with highbeams so I am not going to do the harness pinout thing I am going to mount the FACTORY ones and wire into a factory switch with the option. Then I can do what I want and if the factory switch wont do what I want then I will use a mini switch and wire it that way.
My Gallery
post #56 of 81 (permalink) Old 01-31-2005, 07:30 PM Thread Starter
dcjredline,
If you want to do it like that don't waste your money on buying a factory switch for the fog lamps.
It does not directly switch the fog lamps, it tells the BCM to give the fog lamps voltage. It may sound odd, but there is a difference.
You should have no trouble just adding a rocket switch type setup. I just wanted the factory functionality and look.
Ken Deatrick
post #57 of 81 (permalink) Old 03-01-2005, 10:38 PM
I found the lamp assemplies for less here:
http://www.carpartswholesale.com/cpw/in ... l=COLORADO
2004 Z85 Victory Red, Reg. cab, 4x4, I5, 5 Speed,
AC, AM/FM,. Truck totaled, so sorry it's gone.
Now 2005 Sunburst Orange Z85 I4, 5spd, 2WD, AC, AM/FM putting my cap and bedgrug from my 2004 on the 2005 after getting the cap painted Sunburst Orange to match the truck.
SlayerD is offline
post #58 of 81 (permalink) Old 04-27-2005, 08:45 AM
OK, I'm finally going to get started on this mod.
Ken, are any of the parts different between the Crew Cab and Ext. Cab? (such as the switch module or wiring harness)
And regarding the above post by SlayerD, I assume the right and left fog light assemblies are the same? (site says RH=LH)
Scott
'04 Z85 Crew Cab
I-5, XM, 6-disc
My Pics
Gr8 G8r is offline
post #59 of 81 (permalink) Old 08-24-2005, 08:25 PM Thread Starter
gr8 c8r,
did you ever add them?
How about anyone else?
In looking at the new option packages I think it's now possible to get them in the one lt package.
Ken Deatrick
post #60 of 81 (permalink) Old 08-24-2005, 10:40 PM
I did it earlier this year. I bought the oem harness, relay, lamps and switch. Then just ran the wiring from the switch to the BCM. I checked with the dealer before I wired em up and in all there vast knowlage told me all BCM's were coded for the lights so no flash was needed.
06 Silverado 2500hd
6.0
4x4
GreatWhiteColorado is offline
