max wheel size 2005 colorado ls 4x4? - Chevy Colorado & GMC Canyon
post #1 of 8 (permalink) Old 07-30-2011, 12:41 PM Thread Starter
Hi guys, I am knew to this forum and new to Chevrolet trucks all together so bare with my amateur questions.
Currently i have a 2005 COlorado LS 4x4 crew cab with 15x6.5 wheels and 235/75/r15 tires (the stock items which come with the car).
I was wondering, what is the maximum size tire and wheel I could get without adding any lift kits or suspension lifts of any kind? I noticed some car sites say you can add an optional 16, 18, 20, or 22 wheel, but i can only assume for something as big as a 22 you'd need a mod. Will 18's fit?
(ps - i like the look of wide tires that stick out a bit, i.e. my old explorer has 16x8 wheels with 255/70/r16 tires)
xvertigox is offline
post #2 of 8 (permalink) Old 07-30-2011, 05:36 PM
Good luck getting someone to answer. I asked the same question on here with no help. I just ordered 16x8 4.5 backspace and 0 offset with 255/70/16 I just hope they fit. I done a lot of calling around and have be told this will work. I don't have a lift of any kind. I will be getting them next week. Hope this helps some.
Tacker is offline
post #3 of 8 (permalink) Old 07-30-2011, 05:47 PM Thread Starter
this definitely helps, i had no direction before. Its hard to just doing regular google searching.
Do you think you could let me know how they work out for your truck when you put them on? I am not gettin mine till i sell my old explorer so I have some time to learn more.
let me know how that size works out for ya, good luck!
post #4 of 8 (permalink) Old 07-30-2011, 07:22 PM
enforcer's Avatar
Easy guys, this site just went through some changes and the old "unanswered posts" option disappeared. I have found the members here quite helpful, but they do have day jobs and aren't always lurking around.
I only have a Z71 4x4, and no experience with other set ups, so I would not want to give you unsound advice.
You generally can't go too much bigger than stock size without adjusting your suspension, or you will get rubbing depending on what you buy. One of the internet tire sites has a comparative calculator that you can plug in combinations and see what is compatible for overall diameter.
For instance, I have a 265/75/15, and it says I can go 245/70/16, or even go 18" with 235, but I have to ensure the new rims will fit my truck and its brakes (ie aftermarket rims). By reducing tire size you hold your circumfrence within your limits.
Backspacing is another matter, and I think I've seen 4.55 as the benchmark here in the past (but don't go wih my opinion without confirming anything for yourself).
Just take your time comparing wheels and tires, and price out your options before spending your hard earned money.
traded my 2006 Chev Colorado Z71 4x4
black extended cab 3.5 L
MagnaFlow Single Side Stainless Cat-Back
GM Performance CAI
Xenon Gas White headlights
Spyder tailights and smoked third brake light
enforcer is offline
post #5 of 8 (permalink) Old 07-30-2011, 07:42 PM
u can fit almost any size rim you would want.......u wanna stay around a 4.5backspacing....dont go under 4inch, and try not to go over 5inch....as for tires its a different story....U should be able to fit a 31x10.50 with no mods....I think....ur truck is pretty much the same as a z71 just not as pretty.....so i would try to stay around that size.....
And A Few Mods...
Koda22 is offline
post #6 of 8 (permalink) Old 07-30-2011, 07:43 PM
Going UP!
Send a message via AIM to blurred
This is possibly why:
Chevy Colorado & GMC Canyon - Search Results
blurred is offline
post #7 of 8 (permalink) Old 07-31-2011, 06:14 PM Thread Starter
thanks for the responses. I will do some more research and ill post back when i actually go through with the purchase
post #8 of 8 (permalink) Old 09-08-2011, 02:51 AM
puedo enviarle el programa para calcular las medidas maximas,,, saludos, my mail is farmor66@hotmail.com
farmor66 is offline
