Factory part numbers..keep updating as numbers come in - Chevy Colorado & GMC Canyon
post #1 of 59 (permalink) Old 01-02-2007, 11:02 PM Thread Starter
Factory Part Numbers that we commonly ask for. When you find a part number post it up.
Exterior:
HOW TO INSTALL PASSENGER SIDE KEY LOCK
FOR 2004-2006 TRUCKS WITH MANUAL DOOR LOCKS
P/N - Qty Needed - Part Description - GM List Price Each
#19121155 ..... 1 .... RH Door Lock Cylinder .................... $36.98
N/A .............. 1 .... Key Match to New Cylinder .............. $0.00*
#15847170 ..... 1 .... RH Door Handle w/ Lock Hole ........... $35.26
#11516421 ..... 2* .. RH Door Lock Cylinder Bolt .............. $4.25
#15931323 ..... 1 .... RH Door Latch with Key Lock Rods .... $57.63
*Notes:
- Some may have to pay for having the lock keyed to match
- You can avoid buying the orginal GM Bolts by going to Lowes and picking up a $.98 bag of M6 x 1.00 x 10 Hex Cap Bolts
Prices Listed are "GM List" try http://www.newgmpartsusa.com/ or http://www.gmpartsdirect.com/ for better prices.
HOW TO DO THIS MOD: CLICK HERE
Fender Flares
Large (Z71) fender flares Black: #12498934
Large (Z71) fender flares Blue: #12498935
Large (Z71) fender flares Gray grained: #12498848
Large (Z71) fender flares Red: #12498938
Large (Z71) fender flares Silver: #12498937
Large (Z71) fender flares White: #12498936
Small (ZQ fender flares Blue: #12498850
Small (ZQ fender flares Gray Grained: #12498849
Small (ZQ fender flares Red: #12498853
Small (ZQ fender flares Silver: #12498852
Small (ZQ fender flares White: #12498851
Cheapest place for fender flares CLICK HERE
Part No. Desc. Price For Xtreme Kit
Xtreme headlamps - GM Part #10365773 - LH/ #15228012 - RH
Xtreme bumper lights- GM Part #10360880 - LH/ #10360881 - RH
Xtreme Emblem -#10366203
08304/ 88981093 | Molding | 267.11
08304/ 88981092 |Molding K | 267.11
17505/ 88981108 |Flare PKG | 190.00
17505/ 88981065 |Flare PKG | 190.00
08304/ 88981103 |Molding K | 149.57
08304/ 88981104 |Molding K | 149.57
08304/ 88981097 |Molding K | 149.57
08304/ 88981096 |Molding K | 149.57
08304/ 88981089 |Molding K | 267.11
08304/ 88981088 |Molding K | 267.11
88981088 |TailGate Spoiler | 280.00 guestimation
07831/ 10366204 |Bracket | 16.25
07831/ 10365707 |Grille | 203.39
07831/ 10365709 |Grille | 66.10
07831/ 10365708 |Grille | 66.10
07831/ 88981086 |Fascia | 457.98
08228/ 10365713 |Pad | 51.87
08228/ 10365712 |Pad | 80.44
07831/ 88981087 |Fascia- RR | 442.58
89045537 |Bumper RR bar | 330.00 (roughly
07831/ 10366205 |Bracket | 16.25
Grille Retainer Clips -GM Part # 89045535
Push-pins - GM Part # 11519444
Valence - GM Part # 15113910
RH Latch- GM Part # 10395380
RH O/SIDE HANDLE- GM Part # 15847170
RH Key Cylinder -GM Part #19121155
right rear bed brace #97313161
right rear wheel well liner #15140527
Recovery Hook: #15163526
Fog Lamp: #15898306
Body Side Molding (Reg Cab, '07) Not sure on L/R designation
Doors: #15218576/ #15218575
Cab: #10358741 (Quan-2, same ea side)
Bed: #15218564/ #15218566
DRL wiring harness #19121867
Interior:
Auto trans xtreme gauge cluster - GM Part # 15829921
Manual trans xtreme gauge cluster - GM Part # 15144862
Power Lock Module - GM Part # 89047319
Power Lock Shield - GM Part # 15821718
Grab Handles - GM Part # 15134376
Center Console Manual Shifter -GM Part # 15112814
Non Center Console Manual Shifter -GM Part # 15112813
Very Dark Pewter Extended Cab Carpet for trucks with Buckets and Manual Transmission. #15869019
Engine and Drivetrain:
07 All aluminum Valve Cover 3.7- GM Part Number # 12603876
2006 TOTW Winner #45 l 2007 TOTW Winner #18 l 2008 TOTW Winner #27
Mods Click Here
dlucas is offline
post #2 of 59 (permalink) Old 01-02-2007, 11:21 PM
Good idea, I've been thinking we needed something like this for a while. I just never bothered making the thread.
04 Colorado ZQ8 I5/AT
If you can't afford to do it right, then how can you afford to do it twice?
brakenit is offline
post #3 of 59 (permalink) Old 01-03-2007, 12:32 AM
Send a message via AIM to sillyoldtayo
10366203 Xtreme emblem
TOTW #25...SWEEEEETRUCK!
sillyoldtayo is offline
post #4 of 59 (permalink) Old 01-03-2007, 03:18 AM
craig6970's Avatar
Send a message via MSN to craig6970 Send a message via Yahoo to craig6970
Good idea...^5
05 Colorado Z85 Summit White ext cab 2.8L 2wd, power nothing but my arm
W/T model upgraded with Extremes and a djm 3/4 drop
craig6970 is offline
post #5 of 59 (permalink) Old 01-03-2007, 07:16 AM
This is really an excellent idea. I've started an Excel Spreadsheet of Part Numbers and a brief description of the item. I'll try to keep it current as others post more numbers.
If there is sufficient interest and a place to host it I can convert it to a PDF file so others will be able to access and search it.
2006 Colorado Yellow Crew Cab
I4 Engine, Auto w/3.73 gears
(So far)
PCMforLess Chip, Line-X OTR, Custom Air-Intake, Magnaflow Muffler, RollBak Bed Cover, Chromed stock wheels.
debewley is offline
post #6 of 59 (permalink) Old 01-03-2007, 07:17 AM
craig6970's Avatar
Id like to get a copy if you want to share.
post #7 of 59 (permalink) Old 01-03-2007, 11:17 AM
Great idea! Thanks for starting this project. Next, we need to make it a sticky for everyone to easily access.
'08 4x4 regular cab, I-4, 5-speed (sold, but sort-of missed); '08 4x4 reg cab Silverado 1500
gtimark is offline
post #8 of 59 (permalink) Old 01-03-2007, 08:56 PM Thread Starter
added a couple more. keep um coming guys
Mods Click Here
dlucas is offline
post #9 of 59 (permalink) Old 01-04-2007, 01:17 AM
Some of the ones I have saved:
Xtreme headlamps: 10365773 - LH
15228012 - RH
Xtreme bumper lights: 10360880 - LH
10360881 - RH
"Oh chit!" bar - 15134376
Valence - 15113910
Push-pins - 11519444
Grounded Member #55
My Car Domain
rrcn is offline
post #10 of 59 (permalink) Old 01-04-2007, 09:16 AM
craig6970's Avatar
Shipwright Post subject:
Asked the dealer about the part numbers listed above (burn), I got these part numbers and prices...
RH Latch............... ...10395380.......$57.63
RH O/SIDE HANDLE...15847170........$35.26
RH Key Cylinder........19121155........$36.98
Fit Key............................................$25 .00
post #11 of 59 (permalink) Old 01-04-2007, 02:05 PM
Send a message via AIM to RedneckB790
how bout body side moldings? anyone have that?
RedneckB790 is offline
post #12 of 59 (permalink) Old 01-04-2007, 03:53 PM
How about the part number for a black ZQ8 Colorado grille shell? I don't really care for the Xtreme grille shell with the chrome trim.
Mike G.
2006 Colorado Crew Cab Z85 I5 - 20" Zinik's, 245/35-ZR20 rubber, McGaughy's 2/3 drop
rico1g is offline
post #13 of 59 (permalink) Old 01-04-2007, 04:23 PM
It'll probably be easier to get the Xtreme one.
I got a white Xtreme one with the chrome trim and it had a chrome grille insert.
I just poped the instert out and put in my own insert.
The part number for that is easy to get ahold of.
Grounded Member #55
My Car Domain
rrcn is offline
post #14 of 59 (permalink) Old 01-04-2007, 04:57 PM
Send a message via AIM to blaine517
does any body have the part number for the center console push pins? i need the white ones for the front of the console
blaine517 is offline
post #15 of 59 (permalink) Old 02-01-2007, 01:22 PM
craig6970's Avatar
part number for rear ext cab seatbelt guide
15027409 rear ext cab seatbelt guide. Its the little bunge cord holder for the seat belt
post #16 of 59 (permalink) Old 02-01-2007, 02:08 PM
mc
Re: Factory part numbers
Originally Posted by djlucas
I thought maybe we should start a thread of factory part numbers that we commonly ask for. When you find a part number post it up.
We can seperate it by where it goes on the truck,
Exterior:
Xtreme headlamps - GM Part # 10365773 - LH/ 15228012 - RH
Xtreme bumper lights- GM Part # 10360880 - LH/ 10360881 - RH
Xtreme Emblem -10366203
Interior:
mc is offline
post #17 of 59 (permalink) Old 02-01-2007, 02:14 PM
Send a message via AIM to Rsquires67
Nice work guys...
I need the part number for the interior driver side door handle. The black piece where my power window switches are. I have a crew cab.
VOTE for me please in TOTY!!!! viewtopic.php?f=24&t=67915
Rsquires67 is offline
post #18 of 59 (permalink) Old 02-01-2007, 05:27 PM
Send a message via Yahoo to philip_may
Awesome idea! I was just thinking about something like this the other day.
On that note... Does anyone know the part number for a 05 Xtreme crew cab center console, and left/right air vents by the doors? I want to take mine off and paint them, but I am scared I will screw them up. So I figured I would get a spare set and expirement with them. Thanks in advance!
Bubba
Black "05 Xtreme" Crew Cab
AEM Brute Force Intake
Flowmaster 40 Series
Extang Tonneau Cover
Bolt on T-Rex Billet Grille
Drop = 4203 springs up front, and 2" blocks out back
Black RTS's 20's
Grounded 355 member #33
MY CARDOMAIN SITE
philip_may is offline
post #19 of 59 (permalink) Old 02-10-2007, 10:47 PM
cool
zikronix is offline
post #20 of 59 (permalink) Old 02-27-2007, 08:40 PM
hey whats the part number for the Xtreme Gauge Cluster!??!?!
