Finding the correct Auto Transmission Filter kit… - Chevy Colorado & GMC Canyon
post #1 of 7 (permalink) Old 11-16-2008, 08:18 PM Thread Starter
I’m posting this to see if anyone else out there has had a similar experience and to hopefully help someone else who might be headed down the same road. I have a 2004 Colorado Ext Cab 4wd 3.5 liter.
I wanted to change my auto trans filer and oil, which usually is no big deal right? Well, I bought the filter kit and oil ahead of time from NAPA. This Saturday I finally found some time to actually do the job. I manage to get the pan off, not too hard. I get the old filter off and bring it to the bench. Hmmm, the new filter is shaped a bit different. Oh well, no big deal I thought. Oh how wrong I was. The pan would not go back on, there was at least ½ inch gap with the new filter hitting the pan specifically where the pan is tapered to allow clearance for the front drive shaft. Damn, those guys at NAPA gave me the wrong filter. I call them up, sure they say we have at least 4 different filters for the 4L60E trans. Bring in your old one and we’ll get it matched up. Well, I get there and no luck. They can’t find one that’s the same shape, however the one I originally bought, NAPA # ATP19750, was indeed listed in their books as the one for my truck. So, I call another store, they had a FRAM Ft1217 filter kit. I take it out of the box, same thing as the one from NAPA, wrong again. Well, by this time all the dealers are closed and I really need to get this thing finished by Monday. So I go home and start searching the internet. Turns out not only NAPA and FRAM list the incorrect filter, Purolator does as well, Part number P1267, at least the photo they show for it indicates it is incorrect as it looks the same as the NAPA and FRAM. I also discovered that they list the same filter kit for 2wd or 4wd. They only way I discovered that there are different filters for 2wd and 4wd was when I checked out the AC Delco site, 2 different parts numbers clearly marked one for 2wd, one for 4wd. Bad thing was I could not find any store who sold the AC Delco kit. Probably a dealer item. That’s when I found AutoZone. They clearly showed two separate kits, TF361 for the 4wd, TF351 for the 2wd. I had to drive an hour and half to the nearest Autozone to get the kit, but to me it was worth it to get the truck back running for work on Monday.
Having not seen a 2wd Colorado Auto Trans. Pan, I take it that it must not be tapered for the front drive shaft clearance in the same way as mine is, as a result these other filters would probably work. What stinks is that, I cannot believe that at least 3 different filter manufacturers list the incorrect filter. This turned a job that should have taken a few hours into a 2 day ordeal. Maybe there would not have been a problem had I went to the dealer in the first place, however I didn’t feel like paying an arm and a leg to get a simple filter kit that should be easily attainable at any parts store.
Well, if you don’t feel like reading my whole rant, you can obtain the correct Auto Trans filter kit for a 2004 Colorado, 4wd, 3.5 liter, ext cab at Autozone part number TF361.
Mike
2004 Colorado LS Ext. Cab
4X4
3.5L
Automatic Transmission
mikey945 is offline
post #2 of 7 (permalink) Old 03-12-2009, 12:01 PM
Re: Finding the correct Auto Transmission Filter kit…
Sorry to revive an old thread, but Im going through the same thing. I called NAPA and was told that there are 2 different filters, and to bring in my old one and they will match it up. I laughed and was like "If I have my truck all ripped apart, how am I going to drive there to match it up?" I guess Ill have to bite the bullet and get it from the stealership.
burn is offline
post #3 of 7 (permalink) Old 03-12-2009, 01:14 PM
Can you take a picture of your pan? Is it flat or does it drop an inch or so in the back? Does it have a drain plug? 2.8l or 3.5l? 2WD or 4WD?
http://www.amsoil.com/scripts/runisa.dl...loaf:index
Steve
jackedupcanyon is offline
post #4 of 7 (permalink) Old 03-24-2009, 11:19 AM
How many miles is the reco for trans oil change and filter service?
wpage505 is offline
post #5 of 7 (permalink) Old 03-24-2009, 12:05 PM
80,000KM for severe-use
160,000KM for regular-use
burn is offline
post #6 of 7 (permalink) Old 03-24-2009, 05:50 PM
Or 50,000 miles for severe-use and 100,000 miles for regular-use. Severe is also classified as frequently traveling less than 10 miles (16km) at a time.
Steve
post #7 of 7 (permalink) Old 04-05-2017, 12:57 AM
Wishing i would have read this earlier
I ran through this exact problem today.. An hour job turned into 6. I had to install the pan with the old filter and new fluid.. ill call it a mini flush. stopping by autozone tomorrow. I am requesting this get put on the How-To Write up!!
Heraldj07 is offline
