Gas Tank overflows on fill up - Chevy Colorado & GMC Canyon
post #1 of 9 (permalink) Old 04-04-2011, 06:52 PM Thread Starter
Help!
Does anybody know about this?
It happens at any gas station, any pump, any time of day or weather.
Thanks
Hunter is offline
post #2 of 9 (permalink) Old 04-07-2011, 04:32 PM
Re: Gas Tank overflows on fill up
Try filling your truck when it has !/2 of a tank,not when it's empty.
agha is offline
post #3 of 9 (permalink) Old 04-07-2011, 06:35 PM Thread Starter
I think I get it, if it's on bone dry, the expansion tank is empty, or the shut off float is stuck way down?
Hunter is offline
post #4 of 9 (permalink) Old 04-08-2011, 12:48 AM
Remove and clean (or replace) the evap vent valve. It is located underneath the bed right in front of the spare tire. It is mounted to the charcoal canister. One bolt holds it in place. You also need to disconnect one line and one electrical plug. The valve is stuck closed right now.
post #5 of 9 (permalink) Old 04-08-2011, 07:05 PM Thread Starter
Thank you! Someone in work mentioned a valve, but this makes sense.
Hunter is offline
post #6 of 9 (permalink) Old 04-15-2011, 06:08 AM
I'm sorry for the late response but I have been on the road for several weeks.
The evap vent valve is on the output of the charcoal canister. Normally air flows through the canister and the valve on fill up. The purpose of the valve is to alllow checking of the integrity of the entire fuel tank and feed system. The valve is closed on command and a pressure (or vacuum) check is performed by the engine computer. If the valve then sticks closed you will have problems when filling up the tank. Take it out and clean it.
post #7 of 9 (permalink) Old 05-25-2011, 01:23 PM
i have the same problem on my o4 colly and i have a check engine light for evap leak in the back and my dash blinks gas cap, any suggestions?
SnoX440RaceR is offline
post #8 of 9 (permalink) Old 05-26-2011, 05:33 PM Thread Starter
:D The problem has been corrected, I crawled under the truck and did a rapa tap tap on the unit for a minute, because I didn't feel like getting into a teardown of the valve. I used a wooden handle from a hammer.
It's been 2 ? months now and no problem.. Thanks for the response everybody.
Hunter is offline
post #9 of 9 (permalink) Old 07-16-2011, 01:34 AM
Send a message via AIM to jasinthetank
my spits out almost everytime I fill up at an exxon, I think their hoses may push a little harder than most and yea as soon as it clicks off their is 1/10 of a gallon all over the ground
jasinthetank is offline
