P0506 - Chevy Colorado & GMC Canyon
 1Likes
  • 1 Post By n9cv
post #1 of 5 (permalink) Old 11-23-2016, 12:02 PM Thread Starter
P0506
Well after 130,000 miles I started getting code P0506. I got it a few times last spring and now that the temperature dropped the problem returned this fall. The description is idle speed too low. Watching the engine speed on my Scanguage, I saw that the code usually happened when stopped at a traffic signal for a minute or more and the RPM dropped to the low 500s.
One of the listed fixes listed is to clean the throttle body. So I decided to do that first. It only takes about 45 minutes. I had never done it in 130,000 miles on this vehicle. After removing the throttle body I found it to be dirty, but not extremely dirty. (I have cleaned a few throttle bodies in my life.) So I assumed that cleaning it would not fix the issue. I cleaned and polished all surfaces and removed any trace of the oily dirt.
Upon re-installation I found that the idle had increased to the 650 or 700 range and it idled much smoother. It never drops to the 500s. I have put about 120 miles of city driving on it. The P0506 and slow idle seems to be gone.
So if you experience a P0506, I suggest that you do as others here have recommended and clean the throttle body first.
post #2 of 5 (permalink) Old 11-23-2016, 08:52 PM
Good info. Thanks.
cart7881 is online now
post #3 of 5 (permalink) Old 11-24-2016, 12:28 AM
Good work, yep any idle issues I would go to cleaning the TB first. Great info.
JScottM is offline
post #4 of 5 (permalink) Old 11-24-2016, 06:01 PM Thread Starter
What bothered me on this one is the throttle body was not that dirty. It needed to be cleaned anyway. I was just surprised that it threw that code. It must be more sensitive to gumming up than most vehicles. Oh well, it is done and hopefully this thread will save others some diagnostic time and effort if they have the same code.
JScottM likes this.
post #5 of 5 (permalink) Old 11-25-2016, 10:20 AM
Yes, on my old 2007 it would act like it was going to stall at the end of a decel at a light or stop sign. Cleaned the TB and it fixed it. And like yours it didn't really look that bad.
JScottM is offline
