Will not start after sitting warm. - Chevy Colorado & GMC Canyon
post #1 of 8 (permalink) Old 12-13-2016, 12:29 PM Thread Starter
Chevy Colorado 2007, 95,000 miles. (small four cylinder work truck), This A.M. (20 degrees), I drove to the nearest Walmart to grocery shop (14 miles). When I came out with my groceries (about 1/2 hour later), the truck would not start...just kept spinning the engine over, no catch.
Having happened once before last Fall in warm weather, I went back inside and got a cup of coffee. After drinking the coffee (about twenty minutes), it started right up. After it started the "Check Engine" light did not come on.
As I said, it happened to me before in the Fall. I had made a trip of about 60 miles or so, and when I stopped and shut it off (got turned around, I was asking some construction workers for directions), and when I returned (less than five minutes or so), It would not start...just cranked. After giving-up on it ever starting...figured the fuel pump had possibly failed, after considering my options and getting ready to call for a tow, I tried once more and it started right up (no check engine light)and there was no more starting problems until today.
What I am sure of, is that I did not step on the accelerator, flooding it, so let us not go there...waste of time.
What could it be and if there is a problem, why is there no code generated that indicates the problem?
Bushranger is offline
post #2 of 8 (permalink) Old 12-13-2016, 02:53 PM
cbdallas's Avatar
My memory is a little stretched on this one, because I saw it once during my tenure at a Pontiac / GMC dealership in the 90's on a S-15, but I believe the no-start ended up being caused by a bad coolant temp sensor, or a bad head temp sensor. If the sensor gives the ECU the wrong temp reading at startup, it's not feeding the correct fuel / air ratio, causing a no-start.
cbdallas is offline
post #3 of 8 (permalink) Old 12-13-2016, 03:20 PM Thread Starter
But, wouldn't it generate an error code?
post #4 of 8 (permalink) Old 12-13-2016, 06:24 PM
Sounds like the 'ol passlock problem. Were there any other warning lights illuminated on the Guage cluster? Like one that looks like a padlock with a car?
GregDAP is online now
post #5 of 8 (permalink) Old 12-13-2016, 06:33 PM Thread Starter
No other lights were illuminated.
post #6 of 8 (permalink) Old 12-14-2016, 07:51 AM
Your problem doesn't appear to be temperature related and except for PassLock issues, isn't a common one. As Greg mentioned above, the symptom is indicative of a PassLock problem. The next time it happens check to see if the PassLock indicator (padlock) is flashing while the engine is cranking. PassLock doesn't illuminate the "check engine" light or set a DTC.
cart7881 is online now
post #7 of 8 (permalink) Old 12-14-2016, 04:00 PM Thread Starter
If it turns out to be a Passlock problem, how do I fix/over come it?
post #8 of 8 (permalink) Old 12-14-2016, 09:46 PM
There is an extensive Thread that addresses the PassLock problem and how to bypass the system by cutting a specific wire. A lot of guys successfully applied that mod, but it was just a bandaid fix. How to: Permanently disable the passlock II system.
Since then quite a few owners have had good luck repairing the problem by replacing the ignition switch. It is relatively inexpensive and easy to do.
This link doesn't apply to PassLock, but it has good info regarding replacing the ignition switch: 07 Colorado Won't Stay Running after releasing the Key
A security relearn is required for an ignition switch replacement and there is info for that here: How To: Do a Security Relearn - Chevrolet Colorado & GMC Canyon Forum The steps have to be followed closely.
