question about jacking the truck for an oil change - Chevy Colorado & GMC Canyon
post #1 of 13 (permalink) Old 08-05-2005, 02:41 AM Thread Starter
Send a message via AIM to soybob2002
Forgive me for sounding like such a rookie, but here's my question. Is a 2 ton jack and two 2 ton jackstands sufficient enough to hold up a coly (crew cab w/auto trans.) for changing the oil. I'm plannin' on chaning the oil for the first time one my own and I basically know what's what underneath there and have found posts on this procedure quite helpful. But when ya crawl under there for the first time, it just seems like a totally new monster and I'm just looking if anyone out there has done this safely also with the same capacity jack/jackstand i'm using. I was also wondering where on the front would you jack up the truck? I was lookin underneath there and there barely seems to be much room on the cross member up front; more specifically the area where the stock skidplate is located.
again, I hate it that I'm sounding like such a rookie to you all but any/all help is appreciated.
2005 Chevrolet Colorado
Z85 Crew Cab LS
4x4 - auto trans.
Silver Birch Metallic
soybob2002 is offline
post #2 of 13 (permalink) Old 08-05-2005, 03:07 AM
bbb
2 ton could be considered overkill [not really] cuz your only going to be lifting 1 end of the truck/ not the entire weight of it
try lifting it behind the frt wheel on the frame
'07 silverado 4X4 ext cab/5.5' box
2'' lift with 275/60/20 tires
bbb is offline
post #3 of 13 (permalink) Old 08-05-2005, 06:36 AM
2 ton jack and stands are more than enuff. To be extra safe, chock the rear tires to prevent roll back.
Scott
'04 Z71 Crew
Sunburst Orange
Fram Boost2
PCMforless Tune
BFG 31-10.50x15
T/B Crank 5 turns
Bubaloo 2" Shackles
Flowmaster Super 40
Mr. Tailight Conversion Kit
Rancho RS5190's and RS5300's
My Gallery
scoharri is offline
post #4 of 13 (permalink) Old 08-05-2005, 03:13 PM
Unless you lowered it, there should be enough clearance under a Z85 to change the oil without jacking it up. If the truck is not close to level you won't get all the oil to drain out.
If you really need to, get some ramps to drive up on. They are only about $20. If your driveway slants down back in and then drive up on the ramps, the slant will help keep the truck more level.
Z71 Crew Cab, 1SF, 2WD, 3.42, Sunroof, I5/Auto, Sunburst Orange, In-channel Vent Visors, Hood Deflector, Line-X Bedliner.
http://www.coloradofans.com/album_pe...p?user_id=4969
Hypurr is offline
post #5 of 13 (permalink) Old 08-05-2005, 05:22 PM Thread Starter
thanks for the feedback ya'll. just gives me a lil' more peace of mind when I crall under there.
Z85 Crew Cab LS
4x4 - auto trans.
post #6 of 13 (permalink) Old 08-05-2005, 06:15 PM
DjD
As stated you want the truck level or the oil won't all drain out. You should not have to jack up the front of your truck to reach the drain plug or the oil filter unless you've lowered the suspension or not on flat ground.
Tip-o-the-Day: When you remove the drain plug the oil will shoot all the way over to the tire. Place your drain pan so it can catch the oil over there and put down a piece of cardboard so you don't get oil on the driveway...
...Dennis
'04 3.5 A4 Crew Z71 4WD
Gallery
DjD is offline
post #7 of 13 (permalink) Old 08-06-2005, 12:30 AM
Global Moderator
Danny45's Avatar
Some of us aren't skinny! ;) I almost ripped off my lower valance with my belly. And I'm 5'11" and weigh only 180 lbs.
I used the 2 ton jack and 2 ton jack stands. Gave me a lot more room to avoid the "fire-hose" effect of the oil spewing out. But I had mine on 4 jack stands and rotated the tires at the same time. Made it a lot easier.
I'm still trying to figure out why over a quart of oil came out when I removed the filter. That made a huge mess.
Danny
10,000 Posts Club Member #1
Conservative Club Member #2
Danny45 is offline
post #8 of 13 (permalink) Old 08-07-2005, 12:41 AM
i will continue with a tip of the day, the tip of the drain plug is magnetic, and will stick to the bottom of the transmission pan so u dont have to worry about loosing it on the ground.
ryan
spoolin ex is offline
post #9 of 13 (permalink) Old 08-07-2005, 06:12 AM Thread Starter
Thanks for the input ya'll. I am an oil change virgin no more!. I'm a lil fat (not so much "a lil", more like "am very:)so I had to jack up the truck a bit. I only needed to get it up on the first couple pegs of the jackstand. I kinda compromised tho and backed up my drive that happens to be on a slight slant.
p.s. you weren't kidding about the firehose effect of the draining oil. Good thing I was ready with the cardboard and kitty litter.
p.p.s. that oil can be mighty warm
Z85 Crew Cab LS
4x4 - auto trans.
post #10 of 13 (permalink) Old 08-07-2005, 04:26 PM
Anyone have any experience with Fram Suredrain valves? It might be an alternative to solve the fire hose problem.
2005 GMC Canyon, Z71, 4X4, SLE Crew, Summit White
ptkid2 is offline
post #11 of 13 (permalink) Old 08-07-2005, 05:00 PM
DjD
I just installed one on mine and won't be able to say how it works until the next oil change. I can say it doesn't leak at this point and as long as I don't loose the hose I think it's a good deal. It will be much slower draining as the opening is half the size of the hole in the oil pan. I got one so I wouldn't have to remove my skid plate at every oil change...
Hey spoolin - my oil pan is alum and the only place the hot drain plug has gone is into the oil drain pan, well actually this last time I wore some gloves and was able to hang onto it... Were you thinking of changing the trans fluid? ;)
...Dennis
Gallery
DjD is offline
post #12 of 13 (permalink) Old 08-07-2005, 05:47 PM
no i was talking about the oil, take the oil drain plug the tip of it is magnetic, the transmission pan is metal so it will stick to it provided it is cool enough to touch without getting burned.
ryan
post #13 of 13 (permalink) Old 08-08-2005, 01:56 AM
Why do u even need to lift it? Colies are one of the easiest vehicles to do an oil change on, thank you GM for that! I'd use the drive up ramps insted of a jack. Just what I'd do. good luck...it's easier then you think...MUCH!!
IraSummers is offline
