Automatic Transmission Fluid Change/Update for 2006 - Chevy Colorado & GMC Canyon
post #1 of 13 (permalink) Old 11-28-2006, 01:42 AM Thread Starter
Well guys as I was servicing a 2006 Uplander today I discovered something that im not sure if its been mentioned here before. I searched through all Chevy models and it confirms my findings.
As of 2006, all Chevys (prob most GMs) use Dexron VI automatic transmission fluid instead of Dexron III like they've been using since 2005 and older. Supposedly you can put Dexron VI into a tranny that came with Dexron III but you should not put Dexron III into a trans that came with Dexron VI.
My best guess is the Dexron VI is a synthetic ATF since the service interval for it is 100,000 miles according to GM. Personally I would still change it at 60k, then every 30k after that along with a new filter each time.
turbizzy is offline
post #2 of 13 (permalink) Old 11-28-2006, 01:43 AM Thread Starter
Here's a little info on it, you can google it for additional info.
[quote]April 13, 2005
GM Rolls Out Dexron-VI
By Tim Sullivan
General Motors has unveiled Dexron-VI, a new automatic transmission fluid for 2006 model year cars and trucks equipped with Hydra-Matic transmissions. The new specification raises the bar for fluid performance and for qualification difficulty. With GM aiming to make Dexron-VI the fluid of choice for all of its cars and light trucks, the ATF market may be destined to become more complicated – and more expensive.
GM developed the trademarked fluid in conjunction with Afton Chemical Corp. and Petro-Canada Lubricants, and officials at all three companies described it as a significant advance beyond major existing specifications. Besides ratcheting up performance demands, the standard creates new hurdles expected to drive up licensing costs for additive and oil companies, including a requirement for fleet tests and insistence that new chemistries be compatible with those that are previously approved.
Announced April 1 and presented yesterday at a lubricants meeting during the SAE Congress in Detroit, the new spec is part of a trend of change for the ATF market. Performance requirements have risen steadily the past few years to accommodate transmission design changes as well as pushes by automakers for fluids to last longer and perform better.
GM introduced the Dexron-III(H) spec just two years ago, but decided it needed to upgrade again to accommodate the Hydra-Matic 6L80, its first six-speed automatic transmission. As far as the transmission fluid is concerned, the biggest change with the 6L80 is that it puts clutch interfaces in direct contact with each other, rather than using a buffer such as a freewheeler between them. Having direct contact improves the speed and efficiency of power handoffs between clutches, but it also requires greater precision to keep those interactions consistent.
“With this new transmission, we have to be much more precise in our lubricant performance,
turbizzy is offline
post #3 of 13 (permalink) Old 11-28-2006, 09:56 AM
Send a message via AIM to vicjac1010 Send a message via Yahoo to vicjac1010
Great Info Pimpin'
Under 21 member #2
Louisiana Meet
vicjac1010 is offline
post #4 of 13 (permalink) Old 11-28-2006, 03:56 PM
Canyon08Z71's Avatar
Thanks Izzy for the info.
So if I read it corectly, I might be forced to update to this more expensive IV because GM finally produced a 6 speed automatic?
Canyon08Z71 is offline
post #5 of 13 (permalink) Old 11-28-2006, 04:19 PM
Good to know. Thanks turby
brewer15650 is offline
post #6 of 13 (permalink) Old 11-28-2006, 07:03 PM
It's about time to be honest with you, Ford has been using Mercon 5 since around 2000 or so. They say the same thing too(about using M5 in older trans, but not using M3 in the new trannys) They even recommend flushing the transmissions in Escapes that have torque convertor shutter before replaceing the convertor.
Ford Service Tech
Quite possibly the first Xtreme on 22s??
coloradoX is offline
post #7 of 13 (permalink) Old 11-28-2006, 09:35 PM Thread Starter
Well you have an 04 right? Technically your still ok to use the regular Dexron III stuff, its the 06ers and up that come factory filled with Dexron VI and should only be filled with Dexron VI. You can still put the Dexron VI into your older trans, won't hurt anything and probably benefit you more. But yea i think its more expensive.
Oh and its Dextron VI (6), i guess it was soooo good that they completely skipped over IV and V (4 & 5) :D
turbizzy is offline
post #8 of 13 (permalink) Old 11-28-2006, 10:43 PM
Hahaha. Yeah ok, 6... I thought it was 4, I even went back and edited my post because of that!! :)
Great info and timing.. I was just about ready to get prices to flush and fill my transmission. Does GM do the power flush and fill? I was thinking of calling GM and AAMCO for prices. My local mechanic does not have the power flush system at his shop...
post #9 of 13 (permalink) Old 11-28-2006, 10:46 PM Thread Starter
It really depends on the shop. Every GM dealer does require to have the cooler flusher for warranty purposes but as far as an entire trans flusher depends on the shop.
turbizzy is offline
post #10 of 13 (permalink) Old 11-30-2006, 03:44 PM
So... does that mean '05 and earlier would benefit from an "upgrade" to Dextron VI? Or should we just stick with III?
Update: Traded for a 08 Silverado Ext Cab Z71 4x4
Update: BugShield II, Cover King Seat Covers, Painted Bowtie, 32x11.5x15 BFG AT's, Black steel wheels, T-bars, Shackles, & Shocks... plus a little trimming.
Lifted Club Member #88
Razbery is offline
