removing headlight housing - Chevy Colorado & GMC Canyon
Old 09-13-2011, 08:35 PM   #1 (permalink)
HIX
Default removing headlight housing
hey guys. havent been on here in a while since ive been busy at college. non the less i still need some help on a little problem i have. On the passenger side headlight, i have a lot of moisture built up inside the lens. I was looking on how to take the whole housing off the truck or what the best way is to do this. i havent looked for any threads or stickys on this so im sorry if im beating a dead horse. lol Any help would be great and much appreciated from all of you nice folks. also another thing i would like to know is where do you think this moisture is coming from? there are no cracks from what i can tell and the bulbs were tight in the back of it. so like i said any help would be great.
Thanks,
Owen
HIX is offline   Reply With Quote
Old 09-13-2011, 08:59 PM   #2 (permalink)
Kruz's Avatar
Default
well my stock headlights never leaked but when i got my aftermarket ones i got some adhesive and sealed em up around each headlight and they have not leaked, also have you?
05 Colorado LS crew cab
Kruz is offline   Reply With Quote
Old 09-14-2011, 09:29 AM   #3 (permalink)
jamesrw30's Avatar
Default
I am currently having the same problem HIX. It just started all of the sudden. I have never seen any water inside the headlight, just moisture on the lens.
jamesrw30 is offline   Reply With Quote
Old 03-03-2012, 02:23 PM   #4 (permalink)
Default
I am having the same issue with the turn signal on the passenger side. Everything looks tight, and all of a sudden, moisture all in it.
TENPLATE is offline   Reply With Quote
Old 03-03-2012, 03:42 PM   #5 (permalink)
Default
very common issue on these trucks. if you dont want to bake them and re seal them the only thing you can do is silicone all around the seal and hope it cures it. that or replace the headlight or drl alltogether. you have to pull the grill which takes 2 min its held in by pop clips. you have to un clip the little black snaps there are 4 of them along the top of the grill. then unplug the wiring for the drls and out it comes. pull hard it will come easy. then its just 2 10mm bolts holding the headlights in. Im sure there is a how to on here somewhere.
zeuce is offline   Reply With Quote
You may not post new threads
You may not post replies
