Seating coil boots on plugs?? - Chevy Colorado & GMC Canyon
Old 06-15-2012, 03:21 PM   #1 (permalink)
britishrich's Avatar
Default Seating coil boots on plugs??
Has anyone else had the problem that correctly or incorrectly seated coils/boots feel exactly the same when you put them back on?
I can feel ZERO "bite" or feedback of anykind when I replace the packs...
I had to remove and replace the packs 3 times just to get the truck back to a drivable condition after I put new plugs in...and every time it "felt" the same...just kept doing it until my idle wasn't awful, assuming the bloody spring wasn't lining up
When I did my BMW with coil packs back in the day I could totally feel the boot seating on the plug...
britishrich is offline   Reply With Quote
Old 06-16-2012, 12:24 AM   #2 (permalink)
Tweek's Avatar
Default
I did not have any problem seating the coil packs on mine...Might have just got lucky...LOL
SPIDEY
2005-Z85-4x4 REG.Cab 2.8 I-4 5-Speed
Victory Red
Tweek is offline   Reply With Quote
Old 06-20-2012, 08:40 PM   #3 (permalink)
Default
The only one that give me trouble it #1 at the front because of the small wiring harness, any way to move that?
2-5 are fine no problem at all.
A good racer is one whose head is in communication with his balls." - Richie Evans
CdnColorado is offline   Reply With Quote
Old 06-27-2012, 09:59 PM   #4 (permalink)
Default
For the front one I took the plastic cover off the harness right there to give it as much flex as possible then carefully rotated the coil underneath it...holding the bolt up out of the way...I'd love to see the "textbook" method for that one! LOL
(If they just made the snaps on that wiring harness housing pop off it'd be easy to slide it out of the way, but they look permanent to me)
Old 06-27-2012, 11:15 PM   #5 (permalink)
Tweek's Avatar
Default
They have a small wht. clip that must be turned counter clock wise ( i think) at the bottom of the wire housing...Just turn them with a str8 screwdriver and it lets it free to give room to the #1 boot and plug...Ya gotta kinda look for it...White in color ...
SPIDEY
Victory Red
Old 06-28-2012, 07:53 AM   #6 (permalink)
Default
I know exactly the piecies you mean....those pieces DO move? LOL
I guess that'd be the textbook way then! LMFAO
Thanks Tweek
Now if you knew what the F was up with my P2123 code then I'd be REALLY impressed LOL
Old 06-28-2012, 10:20 AM   #7 (permalink)
Default
BTW - on seating the plugs what I did last night was strecth the boot springs about 1/8th longer, as I wasn't convinced they weren't really making contact, and springs compress over time anyway....made a big difference to seating the plugs...there was actual feedback that felt like they were in place unlike before. It ran perfectly first time doing it this way...well except for my unrelated gremlin code that is!
You may not post new threads
You may not post replies
