LinkBack | Thread Tools |
#1 (permalink) |
Hey guys,
New to the forum :) I own a 2009 Chevy Colorado 2.9L LT. I just came across an issue today with my oil pan. The threading on my oil pan for my oil plug was stripped and someone re-threaded it without me knowing. Now the threading has come off and I am not able to find any sort of plug to that will do the job. Should I replace the oil pan or get it re-threaded?? Not really sure what to do, I've never had this happen and never heard of it happening to anyone I know. Thanks in advance, Jamie |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
I would just replace it... and welcome to c'fans
check gmpartsdirect.com... most likely cheaper than the dealership.
2011 Colorado CC Z71 2LT 4X4 3.7L 3.73 gears/Snuglid/MBRP muffler/K&N Air Filter/Air Doc intake/Supermod PTB/SuperSparks/Z71 decals removed/4" Rancho Lift/Rancho RS5000series/ProComp 17" Alloys/285 70 17 Goodyear Duratracs/5000k HID lows and fogs/LED DRLs,tails,reverse lights/Super 2nd apply servo/tanny cooler/PCM tuned by Justin @ Black Bear Performance/Off road club #3/Lifted Club #440
#3 (permalink) |
Most auto parts stores carry rubber expandable oil drain plugs that can be used to temporarily get you going. Buy Dorman - Autograde Oil Drain Plug Universal 1/2 Inch / M12 65200 at Advance Auto Parts You should replace the oil pan for a permanent, reliable fix. The Part Number for the oil pan is 12600499 and should be available online for $125-$150. Check gmpartsdirect or gmpartsgiant.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
