"Reduced Power" Check engine light? - Chevy Colorado & GMC Canyon
post #1 of 23 (permalink) Old 07-02-2007, 12:06 AM Thread Starter
Send a message via AIM to NCRado89
Hey yall, today when i was driving on my way back from work, my truck started beeping from the dash. I looked down at the dash and the check engine light was on and on the display if said "Reduced Power". I was driving on a level surface at the time so i just said to myself "ill get home and take it to the dealership in the morning". Then i started driving up a hill and with my foot to the floor i didnt achieve a speed any higher than 45mph. I havent had any problems with my truck thus far. I drive a 2006 I5 Z71 4x4 with about 8000 miles on it. Has anyone had this problem or know what this is from. Any help would be appreciated. Thank you.
2006 Chevrolet Colorado I5 Auto Trans.
3" PA Body Lift
Rock Crawler series 97 wheels
33x12.50x15 Mickey Thompson MTZ's
Cobra CB Radio with Wilson 1000 antenna and whip antenna
Lifted Colorado/Canyon club #87
NCRado89 is offline
post #2 of 23 (permalink) Old 07-02-2007, 04:35 AM
back when i had my 2005 crew 3.5 auto, if i floored it and start spinning for too long it would say reduced power; i think it was part of traction control or something. hope this helps.
"For God so love the world, he gave his only begotten son that whoever should believe in Him should not parish but have everlasting life."
-John 3:16
The price for your and my sins is already paid.
crewcabcolley is offline
post #3 of 23 (permalink) Old 09-21-2007, 08:28 PM
My 2005 Canyon has approx. 61000 on it. I drive about 105 miles round trip to work daily along curvy mountain roads, except for about 20 miles of road I can really open up on. This morning while enroute to work I pulled out to pass a vehicle, I was going about 55, when I punched the gas the engine lost power and the "Reduced Power" message came on . I pulled to the side of the road and the truck wouldn't get any faster than 10 mph. Although I didn't hear anything break in the engine I thought I had busted it. I shut the engine off and then restarted it and it was still the same. Shut it off again and started looking in the manual and it stated to push the pin on the dash in to reset the message. I had sat there about 5 minutes and refired the truck at which time it started fine and the message light was off. I took back off and the truck run great and I didn't have any other problems. I've always run the truck pretty hard and this is the first time this has happened, never had any other problems. I am curious on why this happened. Any information is welcomed.
Lesnes is offline
post #4 of 23 (permalink) Old 09-22-2007, 04:38 PM
Isnt that considered limp mode?
Ragnarok is offline
post #5 of 23 (permalink) Old 09-26-2007, 01:31 PM
Send a message via AIM to Stepdaddy
yes...I have had case or 10 with reduced power....twice at the track...I got some sweet 30 second 1/4 times with a trap speed of 26mph
turn the truck off for a min and start it back up...you will get a cel but it will turn off with some normal driving....unless your problem is more serious
dealership is unnecessary
04 z85 5cyl 5 speed RC - only a handful of mods
15.1 in the 1/4
http://www.HOU355.com
Remember kids, its not what you know - but who you know; and how much brown-nosing you do.
rangerbob
“What a pompous ass you are. I think you beat out me and Dillusion.”
Stepdaddy is offline
post #6 of 23 (permalink) Old 09-26-2007, 01:51 PM
Uh... Dealership would be the first place I would go to find out why it's doing that.
rangerbob is offline
post #7 of 23 (permalink) Old 09-26-2007, 06:39 PM
mine has gone off due to over reving
and large traction control issues
i guess if he was just driving normal and it went off mabey the stealership might be the place to go
15.1 in the 1/4
rangerbob
post #8 of 23 (permalink) Old 09-29-2007, 03:33 AM
Subject: LSJ, L61, LK5, L52, LL8 Engine - Reduced Engine Power, MIL/SES Light, DTC P1516, P2135, P2138 (Replace PCM) #07-06-04-003 - (01/19/2007)
Models: 2005-2006 Chevrolet Cobalt, Cobalt SS, Malibu
2006 Chevrolet Colorado, TrailBlazer
2006 GMC Canyon, Envoy
2006 HUMMER H3
2005-2006 Saturn ION, ION Red Line
2006 Saab 9-7X
with ECOTECâ„¢ 2.0L, 2.2L I-4 Cylinder Engine (VINs P, F-- RPOs LSJ, L61) or
VORTECâ„¢ 2.8L I-4, 3.5L I-5, 4.2L I-6 Cylinder Engine (VINs 8, 6, S -- RPOs LK5, L52, LL
Attention: The following bulletin information is only to be used if the customer has returned for REPEAT repairs for DTCs P1516, P2135 and/or P2138.
Condition
Some customers may comment on engine operation in the Reduce Engine Power mode with the MIL/SES light illuminated. This condition may be repeated and upon investigation, the technician may find the following DTCs set as current or in history:
• DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
• DTC P2135 Throttle Position (TP) Sensor 1-2 Correlation
• DTC P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
Cause
This condition of a repeat DTC P1516, P2135 and/or P2138 may be caused by an internal concern with the PCM.
Correction
Important: DO NOT replace the APP sensor. Inspect the PCM build date first.
Before following the diagnostic information in SI on DTCs P1516, P2135 and/or P2138, an inspection of the PCM serial number year and Julian (PCM build) date will be necessary to determine if the PCM will need to be replaced to correct the repeat DTC P1516. Refer to Engine Control Module Replacement in SI in order to remove the PCM. Refer to the above graphic illustration (1) for the location of the PCM serial number.
The serial number is read left to right. The last digit of the year is the 9th character and the Julian date is comprised of the 10th, 11th and 12th characters and is used to determine the PCM build date. Refer to the example below to read a build date from the PCM serial number:
* 8 6 Y N AU K 1 5 3 2 5 0 R P N *
If the PCM year and Julian dates are between 5182 and 5304 , replace the PCM. Refer to the Part Catalog to order the correct PCM for your vehicle application, if necessary.
Vehicles with PCM built outside the dates should refer to SI diagnostics for DTCs P1516, P2135 and/or P2138.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J6360
Powertrain Control Module Replacement
Use Published Labor Operation Time
Warranty Information (Saab U.S. Models)
Labor Operation
Description
Failed Object
Fault/Reason Code
Location Code
Warranty Type
Repair/Action Code
Labor Time
2481001
24810
67
0
01
01
ASE Master Techician, L1 Certified, Chevrolet Tech
GM Diesel Master Certified, GM Brakes Master Certified
2006 Colorado 4cyl 4x4 5spd Standard Cab
Pioneer HU, Polk 6 1/2's in Front Doors
Pioneer 200w Amp pushing Polk 6x9's in boxes
GM color matched, chrome grille
30% Tint on Side windows, Limo on rear
K&N Cold Air Intake
ChevTech06 is offline
post #9 of 23 (permalink) Old 10-13-2007, 02:26 PM
After my 05 Canyon experenced the Reduced Power within two weeks I took it to the dealer. The problem with mine was a buildup of carbon on the throttle plate. The engine light is now off and the truck runs great. Cost me about $75 for the repair and it took approx. 45 minutes for the repair job.
Lesnes is offline
post #10 of 23 (permalink) Old 10-16-2007, 08:36 PM
Send a message via AIM to J-man67
HAHA, yeah thats when mine went on. I was SCARED!!! I had the codes cleared and fine ever since.
GET IT DIRTY!!!!!
2004 Colorado Ext cab LS z71 4x4 - traded :(
2007 Harley D. FXDB (Street Bob)
2006 Kawasaki KFX400
2004 Kawasaki zx636R
J-man67 is offline
post #11 of 23 (permalink) Old 10-17-2007, 05:59 PM
Ive prabably had this happen to me about 5-10 times since ive owned the truck...only once did it happen when i was over reving it but WOT in 3rd at about 85ish....Ive learned that turning the truck off for about a min. and treating it nice for a day and the CEL will go off....If you dissconect the Bat. it will have to relearn everything, wich isnt the best
15.1 in the 1/4
rangerbob
post #12 of 23 (permalink) Old 11-21-2007, 11:48 PM
I had this issue with mine yesterday on the highway. I pulled out to pass a slow poke and just as i got around him i had the reduced power message. No matter how far i pushed the gas pedal i couldn't go any faster. I eventually pulled over to the shoulder and shut it off. Re-started it and it still ran terrible. Tried shutting off and re-starting it a second time and it was fine.
However, the code i had was P0068A - throttle body performance.
Anyone had that one?
Oh and this was the second time it pulled this on me. The first was when trying to pull away from a stop light. Funny enough that was when i was on my way to the dealer for the brake light switch recall. Needless to say, they didn't find anything wrong.
canyonaero is offline
post #13 of 23 (permalink) Old 11-22-2007, 06:18 PM
Send a message via AIM to schardbody Send a message via Yahoo to schardbody
i bought my truck even though it did this on the testdrive before i purchased it.
clean the throttle body.
CarolinaChapter@355nation.net
schardbody is offline
post #14 of 23 (permalink) Old 11-22-2007, 10:49 PM
I'll definately do that A.S.A.P. Thanks for the info.
post #15 of 23 (permalink) Old 01-20-2008, 07:21 PM
So this is not at all related to the head issue? Or am I off base? Cuz if it has anything to do with it I want it fixed, instead of treating the symptoms on a regular basis? Thanks for the help
2005 Victory Red Z71 LS. No problem until 34000 miles. Extended Warranty Pending.
jbell310 is offline
post #16 of 23 (permalink) Old 01-21-2008, 08:02 PM
I was told today that it is an ignition issue, based on our recent cold weather -30 not including windchill. Told to leave it alone. They are having the same issues with Envoys and Trailblazers at my dealer.
jbell310 is offline
post #17 of 23 (permalink) Old 01-30-2008, 02:59 PM
There's an issue with cold weather and ice build on the throttle body that causes reduced power message. Place truck in heated garage or some how heat up your throttle body.
05 Canyon Crew Z71 SLE
mustangp_51 is offline
post #18 of 23 (permalink) Old 02-03-2008, 08:38 PM
I cleaned my throttle body and it hasn't happend since. It's been a couple months now.
post #19 of 23 (permalink) Old 03-04-2008, 11:04 PM
reduced power engine light
I just had the throttle body replaced two months ago. I got about 63000 miles on my truck. So the other day i was driving back to home from DC and I got this problem. So i pulled over and called AAA for a tow. Tow truck comes so start the truck to reposition it for the tow truck and it ran fine. Took it right to the shop they did a quick scan and couldn' come up with nothing because it had reset itself. So I continued to drive it home with no problems. Next day took it to the dealer wher I bought it and the said the only thing that they could come up with is the throttle body. I told them it was only two months old and they said they cleaned it and sent me on my way. Next day I leave for DC again make it about 130 miles and truck started to get very weak. I floored it motor sounded good but felt like it was restricted somewhere. Towed it to a dealer in Somerset, PA and they are going to put a new catalytic converter on it. Hopefully this will fix it.
I guess we will see, I am about ready to torch it!!!
2004 Z71 Ext Cab 4X4
bkbrown5881 is offline
post #20 of 23 (permalink) Old 03-06-2008, 04:32 PM
Mine did this when I was going through DEEP water. (It was coming over the hood) I know don't drive in water that deep, but didn't have a choice couldn't stop my truck would die. I got the Reduced Power message and just pulled into a driveway and reset my truck. Don't know if that is advisable but it worked in a tight situation. I won't post how to reset it unless someone says that it isn't bad to do that.
2005 Colorado Z-71 Volant Intake and Magnaflow Exhaust
sbees2008 is offline
