I-5 motor knocking - Chevy Colorado & GMC Canyon
post #1 of 33 (permalink) Old 03-18-2009, 06:04 PM Thread Starter
Send a message via AIM to cali calorado
I-5 motor knocking
I am not sure if the knocking in my motor is from the valves? It knocks when it is cold or warm. I am not sure what to look for if you have any ideas or suggestions it would be great. It is an 2006 I-5 crew cab Z71 with a stock motor with about 62,000 miles on it.
2006 chevy colorado crew cab Z71 with a 4 inch rancho lift on 265/70r-17 yokohoma geolander a/t-s.
cali calorado is offline
post #2 of 33 (permalink) Old 03-26-2009, 12:17 PM
Re: I-5 motor knocking
Check your oil for starters if you haven't done it already. Did it just start doing this or has it been getting worse over time??
CapeRR is offline
post #3 of 33 (permalink) Old 03-28-2009, 10:49 AM
Check the motor mounts. Another truck owner thought the engine was knocking and it ended up being motor mounts. I would say also clean the MAF, TB, run power foam through and change the spark plugs.
Steve
jackedupcanyon is offline
post #4 of 33 (permalink) Old 04-05-2009, 12:02 AM Thread Starter
Thanks for the advice. It sounds really bad when it is cold and at low rpms about 2000 or so. it sounds like it is in the lower end. My friend thought it was rod nock but as i get higher in the rpms the knocking goes away. The noise has become more noticable.
post #5 of 33 (permalink) Old 04-08-2009, 07:21 PM Thread Starter
I do quite a bit of heavy towing and go to the desert and beach to off road it and am at full throttle quite a bit.
I did use a stethescope and it sound like it is in the motor for sure it is not that easy to pin point. I will check the motor mounts and see how they look. The knocking is in park and in gear at low rpms and goes away in higher rpms and at higher speeds
post #6 of 33 (permalink) Old 04-08-2009, 08:09 PM
Send a message via Yahoo to dirtydawg
The fact that it's going away at higher RPMs makes me think valve train. If it were rod knock, it should get worse as the Rs go up. Just my .02
2007 TOTW #33 - LIFTED CLUB #24 - CONSERVATIVE CLUB #43
Rancho 4" / Skyjacker Softride / PA 3" - ProComp Xterrain 305/70R16 - 16x8 Eagle 1378
Smittybilt XRC-8 Winch - Optima Red - Hella 4000 Compact Fogs - AEM / PCMForLess - E-fan - Hard Cover
dirtydawg is offline
post #7 of 33 (permalink) Old 04-09-2009, 07:15 AM
FWIW: I'm still not buying the argument that bad motor mounts will ake an engine knock.
post #8 of 33 (permalink) Old 04-09-2009, 09:10 AM
x2.
rangerbob is offline
post #9 of 33 (permalink) Old 04-12-2009, 08:04 PM Thread Starter
If it were the valve train what should i be looking for or what should i attempt to do
post #10 of 33 (permalink) Old 04-14-2009, 06:06 PM
Isn't there a GM recall for the heads and valves on a 3.5?
viewtopic.php?f=43&t=26513
BedRug
Catch-All Xtreme Floor Guards
ZQ8 tailgate decal
Factory foglights added
upflying is offline
post #11 of 33 (permalink) Old 04-14-2009, 11:29 PM
It's not a recall, it's an extended warranty on the head.
I wonder if his problem isn't in the balance shafts/chain.
post #12 of 33 (permalink) Old 04-14-2009, 11:34 PM
THANK YOU!
Have the dealer look at it bro. There are ways for us to pinpoint specific cylinders by runnin power balance tests and such. Also, i do remember someone saying the same symptoms, ended up being a balanceshaft and the entire engine got replaced.
turbizzy is offline
post #13 of 33 (permalink) Old 04-16-2009, 01:08 AM Thread Starter
Dealers cost to much and it is a recall if the engine light comes on for it and a extended warrenty. beside the point I figured I would replace the plugs and the noise is no longer their wich can make some sense I guess. what do you guys think
post #14 of 33 (permalink) Old 04-16-2009, 07:11 AM
Based on this post......Id put money on it that its a rear main issue. Its very common to hear the knocking at idle or low RPM's, but once the vehicle is moving along and not under the load of accelerating anymore, the knocking goes away.
If thats what it turns out to be, its NOT an easy fix unless you are mechanically inclined.
{Morbid} is offline
post #15 of 33 (permalink) Old 04-16-2009, 07:50 AM
IT IS NOT A RECALL.
post #16 of 33 (permalink) Old 04-21-2009, 12:10 AM
IT IS NOT A RECALL.
THANKS AGAIN! Its not a recall whatever happens. Its a warranty extension on the cylinder head coverage.
turbizzy is offline
post #17 of 33 (permalink) Old 04-21-2009, 06:35 PM Thread Starter
Your right not a recall. just an extended warrenty.
post #18 of 33 (permalink) Old 04-21-2009, 08:39 PM
Send a message via Yahoo to mike xlb
Perhaps it's an accessory doing this, the noise and vibration can travel INSIDE the motor since everything is attatched. If it was a something directly inside the motor I would imagine you would hear it all the time.. Is the noise noticeable in the cabin?
2008 GMC Canyon 4x4 SLE-1 Z85
2005 Chevy Cobalt SS/SC
mike xlb is offline
post #19 of 33 (permalink) Old 04-22-2009, 07:54 PM Thread Starter
not really just when it was cold. But since replacing the spark plugs the noise is no longer there. Still thinking why that is
post #20 of 33 (permalink) Old 04-23-2009, 07:32 AM
So is it fixed now? Spark plugs eventually start eroding away, increasing the gap, decreasing amount of spark produced and delaying spark/burn/combustion because of it and causing some knock.
Steve
