Random no start problem - looking for advice - Chevy Colorado & GMC Canyon
post #1 of 15 (permalink) Old 08-28-2011, 08:58 PM Thread Starter
MMM
Hello all -
My '06 Z71 Colorado (5 Cyl) had the oft reported won't start till ya wait 10 minutes problem. So, like everyone else, I went through the "take it to the dealer, we can't reproduce it" routine. Finally it threw a misfire fault, they did a compression check, and found the following:
Cyl 1: 15% leakage
Cyl 2: 85% leakage
Cyl 3: 44% leakage
Cyl 4: 15% leakage
Cyl 5: 20% leakage
So, they replaced the head, and also the cam.
Problem went away. That was in March, @ 65,000 miles. Now I'm at 75,000 miles... and... yes .... I have the same problem again. Cranks, no start, wait 10 minutes, fires right up.
I don't have a passlock system, and am religious about changing the oil with pure synthetic on a regular basis.
So I'm guessing I'm going to take it to the dealer for another compression check.
My question - and I know this is difficult to answer, but is it remotely possible a replacement head could again need to be replaced after 10,000 miles?
I'll let ya'll know what compression results come back from the dealer..... what I'm trying to avoid is:
1) We can't reproduce it (until of course I go out of the 100K powertrain warranty).
2) We don't know what the problem is.
Guess I'm just looking for any other areas I can have the dealer check out and repair before I go out of warranty.
Is it possible the truck has the passlock computer... but not a passlock ignition?
This is really starting to bum me out..... I'm not one to throw a temper tantrum at the dealership.... but at this point I feel llike I either want to just take the truck back to the dealer and leave it (which I would hate to do, because despite all the problems - and I've had ALL the common ones - I really do like this truck), or have them replace the whole engine (which, I suppose, would only delay but would not fix the problem).
Any comments are most appreciated.
Thanks
Matt
MMM is offline
post #2 of 15 (permalink) Old 08-29-2011, 09:03 AM
naskie18's Avatar
I'm not sure this is possible, I think GM has put that on everything for years, as far as I know, there isn't an option to delete it (at least not from the factory).
And the issue you're having sounds exactly like the passlock system activating.
naskie18 is offline
post #3 of 15 (permalink) Old 08-29-2011, 09:20 AM Thread Starter
MMM
Nick -
Thanks! The only reason I say it doesn't have passlock is that there is no resistor in the key (there doesn't apper to be anything special about the key at all)... I'd thought that was how you determined if you have passlock or not.
Am I mistaken?
(Also the "lock" indicator in the instrument cluster is not illuminated while it's in a "no-start" condition).
Thanks
Matt
MMM is offline
post #4 of 15 (permalink) Old 08-29-2011, 05:23 PM
Nick -
Am I mistaken?
Thanks
Matt
You still have a pass-lock system on your truck. The resistor is in the ignition switch and not on the key as older vehicles had in the past. You can bypass the pass-lock very easy if you so desire. You can also run a few new wires to the fuel pump relay with a different switch and this will get you started also. Pass lock shuts the fuel off only. No fuel-no go.
Colorado Cajun is offline
post #5 of 15 (permalink) Old 08-29-2011, 05:42 PM Thread Starter
MMM
Ah! Things are making much more sense now, thank you! I think I'll cancel tomorrows compression test and look into disabling the pass-lock. I was reading some threads on how to do it by cutting a wire or two.... I don't think I'll go that route though. I need to read through some more threads, but the general idea I got was it could also be "programmed away". Maybe I'll also just use my spare key for awhile and see if the problem replicates ... I'm guessing the ignition key cylinder or the key itself wears down after awhile and freaks out the pass-lock.
THANKS!!!!
(I'll follow up with any new info as it comes along).
- Matt
MMM is offline
post #6 of 15 (permalink) Old 08-31-2011, 07:11 PM Thread Starter
MMM
Well, I took it to the dealer - it did show a passlock fail code. So I skipped the compression check and will just wait for the next time it happens to get a bit more info as to what's going on. The dealer said with the code that was thrown, the engine shouldn't have cranked at all.... yet it did.
On the way there, an ABS fault showed up... so they changed a hub at no charge. I was there last week as the brake switch had failed. The recall covered that.
I'm getting to know the service reps pretty good by now.
But I will say this - if you are in Kansas City, Superior Chevrolet is a great dealership... they've taken care of the many problems I've had in a courteous and professional manner.
Will update if / when more problems crop up.
MMM is offline
post #7 of 15 (permalink) Old 09-01-2011, 09:45 AM
naskie18's Avatar
The way the passlock thing works, the engine will crank fine, but the passlock system shuts off the fuel delivery, so you can sit there and crank it all you want, it won't start until the passlock system resets and fuel delivery is restored.
naskie18 is offline
post #8 of 15 (permalink) Old 09-09-2011, 11:21 PM
FUR
Mine would do the same thing intermittently. My passlock would flash however. I cut the wire and put a couple quick connects on it for if my battery ever goes dead and it needs to relearn. Few thousand starts since with no issues.
FUR is offline
post #9 of 15 (permalink) Old 06-14-2013, 04:58 PM
Colorado/canyon won't start
I have been dealing with this no start for over a year
Now. And I think I figured it out.
Haven't had the problem in over 3 months
I quit using that cheap little door lock unlock
Panic button thing that goes on your key ring.
Simple has that. Please post a message if it works
For you. Bill
Poppy4400 is offline
post #10 of 15 (permalink) Old 06-17-2013, 10:34 PM
For you. Bill
mine still does it occcasionally even though i never use my remote.
bholcomb is offline
post #11 of 15 (permalink) Old 07-25-2013, 06:03 AM
Mine was doing the same now and then, took it to the dealer, they replaced the horn and no more trouble. I'm told its part of the system.
rokwldr is offline
post #12 of 15 (permalink) Old 07-25-2013, 07:56 AM
10 Colorado Ext. 4X4's Avatar
Actually not all these trucks have the passkey system. I thought the same thing until I recently went to the dealer to get a new key cut to VIN. The VIN search on my 2010 showed no transponder and the total cost for a new key was $36 and change. Just for an extra spare I had another cut at Home Depot and it works fine.
10 Colorado Ext. 4X4 is offline
post #13 of 15 (permalink) Old 07-25-2013, 12:45 PM
GM Customer Service's Avatar
Hello rokwldr,
I am glad to see your vehicle was able to be repaired by the dealership and there is no more trouble. I am sorry for any trouble you had to go through in order to get this replaced. If you ever have any other questions or concerns, don't hesitate to contact us via private message.
Laura M. (assisting Jennifer T.)
GM Customer Care
post #14 of 15 (permalink) Old 08-08-2015, 05:37 PM
Same issue
I'm having the same issue, no starting, but waiting 15 minutes and it usually does. But my main issue seems to be weather related. In extreme heat or humidity, it is unreliable. Most times waiting 15, sometimes 30 minutes and it starts fine. Only happens from June-July to about late September, never any other time of year. Dealer can't figure it out, no security system, manual locks and windows. Any ideas?
Chris08Colorado is offline
post #15 of 15 (permalink) Old 08-08-2015, 09:41 PM
to C'Fans.
What model year and engine are we talking about? If the Dealer can't figure it out, I'm assuming that it isn't a PassLock problem. Maybe a defective starter.
