Engine stalls - rough idle (suggestions?) - Chevy Colorado & GMC Canyon
post #1 of 16 (permalink) Old 09-24-2011, 11:38 AM Thread Starter
2007 Colorado Z71 5cyl. automatic 86k mileage
When coming to a stop the rpm drops to 500 and feels like it is going to stall. It then jumps back up to about 750, but idles rough. The engine completely stalled one time as I was braking coming off of a freeway off-ramp into a turn. The check engine light has come on twice, but went out on the next drive. This has been over a two week period.
I replaced a gunked up air filter. Ran perfect on the drive home. The next time I drove it the problem reoccured.
I replaced the MAF. Again, ran perfect on the test drive. The next time I drove it though the problem reoccured.
Someone suggested that I disconnect the battery to reset the computation for the air-fuel mixture. Didn't work.
This is my first time using the forums here. Any ideas or suggestions would be greatly appreciated.
Thanks,
T
TSimps7777 is offline
post #2 of 16 (permalink) Old 09-24-2011, 12:55 PM
CALI-BOSS
DBNissan's Avatar
The best thing to do is scan your PCM to find out what codes were thrown when the CEL came on. Probably need to clean the throttle-body and check for vacuum leaks. You didn't need to change the MAF sensor. A simple cleaning would have achieved the same results.
DBNissan is offline
post #3 of 16 (permalink) Old 09-27-2011, 03:36 AM
Clean the throttle body. It's a simple 1 hour job that only costs about 12 bucks for the cleaner. Mine used to do the same exact thing yours is doing. Cleaned the TB, no problems since.
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does an oil change. It's a pity the ECU is so damn temperamental. -- Author Unknown
Sarge is offline
post #4 of 16 (permalink) Old 10-06-2011, 01:49 AM
Mine was doing that off and on too. It turned out the solution, for me, was to replace a spark plug coil that had gone bad. Found out the CEL was telling me of a large number of misfires in one of the cylinders. Changed all the plugs while it was apart too since there were about 85000 miles on the truck. No more rough idle.
cm_wright22 is offline
post #5 of 16 (permalink) Old 02-01-2012, 09:40 PM
Angry 2007 GMC Canyon - Check Engine & Stalling Problems
I have a 2007 GMC Canyon and beginning last Summer (in 2011) the Check Engine light started coming on intermittently. Also, whenever I come to a stop, the RPMs run so low that sometimes my truck stalls if I don't rev the engine a little while I have the brakes applied. I have taken it to multiple shops (including the dealership). They run a diagnostics on it each time, which returns a code that can mean multiple issues. However, nothing LOOKS wrong to them. They have cleaned the throtte body, which seemed to help for about two months, but that might have been my imagination. I have had hoses and other various parts replaced (including a new battery), as well as filled up a couple of times with the most expensive gasoline, in hopes that it would help, but the problem still exists. Now, on top of the stalling and check engine light issues, my truck likes to run the windshield wipers whenever it wants, turn on control panel lights for a few minutes just to scare me, and some of the lights on my radio buttons no longer light up. I love my Canyon and want to keep it for a very long time, but I have no clue (and neither does anyone else obviously) as to what to do about these issues. :(
tracyandnoah is offline
post #6 of 16 (permalink) Old 02-01-2012, 10:04 PM
Thanks,
T
Keep the old MAF sensor if you haven't already tossed it. It will be a backup for you. Yep, a cleaning is all you need to do (unless somebody broke it). All you do is pull it out, spray it with MAF Cleaner (a specific cleaner) and reinstall. The throttle body is pretty easy to clean, but the fuel disconnect line is tricky. Something else aside from intake issues are vacuum leaks, like mentioned previously. You may have a bad coil someplace. Maybe an injector is dirty/clogged. The coil and injector are a long shot if it actually runs alright but acts up at idle. I wonder if the cam actuator thingy can cause that, if the valve timing is screwy. Do our trucks have an idle air sensor? Your local autoparts store should be able to read the codes for you. See if you can get that info and provide the info back here. These dudes are sharp when it comes to codes. Also, if you clean the Throttle Body (TB) let us know how that goes.
What are the possible codes the dealer has told you could be problems? Expensive fuel won't fix anything. Maybe running some injector cleaner through the system, or running Seafoam through your top end? The other issues you speak of sound like what the Body Control Module (BCM) control. Try to pull your battery for an hour. That will allow any remaining energy in the BCM to bleed off. That's a good place to start for the wipers and radio issues.
post #7 of 16 (permalink) Old 02-02-2012, 06:37 PM
This sounds about the same issue with my colly as well when i come to a stop sign or taking a small u-turn my idling seems to go to were the truck wants to stall out i know my check engine light has been on but thats the 02 sensor that bad i might have to recheck it again just to be safe as for the tb i am gonna do that tomorrow and get that out of the way....but i will post my codes on here tomorrow and see if they might match up with tsimps777 man i hope its not a fuel injetor...
fenix23 is offline
post #8 of 16 (permalink) Old 12-07-2014, 05:13 PM
Tagged. Thanks.
FoggDogg is offline
post #9 of 16 (permalink) Old 03-18-2015, 02:48 PM
same issues on Canyon
Have you had any luck in resolving this. My canyon is now doing the same thing
Keith Klimko is offline
post #10 of 16 (permalink) Old 03-25-2015, 08:59 PM
i just got a canyon and im having the same problem as well, when starting it takes like 15 seconds before it becomes normal and it starts really rough. it almost stalls everytime i accelerate slowly in drive or reverse. i have had it stall on me in reverse. when driving it runs perfectly. Ever figure out what the problem was?
canyon man12 is offline
post #11 of 16 (permalink) Old 03-25-2015, 09:31 PM
rkj__'s Avatar
Clean the throttle body. If problem persists, come back for more help.
rkj__ is offline
post #12 of 16 (permalink) Old 03-25-2015, 09:36 PM
to C'Fans.
What rkj said.
post #13 of 16 (permalink) Old 03-26-2015, 08:05 PM
just cleaned the throttle body and its working perfectly now.
post #14 of 16 (permalink) Old 06-29-2015, 03:19 PM
Rough idle and stalls
Replace the intake exhaust camshaft actuator solenoid. It costs $65.00 + tax. They go bad all the time. You get it any gm dealer parts.
davdos19516952 is offline
post #15 of 16 (permalink) Old 07-07-2015, 04:42 PM
I have an 04 Canyon single cab. It began running very rough, and stalled on me repeatedly yesterday. I changed the fuel filter today. After changing, at first it was still running rough, so I took it on the highway and gunned it until it got up to the speed limit. I could tell exactly when the rest of the trash blew through. Still runs slightly rough, but not so much that I fear it will stall out on me. Going to try cleaning the throttle body next and see if that fixes the rest.
crazy4cp is offline
post #16 of 16 (permalink) Old 11-19-2015, 08:10 AM
my 2008 canyon stall out at idle when warm only no codes cleaned throttle body no help short term and long term fuel trim normal runs fine above 800 rpm
phill king is offline
