05 Colorado Dies Briefly TB Code - Chevy Colorado & GMC Canyon
post #1 of 8 (permalink) Old 12-02-2016, 06:28 PM Thread Starter
Hi Everyone,
Looking to see if anyone has any info or thoughts on an odd issue I am having with my 2005 Z71 Colorado. The truck runs perfectly, Just hitting 105,000 miles no issues until recently. I can be driving along just fine then suddenly it will die loose power but kick right back in, the best way I can described it is image pulling all the power for a brief moment then putting power right back. The truck will keep on going never dies, just that brief dead spot like a stall. No throttle response nothing but it is quick doesn't last long. The ECM was throwing the throttle body code, I have tested this with known good throttle bodies same issue present. I checked the wire to the ECM from the TBI no open circuit there. I have heard the connector can be an issue, mine is super clean plastic is not brittle at all. I hate to throw money at a replacement ECM, figured I would see if anyone has seen or heard of this issue before. I hate to pull what I have left of my hair out!
Thanks!
Scott
TheSnake16 is offline
post #2 of 8 (permalink) Old 12-02-2016, 08:46 PM
to C'Fans
Any chance you can get that throttle body code? It could help. Some throttle control problems will cause the ECM to switch to Reduced Power Mode which would give the symptom you describe.
post #3 of 8 (permalink) Old 12-21-2016, 12:46 PM Thread Starter
Thanks sorry about the late reply! P2119
post #4 of 8 (permalink) Old 12-21-2016, 07:09 PM
Low voltage can cause a P2119 to set. How old is the battery? Might be a good idea to have it load tested. Most Advance or AutoZone parts stores will do it free.
post #5 of 8 (permalink) Old 12-21-2016, 08:04 PM
It sure sounds electrical to me. I would be cleaning everything electrical including grounds, battery alternator connections and anything electrical on the throttle body. I realize that this is a shotgun approach but finding intermittent problems is sometimes reduced too doing just that.
post #6 of 8 (permalink) Old 01-06-2017, 08:47 AM Thread Starter
Thanks everyone for the suggestions, I have a fresh batter for what that is worth. I have cleaned what connections I can. The truck is super clean well maintained hard to find hard or brittle plastic connectors anywhere. I certainly agree it is electrical, crazy thing! I will see if I can get back under the hood and report back with any new findings. Happy New Year everyone!
Scott
post #7 of 8 (permalink) Old 01-09-2017, 09:11 PM
I am having the same intermittent issue, however I get code P2101. I am going to try the throttle body pigtail harness fix. Can find them on e**y for about $20. I clean my throttle body periodically and maybe I damaged the connector while I was removing it at one point. I'll let you know if it works. It's the cheapest thing to try first I guess. In the meantime, if you find a fix. post it here. Thanks
Tailgater is offline
post #8 of 8 (permalink) Old 01-11-2017, 08:36 AM Thread Starter
Thanks Tailgater, looking forward to your results. I almost changed mine out, seeing how it was not dry or brittle I left it alone.
