no acceleration after first start of the day - Chevy Colorado & GMC Canyon
post #1 of 10 (permalink) Old 02-20-2017, 09:57 AM Thread Starter
So I am having a problem with my 04 I5 Colorado. In the morning and sometimes after work (basically after the vehicle sits for awhile) the truck has very bad acceleration and sometimes acts like it wants to stall but it never does. Yesterday I cleaned the throttle body but that did not solve the problem. The throttle body was dirty even seemed a little oily or slick. I went to autozone because of the check engine light that came on with this little issue but they just printed out like 10 pages of could be culprits anywhere from o2 sensors to spark plugs.
One thing that has also happened which may or may not be coincidental is that I now have an exhaust leak in the pipe union right under passenger driver seat. Any help would really be great.
rpresley is offline
post #2 of 10 (permalink) Old 02-20-2017, 05:14 PM
Bad accel is very vague, does it miss, just not move ? What do you mean? What does it do exactly? When does it act like it wants to stall?
JScottM is offline
post #3 of 10 (permalink) Old 02-21-2017, 06:12 AM Thread Starter
So vehicle starts up fine. When I start to give it some gas (pedal) then it just doesn't respond and basically just idles along until it warms up a bit maybe 5-10min. During this time the idle will vary from very low almost dying to normal rpm, but just doesn't respond to the gas pedal. Basically what I have been doing is starting up and then idling down the road until the vehicle starts to respond to the gas pedal, once it does the vehicle drives fine. However a new thing that happened last night after work was that even after the warm up period, at a stop sign the vehicle idled down and almost died but recovered on its own without me giving it the pedal, did not die and drove fine.
I cleared the engine light yesterday and then after driving the vehicle gave me a light again P0300 random misfire. Only other thing that has happened and maybe just a coincidence is I now have a vacuum leak under the passenger front seat, pipe to pipe gasket.
rpresley is offline
post #4 of 10 (permalink) Old 02-21-2017, 10:30 AM
How many miles on the engine?
GregDAP is offline
post #5 of 10 (permalink) Old 02-21-2017, 12:05 PM Thread Starter
150,000
rpresley is offline
post #6 of 10 (permalink) Old 02-21-2017, 01:43 PM
Possible worn valve seats... common on 2004-2006 models. There was a TSB from chevy about it. Do a compression or cylinder leak down test. Also o2 sensors go bad around 100,000 miles. Also clean the MAF sensor. Also if you didn't remove the negative battery cable while cleaning the throttle body then that could be the problem. Remove the negative battery cable for a couple of hours. Re connect the let the idle.for about 10 min so the computer can relearn.
GregDAP is offline
post #7 of 10 (permalink) Old 02-21-2017, 01:59 PM
BeastStarr68's Avatar
I had something similar happen to me one morning on my 2017 Canyon. It got cold over night and I backed out of the drive and drove/coast about 25 yards to the stop sign. When I turned right to head up the hill I hit the gas and it was like it was in neutral. It was only for a second or two and then it seemed to get in gear and take off. I don't know about everybody else but my trucks transmission does not like the cold when starting off. I really have to drive about a quarter of a mile to get the temp up before it becomes a responsive smooth running auto transmission. Some folks in cold climates use engine block heaters, well my truck needs a transmission heater
BeastStarr68 is offline
post #8 of 10 (permalink) Old 02-21-2017, 02:49 PM Thread Starter
I removed the negative cable when I did the TB cleaning. I looked at the MAF sensor, it did not look like much nor did it look dirty at least I don't think so.
I guess I need to change the o2 sensors there are just a bit pricey at autozone. I thought that I might get a different code for the o2 sensors...I don't even want to think about the worn valve seats.
rpresley is offline
post #9 of 10 (permalink) Old 02-21-2017, 02:55 PM
NewColy's Avatar
I've had good results just spraying out the o2's with a quality contact cleaner. $9/can? just make sure not to touch the tips with your fingers.
NewColy is offline
post #10 of 10 (permalink) Old 02-21-2017, 05:00 PM Thread Starter
Went to repair the exhaust leak and noticed after running truck to see how it was doing that a small amount of water ran out of the flange/gasket area where my obvious leak is. Did not look or smell or feel like coolant.
rpresley is offline
