2007 with P0300 code - Chevy Colorado & GMC Canyon
 2Likes
  • 1 Post By NewColy
  • 1 Post By JScottM
post #1 of 8 (permalink) Old 02-22-2017, 07:49 PM Thread Starter
Unhappy 2007 with P0300 code
2007 Colorado 5cyl with 70,000 miles. Dealer said bring it in for 90.00 diagnostic and could cost up to 5000.00 for head.
Don't really want to but thinking about trading in.
Ideas/suggestions please??????
waymo is offline
post #2 of 8 (permalink) Old 02-23-2017, 11:34 AM
NewColy's Avatar
if the truck runs good, you should have time to research. search for p0300 here and on 355nation.net. I think from memory that a compression test is best way to confirm/eliminate a head/valve issue. i'd find an reputable independent shop to do it (or DIY), I don't trust the dealer at all. there are many other reasons for that code ... actuator solenoid, loose bolts on the intake manifold, faulty coil(s), loose/intermittent connector, plugs, etc... P0300- what's my next step - Chevrolet Colorado & GMC Canyon Forum
waymo likes this.
NewColy is offline
post #3 of 8 (permalink) Old 02-23-2017, 02:15 PM
Isn't that a random misfire code? If so have you ever put spark plugs in the truck? 70k they will be worn out for sure. I think plugs would be a good cheap start you know? Besides if they have never been replaced it needs it anyway......
And look very closely at the boots too.
waymo likes this.
JScottM is offline
post #4 of 8 (permalink) Old 02-23-2017, 03:06 PM Thread Starter
Thanks to all and just found out could be #5 Coil, code was P0305...my mistake
another per said he just kept driving and no problem light just kept going off and on...
not blinking steady on when on.
waymo is offline
post #5 of 8 (permalink) Old 02-23-2017, 07:12 PM
Again, have you done spark plugs yet? If not do that first, It could be #5 plug. (much cheaper than a coil)
If you haven't changed the plugs at 70k they are overdue anyway.
JScottM is offline
post #6 of 8 (permalink) Old 03-02-2017, 07:11 PM Thread Starter
Took to mechanic and he could not get it to miss...once it throws the P0305 code if it is not still missing he says
no way to diagnose. It misses when it throws the code and the misses again when Check Engine Light goes out.
It is out now so mech says no way to check.
waymo is offline
post #7 of 8 (permalink) Old 03-02-2017, 07:19 PM
Swap the #5 coil with one of the others and see if the code moves with the coil.
post #8 of 8 (permalink) Old 03-03-2017, 08:50 PM
do the freekin plugs already. sheeesh
JScottM is offline
