fuse box/ electrical problems 04 with I5 - Chevy Colorado & GMC Canyon
post #1 of 6 (permalink) Old 03-03-2017, 04:12 PM Thread Starter
where there a lot of them. the other month the TB lost its 12volt source and caused a code and reduce power. now yesterday the truck would not start. hauled it to a shop and found out the fuel pump is not getting power. is this a common thing?
1966 Chevelle SS396
1994 Corvette base coupe
2006 Chevy Malibu (wife's)
Nowhere Man is offline
post #2 of 6 (permalink) Old 03-03-2017, 05:23 PM
Where, in the fuse box, is the 12volt source of power for the Throttle Body? Which fuse protects the circuit? I thought the TB circuit was only between the PCM and the TB.
Both conditions are not common. Where is the fuel pump losing power?
post #3 of 6 (permalink) Old 03-03-2017, 05:36 PM Thread Starter
Not sure where the fuel pump is loosing power. The shop needs to dig deeper.
1966 Chevelle SS396
post #4 of 6 (permalink) Old 03-04-2017, 03:46 AM
Check and clean the grounds on both front inside fenders.
Wiring diagrams are located here:
http://www.naskie18.com/colorado/schematics/
post #5 of 6 (permalink) Old 03-04-2017, 04:42 PM Thread Starter
update the shop tore into the fuse box and found the contacts for the fuel pump fuse was not right. corrected that and now all is well. not sure why a past owner was in there to mess it up. but that is all it could be
1966 Chevelle SS396
post #6 of 6 (permalink) Old 03-05-2017, 05:23 AM
At least you found it and it was a simple fix.
