Belt Tensioner Replacement - Chevy Colorado & GMC Canyon
post #1 of 10 (permalink) Old 03-06-2011, 03:56 PM Thread Starter
My Belt Tensioner is squealing, how big of a job is it to replace it?
Steve
2005 GMC Canyon SLE Crew-Cab Off-Road Z71 4X4 3.5L
MaineCanyon is offline
post #2 of 10 (permalink) Old 03-06-2011, 03:57 PM
Blue15ColoradoLT's Avatar
Send a message via AIM to Blue15ColoradoLT Send a message via Yahoo to Blue15ColoradoLT
Re: Belt Tensioner Replacement
Check out this NEC355 event to helpy do the work in you are intersted:
http://www.nec355.net/forums/showthread.php?t=675
2015 Laser Blue Colorado LT
CC, 4X4, V6, SB
LED headlights
LED fog lights
LED high beams
LED reverse lights
LED license plate lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
Canyon swapped tail lights
Red painted calipers
Blue15ColoradoLT is offline
post #3 of 10 (permalink) Old 03-06-2011, 08:47 PM Thread Starter
Too far to travel.
Steve
post #4 of 10 (permalink) Old 03-09-2011, 06:02 PM Thread Starter
The part is under $40, and a new belt is under $40.
Doesn't look like a big deal to swap the tensioner, anyone have any input?
Steve
post #5 of 10 (permalink) Old 03-10-2011, 12:06 AM
I have not changed a Collie one but on most other vehicles they are mounted to the engine with one bolt. Take off the belt, remove the tensioner mounting bolt, and you will have the tensioner in your hand. Reverse the process to install the new one. The last one I installed was on a Ranger outside at about 5 below zero. It took about 5 minutes.
I have to assume the Collie is very similar.
n9cv is online now
post #6 of 10 (permalink) Old 03-10-2011, 04:36 PM Thread Starter
It doesn't look hard at all, toughest part is the lack of space to work.
I'm going to put a new belt on at the same time, 100000 miles on the truck now.
Steve
post #7 of 10 (permalink) Old 03-16-2011, 04:04 PM
I don't know if you go over on the Nation site but here is a how to for the replacement. http://www.355nation.net/forum/how-perf ... ioner.html
2007 Chevrolet Colorado Crewcab 2WD Z85 Victory Red
3.7L
BigR is offline
post #8 of 10 (permalink) Old 03-18-2011, 10:08 AM
The belt tentioner is not that bad me and aa friend replaced the alternator and belt tentioner and belt in about 3 hrs
'05 colorado z71 LS
I5
colorado monogramed Tourneau
spectre air intake
lots more to come
reedbogger is offline
post #9 of 10 (permalink) Old 03-19-2011, 08:03 AM Thread Starter
It stopped making noise, not sure what was in there. I sprayed some parts cleaner into it, then some lube.....and now it's quiet again.
I'll keep an eye on it and see if it starts again.
Steve
post #10 of 10 (permalink) Old 04-17-2011, 09:33 AM
russman63's Avatar
It's possible the factory tensioner could be made in China. That might explain it.
Z71 owner
russman63 is offline
