i 4 oil trouble - Chevy Colorado & GMC Canyon
Old 06-23-2012, 02:26 PM   #1 (permalink)
Default i 4 oil trouble
i just bought a 05 colorado with 48000 miles and it used almost a gallon of oil in 300 miles , now its got no oil leaks or smoking not even scum on the tailgate any ideas
hobbytrucker1966 is offline   Reply With Quote
Old 06-23-2012, 10:43 PM   #2 (permalink)
Default
You'd be smoking like the space shuttle if it was going through the combustion chambers. You'd have oil all over the engine or on your driveway if it was leaking. Are you sure it was full when you got it? Did you pull the stick, wipe it off, and fully seat it again to check the oil? Are you checking the dipstick in good light - they are notoriously hard to read, especially with clean oil.
2008 Chevy Colorado 4x4 standard cab
31x10.50 Goodyear Wrangler Authority
Midland 1001WX CB w/ 3' Wilson antenna on driver's side fender
60/40 split bench converted to 40/40 buckets
Console from 1992 Jeep Wrangler
smokeybear is offline   Reply With Quote
Old 06-25-2012, 12:06 PM   #3 (permalink)
Default
Better check your coolant just to be sure there isn't oil in there.
2005 ZQ8
Hawkeye is offline   Reply With Quote
Old 06-25-2012, 07:17 PM   #4 (permalink)
Default
nothing in the coolant and yes it was full i made shure of that when i serviced it last the only thing i found is the tail pipe is black and sooty , its my 2nd colorado and yes the dip stick is hard to read im going for a 6 hr drive tomorrow and am takin some extra oil for the trip ill check it again getin frustrated thanks for the input
You may not post new threads
You may not post replies
